Reading: How to Add Unspecified CPU in Tia Portal?
Inst Tools > Blog > PLC Tutorials > How to Add Unspecified CPU in Tia Portal?
Last updated: March 4, 2021 12:03 pm
2 Min Read
This article is about to add an unspecified CPU in Siemens TIA portal.
During software setup, you get to know that CPU which installed in hardware doesn’t contain a part number and you also don’t have anything else related to its which can give us a part number.
In such a case, siemens provide an option to detect unspecified CPU. Do follow the below steps to know the process of adding such CPU.
 Step 1:
Open TIA PORTAL. Create a new project or open an existing one.
Step 2:
Do follow the steps as shown in the below window.
In Simatic option, you Can expand any option to add CPU which you want to add.
Step 3:
Here. I will add the CPU using the Simatic-1500 option.
Expand CPU and choose unspecified CPU as shown in the below window.
Click “Add” to proceed.
Simatic-1500 CPU
Step 4:
The following window will open up. You can see unspecified CPU is added.
Adding unspecified CPU
Step 5:
Click on “Detect” as shown in the below window.
Siemens S7 CPU
Step 6:
The following window will open.
Hardware Detection for PLC
Step 7:
As you can see in the below window when I drop down the list it won’t contain a simulator option.
But simply you have to choose the method of communication you are using and hit the “start search” button. Where you can find a CPU and click on “detect” to add CPU.
As I don’t have actual PLC, I can’t show you detect procedure but you can find it by following the last step (online).
Assign CPU in Siemens PLC
Author: Suhel Patel
  • Script in Intouch Scada
  • Pulse Generation Timer
  • Why we use RTO?
  • FIFO Instruction in PLC
  • Create Project in Intouch
How to Take Program Backup from Physical PLC? – Siemens PLC
Working Principle of Single Phase Preventer Relay
Open Source PLC and SCADA Software
Difference Between PNP and NPN Sensors
Cybersecurity in PLC
How to Work with Allen Bradley RsLogix Emulator?
History of Programmable Logic Controllers (PLC)
PLC Program Example on Multiple LEDs using Set Coil
Car Wash Program using Functional Block Diagram (PLC)
Wiring in a PLC Control Panel
Create Ladder Diagram from Boolean Logic
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Configuration of Siemens VFD Using TIA Portal
Configuration of Siemens VFD Using TIA Portal Start drive
PLC Conversion Program
How to use Converters in PLC
PLC offline data of a project are compared
Compare Two Offline PLC Projects
Simple PLC example Hardware configurations
PLC to Start or Stop 3 Machines using 1 Switch Program
Difference Between PLC and CNC Machine
Safety PLC Coding Practices
Safety PLC Coding Practices – Programming Recommendations
Emergency Block Valve
SIS Emergency Block Valves (EBV)
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
What is an RTD
Components of RTD
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Microprocessors Objective Questions – Set 7
Most Frequently Asked Instrumentation Questions
General Instrumentation Questions
Transmission Lines Protection Questions Answers
Instrument Control Package (ICP)
Package Control and Safety Systems Implementation Methods
