Reading: Types of MCB
Inst Tools > Blog > Electrical Basics > Types of MCB
Types of MCB
A miniature circuit breaker (MCB) is an automatic electromechanical device that guards the electrical system short circuit and overcurrent.
Last updated: October 17, 2023 3:21 pm
R Jagan Mohan Rao
Electrical Basics
6 Min Read
PrincipleMCB (Miniature Circuit Breaker)MCB RatingTypes of MCB based on Tripping CharacteristicsType BType CType DType KTypes of MCB based on PolesAdvantagesDisadvantagesApplications
MCB is a replacement of rewirable switch-fuse for low power domestic and industrial applications.
MCB is a function of three functions in one and ensures protection against short circuit, switching, and overload. Protection of overload by using a bimetallic strip and short circuit protection by a solenoid.
MCB should not be confused with the earth leakage circuit breaker(ELCB), MCB is only an overload relay.
Principle
As the current flows through the bimetallic strip, it gets heated up and deflects by bending and releases the mechanical latch.
The deflection of the bimetallic strip depends on the amount of current flowing through the strip. More the current, the faster the deflection of the bimetallic strip.
During the short circuits, the transient current flowing through the solenoid forces the plunger towards the latch. This action is rapid and releases the mechanical latch and opens the contacts immediately.
Types of MCB
  1. Actuator lever – used to manually trip and reset the circuit breaker. Also indicates the status of the circuit breaker (On or Off/tripped). Most breakers are designed so they can still trip even if the lever is held or locked in the “on” position. This is sometimes referred to as “free trip” or “positive trip” operation.
  2. Actuator mechanism – forces the contacts together or apart.
  3. Contacts – allow current when touching and break the current when moved apart.
  4. Terminals
  5. Bimetallic strip – separates contacts in response to smaller, longer-term overcurrents
  6. Calibration screw – allows the manufacturer to precisely adjust the trip current of the device after assembly.
  7. Solenoid – separates contacts rapidly in response to high overcurrents
  8. Arc divider/extinguisher
Tripping Mechanism
  1. Thermal Tripping
  2. Magnetic tripping.
MCB Rating
The ampere rating describes the maximum current the circuit breaker can carry without tripping.
Available in the range of 0.5 A to 100 Amp.
  • Type B
  • Type C
  • Type D
  • Type K
Type B
In type B, the MCB trips between 3 to 5 times of full load.
Operating current 0.4 to 13 seconds.
Type of load: Resistive loads.
Response: React quickly to overloads.
Uses: Incandescent lighting, bulbs, heaters. Residential applications.
Type C
In type C, the MCB trips between 5 to 10 times of full load. Used in residential or industrial applications.
Operating current 0.4 to 5 seconds
Type of Load: Slightly inductive loads.
Response: React more slowly.
Uses Highly inductive loads such as motors, Air conditioners, fans, and household appliances.
Type D
In type D, the MCB trips between 10 to 20 times of full load. This is used in industrial or commercial applications where there could be chances of the higher value of short circuit currents in the circuit.
Operating current 0.4 to 3 seconds.
Type of Load: Inductive loads.
Uses Very high inrush inductive currents such as small transformers, UPS, small motors, pumps.
Type K
In type K, the MCB trips between 8 to 10 times of full load.
Operating current less than 0. 4 to 3 seconds.
Response: MCBs are slower.
Uses: Enhanced protection is achieved without nuisance tripping.
  • Single pole
  • Double pole
  • Three pole
  • Four pole
A single-pole (1P) MCB provides switching and protection only for one single phase of supply.
A two-pole (2P) provides switching and protection for both phase and neutral.
A three-pole (3P) MCB provides switching and protection only to three phases and not neutral.
A three-pole with neutral (3P+N) has switching and protection to all three phases and additionally neutral.
A four-pole (4P) MCB is similar to Three poles neutral.
Advantages
  • Handling of an MCB is safer.
  • Restoration of power supply quickly is possible with MCBs.
  • During abnormal conditions such as overload and fault conditions, automatically switches off the electrical circuit.
  • Power restoration can be done quickly.
  • It is easier to identify when they have tripped.
Disadvantages
  • Slow tripping
  • Aging and wear
  • Vulnerability to heat
  • They are more expensive than fused switches.
  • Can not protect against earth faults.
Applications
Miniature circuit breakers (MCB) are used in residential, commercial, and industries.
Reference: Wikipedia
  • Circuit Breaker Quiz
  • Circuit Breaker Animation
  • Oil Circuit Breakers
  • How to Select a Fuse?
  • What is Auto Reclosing?
Motor Cooling Methods
Introduction to Protective Systems
Single Phase versus Three Phase Power
What is an Electrical Drive? Types, Advantages, Disadvantages
What is Switchgear and Electrical Substation?
Dynamic Braking Resistor in VFD
Difference Between MPCB and MCCB
How to Read and Understand an Electrical Single Line Diagram?
Electrical Switches Principle & Types
What is an Air Circuit Breaker? Working Principle & Applications
Electric Motors Efficiency Classes
Connection between PLC and Contactor
How to Check the Continuity of Protective Conductors
How to Check the Continuity of Protective Conductors?
Motor Slip Calculation
Electrical Motor Terms and Concepts
Intelligent MCC
What is Smart or Intelligent MCC?
Difference between Servo Motor and DC Motor
Difference Between RCCB and MCCB
Electrical Conduit Seal
Why Are Neutral and Earth Separated
Why Are Neutral and Earth Separated?
Construction of Megger
What is a Megger? Principle, Advantages, Disadvantages, Applications
different types of threads based on 4 standards
Different Types of Threads based on 4 Standards
Field Instruments enclosures
Pressure Transmitter Heated Enclosures
Heat Exchanger Baffles Holes
Heat Exchanger Tubes Corroded Root Cause Analysis
Peak Inverse Voltage of Center Tap Rectifier
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
Classification of Transmission Lines
Three Wire RTD Wheatstone bridge Circuit
RTD Wheatstone Bridge Circuits
