Half-Adder
As a first example of useful combinational logic, let’s build a device that can add two binary digits together. We can quickly calculate what the answers
should be:
0 + 0 = 0          0 + 1 = 1          1 + 0 = 1          1 + 1 = 102
So we well need two inputs (a and b) and two outputs. The low order output will be called Σ because it represents the sum, and the high order output will be called Cout because it represents the carry out. The truth table is
Half-Adder Truth Table
Simplifying boolean equations or making some Karnaugh map will produce the same circuit shown below, but start by looking at the results.
The Σ column is our familiar XOR gate, while the Cout column is the AND gate. This device is called a half-adder for reasons that will make sense in the next section.
Half-Adder
or in ladder logic
Half-Adder Ladder Logic
Previous: Introduction to Combinational Logic Functions
Next: Full-Adder
Share via
Send this to a friend
