Reading: Types of NMR Spectrometers Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Types of NMR Spectrometers Questions & Answers
1. Which of the following is not a type of NMR spectrometer?
a) Minimal type
b) Maximal type
c) Multipurpose type
d) Wideline type
Answer: b
Explanation: Maximal type is not a type of NMR spectrometer. Minimal type, Multipurpose type and Wideline type are types of NMR spectrometer.
2. Which of the following NMR spectrometers have stressed reliability and ease of operation?
a) Minimal type
b) Maximal type
d) Wideline type
Answer: a
Explanation: Minimal type has stressed reliability and ease of operation. It uses a permanent magnet.
3. Which of the following type of NMR spectrometer uses a frequency synthesizer to generate RF fields?
a) Minimal type
b) Maximal type
d) Wideline type
Answer: c
Explanation: Wideline type NMR spectrometer uses a frequency synthesizer to generate RF fields. It is a type of continuous wave NMR spectrometer.
4. In wideline NMR spectrometers, which of the following has to be supplied to the electromagnet?
a) Slowly varying low voltage
b) Rapidly varying low voltage
c) Slowly varying scan voltage
d) Rapidly varying scan voltage
Answer: c
Explanation: In wideline NMR spectrometers, slowly varying scan voltage has to be supplied to the electromagnet. This is injected using a regulator.
5. Which among the following NMR spectrometer is the more diverse spectrometer?
a) Minimal type
b) Maximal type
d) Wideline type
Answer: c
Explanation: Multipurpose type NMR spectrometer is more diverse. These instruments are designed mainly for research.
6. Permanent magnet cannot be used in wideline type NMR spectrometer.
a) True
b) False
Answer: b
Explanation: Permanent magnet can be used in wideline type NMR spectrometer. Compact, light-weight electromagnet can also be used.
7. Which of the following NMR spectrometer emphasises on high performance versatility with cost being a secondary consideration?
a) Minimal type
b) Maximal type
d) Wideline type
Answer: c
Explanation: Multipurpose type is mainly used for research. Hence, it emphasises on high performance versatility with cost being a secondary consideration.
8. Which of the following NMR spectrometer does not require power supply and cooling system?
a) Minimal type
b) Maximal type
d) Wideline type
Answer: a
Explanation: Minimal type NMR spectrometer uses a permanent magnet. Hence, it does not require power supply and cooling system.
9. Minimal type NMR spectrometer is inexpensive.
a) True
b) False
Answer: a
Explanation: Minimal type NMR spectrometer is inexpensive. It uses a permanent magnet and does not require a power supply.
10. Which of the following is used as coolant for magnets in continuous-wave NMR spectrometer?
a) Water
b) Liquid He
c) Liquid Na
d) Heavy water
Answer: a
Explanation: Water is used as coolant for magnets in continuous-wave NMR spectrometer. Liquid He is used for FT-NMR spectrometers.
Silica Analyzer Questions & Answers
Compensation Techniques : Control Systems
Steady-state Errors & Error Constants
Infrared Gas Analyzers Questions & Answers
Continuous Wave NMR Spectroscopy Questions & Answers
Solution of State Equations
Detection System of Liquid Chromatography Questions & Answers
Surface Spectroscopic Techniques
NO2 Analyzer Questions & Answers
Stability Analysis by Describing Functions
Fundamentals of Radiochemical Methods Questions
Time Response Analysis
Performance Indices
Optimal Control Systems
Optimal Control Problems – Part 1
Control Loops Multiple Choice Questions
Control Loop Multiple Choice Questions
State Variable Analysis – Part II
Absorption Instrumentation Questions & Answers
Components of Mass Spectrometer Questions & Answers
Stability in Frequency Domain
Assessment of Relative Stability Using Nyquist Criterion
ORP Measurement
Basics of ORP Measurement
4–20 mA Process Control Loops
Electron Spin Resonance Questions & Answers
Instrumentation of ESR Spectrometer
How Buoyant Force instruments Works
Power Systems MCQ Series 12
Feedforward Control Questions & Answers
Temperature Switch Calibration
How to Calibrate Temperature Switch? – Instrument Basics
Why Calibration is Important
Why Calibration is Important?
