Reading: What is a Bus Coupler in Electrical Panel?
Inst Tools > Blog > Electrical Basics > What is a Bus Coupler in Electrical Panel?
Bus-coupler is one of the most important components used in an electrical panel. In this post, we will learn the concept of a bus coupler.
Last updated: January 9, 2023 2:13 pm
Electrical Basics
An electrical panel consists of many electrical components which must be understood properly for correct working. In electrical panels, you must have seen red, yellow, and blue color plates which are used in many distributed applications. This is called a bus coupler.
What is a Bus coupler?
First of all, let us understand what a bus bar is. A bus bar can be said as a group of conductor plates (three phases of R, Y, and B) that gets the main incoming power and distributes it to various outgoing requirements.
Refer to the below image for understanding. The main incoming three-phase supply is fed to the three plates of conductors. From these plates, various other small plates are distributed to panels or feeders which require three phase supply.
What happens is that you get a uniform connection and avoid a large number of connections to the main incomer. You have only one incoming supply and you can get multiple outgoing connections to various feeders which require supply.
Let us move ahead to the bus coupler now. Suppose there are two bus-bar panels. One panel is used to take incoming supply from transformer-1 and another panel is used to take supply from transformer-2.
Both these bus-bars are providing supply to the load. Now, comes the role of a bus coupler. Bus-coupler is a component that combines multiple bus bars together.
There are two uses for it. Let us see the first case. The bus coupler can be used to provide supply from the first bus bar by default. In case it fails, then it will cut off the first one and take the supply from the second one.
Here, the load will remain disconnected for some time. In this case, the two bus bars will be isolated from each other through the bus coupler.
Let us now take the second case. The bus coupler will connect both bus bars simultaneously. In case the first bus bar fails, then the load will be connected through the second bus bar. It will not stop consuming current even for a second. Thus, in any case, you can see that the bus coupler is used to combine multiple bus bars together.
So, the concept of a bus coupler is simple. It can either be used to connect multiple bus bars at a time simultaneously or connect them only one at a time; depending upon the current consumption and the amount of time the load can withstand disconnection of power.
In this way, we understand the concept of a bus coupler in an electrical panel.
  • Electrical Drawings
  • Motor Cooling Methods
  • SCADA in Power System
  • What is a Buchholz Relay?
  • Cables between VFD & Motor
Basics of Electrical Transformer
Formula of AMP, KW, KVA, HP for AC and DC Voltages
What is Arc Protective Clothing? – Importance, Features, Materials
What are Switchgear Interlocks?
DC Injection Braking in VFD
How to Check the Continuity of Protective Conductors?
Stepper Motor Working Principle
Why Are Charcoal and Salt Added to an Earthing Pit?
Understanding Protection Relays – 50, 50N, 51, 51N
What is a Wave Trap? – Power Line Carrier Communication
Difference Between Metering CT and Protection CT
Why is IGBT used in VFD?
Difference between Stepper Motor and Servo Motor
Connection between PLC and Contactor
Relay Parts
NO vs NC Contact
Humming Sound in Transformer
Why is the Humming Sound Produced in Transformer?
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Routine Tests of Circuit Breakers
Circuit Breaker Testing – Routine Tests of Circuit Breakers
4-20mA VFD Drive Formula
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
Why do we need to Control the Motion using VFD drives
Why do we need to Control the Motion using VFD drives?
Current Transformer Operation
Current Transformer Selection, Operation & Maintenance
Pressure Control Loop
Pressure Control Loop Wiring Connections
Simple High Level Indicator Circuit
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
Pneumatic-Level-Transmitter-Value-Struck
Pneumatic Level Transmitter Value Struck?
Flow Measurement Quiz
Flow and Level Measurement Quiz
Flow Switch Principle
In-Line Flow Switch Working Principle and Animation
Shift Registers Objective Questions
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
