What is a Band-Stop Filter?
You are here:
Band-stop Filter
Also called band-eliminationband-reject, or notch filters, this kind of filter passes all frequencies above and below a particular range set by the component values.
Not surprisingly, it can be made out of a low-pass and a high-pass filter, just like the band-pass design, except that this time we connect the two filter sections in parallel with each other instead of in series. (Figure below)
Band-Stop Filter
System level block diagram of a band-stop filter.
Twin-T Band-stop Filter
Constructed using two capacitive filter sections, it looks something like (Figure below).
Twin-T band-stop filter
“Twin-T” band-stop filter.
The low-pass filter section is comprised of R1, R2, and C1 in a “T” configuration. The high-pass filter section is comprised of C2, C3, and R3 in a “T” configuration as well. Together, this arrangement is commonly known as a “Twin-T” filter, giving sharp response when the component values are chosen in the following ratios:
Notch Frequency
Given these component ratios, the frequency of maximum rejection (the “notch frequency”) can be calculated as follows:
The impressive band-stopping ability of this filter is illustrated by the following SPICE analysis: (Figure below)
twin-t bandstop filter
v1 1 0 ac 1 sin
r1 1 2 200
c1 2 0 2u
r2 2 3 200
c2 1 4 1u
r3 4 0 100
c3 4 3 1u
rload 3 0 1k
.ac lin 20 200 1.5k
.plot ac v(3)
.end
Response of “twin-T” band-stop filter.
REVIEW:
  • band-stop filter works to screen out frequencies that are within a certain range, giving easy passage only to frequencies outside of that range. Also known as band-eliminationband-reject, or notch filters.
  • Band-stop filters can be made by placing a low-pass filter in parallel with a high-pass filter. Commonly, both the low-pass and high-pass filter sections are of the “T” configuration, giving the name “Twin-T” to the band-stop combination.
  • The frequency of maximum attenuation is called the notch frequency.
Previous: What is a Band-Pass Filter?
Next: Resonant Filters
Share via
Send this to a friend
