Reading: Top 100 Control Systems Objective Questions & Answers
Inst Tools > Blog > Control Systems MCQ > Top 100 Control Systems Objective Questions & Answers
Here at Instrumentation Tools, we can offer you with a list of Top 100 Objective type questions-answers on Control Systems.
Last updated: September 7, 2020 4:01 pm
Control Systems MCQ Instrumentation Interview Questions Multiple Choice Questions
6 Comments
26 Min Read
We prepared an article on Control Systems Objective Questions & Answers. Test your skills on control systems. Best wishes for your exam preparation.
Control Systems Objective Questions & Answers1. In an open loop control system2. For open control system which of the following statements is incorrect ?3. A control system in which the control action is somehow dependent on the output is known as4. In closed loop control system, with positive value of feedback gain the overall gain of the system will5. Which of the following is an open loop control system ?6. Which of the following statements is not necessarily correct for open control system ?7. In open loop system8 . ___has tendency to oscillate.9. A good control system has all the following features except10. A car is moving at a constant speed of 50 km/h, which of the following is the feedback element for the driver ?11. The initial response when tune output is not equal to input is called12. A control system working under unknown random actions is called13. An automatic toaster is a ______ loop control system.14. Any externally introduced signal affecting the controlled output is called a15. A closed loop system is distinguished from open loop system by which of the following ?16. ___ is a part of the human temperature control system.17. By which of the following the control action is determined when a man walks along a path ?18. ___ is a closed loop system.19. Which of the following devices are commonly used as error detectors in instruments ?20. Which of the following should be done to make an unstable system stable ?21. ___ increases the steady state accuracy.22. A.C. servomotor resembles23. As a result of introduction of negative feedback which of the following will not decrease ?24. Regenerative feedback implies feedback with25. The output of a feedback control system must be a function of26. ___ is an open loop control system.27. A control system with excessive noise, is likely to suffer from28. Zero initial condition for a system means29. Transfer function of a system is used to calculate which of the following ?30. The band width, in a feedback amplifier.31. On which of the following factors does the sensitivity of a closed loop system to gain changes and load disturbances depend ?32. The transient response, with feedback system,33. The second derivative input signals modify which of the following ?34. Which of the following statements is correct for any closed loop system ?35. Which of the following statements is correct for a system with gain margin close to unity or a phase margin close to zero ?36. Due to which of the following reasons excessive bond width in control systems should be avoided ?37. In a stable control system backlash can cause which of the following ?38. In an automatic control system which of the following elements is not used ?39. In a control system the output of the controller is given to40.  A controller, essentially, is a41. Which of the following is the not the ideal input to a controller ?42. The on-off controller is a _____ system.43. The capacitance, in force-current analogy, is analogous to44. The temperature, under thermal and electrical system analogy, is considered analogous to45. In electrical-pneumatic system analogy the current is considered analogous to46. In liquid level and electrical system analogy, voltage is considered analogous to47. The viscous friction co-efficient, in force-voltage analogy, is analogous to48. In force-voltage analogy, velocity is analogous to49. In thermal-electrical analogy charge is considered analogous to50. Mass, in force-voltage analogy, is analogous to51. The transient response of a system is mainly due to52. ___ Signal will become zero when the feedback signal and reference signs are equal.53. A signal other than the reference input that tends to affect the value of controlled variable is known as54. The transfer function is applicable to which of the following ?55. From which of the following transfer function can be obtained ?56. ___ is the reference input minus the primary feedback.57. The term backlash is associated with58. With feedback _____ increases.59. By which of the following the system response can be tested better ?60. In a system zero initial condition means that61. In a system low friction co-efficient facilitates62. Hydraulic torque transmission system is analog of63. Spring constant in force-voltage analogy is analogous to64. The frequency and time domain are related through which of the following?65. An increase in gain, in most systems, leads to66. Static error co-efficients are used as a measure of the effectiveness of closed loop systems for specified     ________ input signal.67. A conditionally stable system exhibits poor stability at68. The type 0 system has ______ at the origin.69. The type 1 system has ______ at the origin.70. The type 2 system has    at the origin.71. The position and velocity errors of a type-2 system are72. Velocity error constant of a system is measured when the input to the system is unit _______ function.73. In case of type-1 system steady state acceleration is74. If a step function is applied to the input of a system and the output remains below a certain level for all the time, the system is75. Which of the following is the best method for determining the stability and transient response ?76. Phase margin of a system is used to specify which of the following ?77. Addition of zeros in transfer function causes which of the following ?78. ___ technique is not applicable to nonlinear system ?79. In order to increase the damping of a badly underdamped system which of following compensators may be used ?80. The phase lag produced by transportation relays81. In a stable control system saturation can cause which of the following ?82. Which of the following can be measured by the use of a tacho-generator ?83. ___ is not a final control element.84. Which of the following is the definition of proportional band of a controller ?85. In pneumatic control systems the control valve used as final control element converts86. Pressure error can be measured by which of the following ?87. Which of the following devices is used for conversion of co-ordinates ?88. The effect of error damping is to89. ___ technique gives quick transient and stability response90. A phase lag lead network introduces in the output91. Which of the following is the non-linearity caused by servomotor ?92. ___ can be extended to systems which are time-varying ?93. When the initial conditions of a system are specified to be zero it implies that the system is94. Which of the following is electromechanical device ?95. A differentiator is usually not a part of a control system because it96. If the gain of the critical damped system is increased it will behave as97. In a control system integral error compensation _______    steady state error98. With feed back _____ reduces.99. An amplidyne can give which of the following characteristics ?100. Which of the following can be measured byLVDT?101. ___ directly converts temperature into voltage.102. The transfer function technique is considered as inadequate under which of the following conditions ?103. Which of the following is the output of a thermocouple ?104. A.C. servomotor is basically a105. The first order control system, which is well designed, has a106. Which of the following is exhibited by Root locus diagrams ?
(a)    Output is independent of control input
(b)    Output is dependent on control input
(c)    Only system parameters have effect on the control output
(d)    None of the above
Ans: a
(a)     Less expensive
(b)     Recalibration is not required for maintaining the required quality of the output
(c)    Construction is simple and maintenance easy
(d)    Errors are caused by disturbances
Ans: b
(a)     Closed loop system
(b)     Semiclosed loop system
(c)     Open system
Ans: a
(a)    decrease
(b)     increase
(c)     be unaffected
(d)     any of the above
Ans: a
(a)     Field controlled D.C. motor
(b)    Ward leonard control
(c)    Metadyne
(d)     Stroboscope
Ans: a
(a)     Input command is the sole factor responsible for providing the control action
(b)     Presence of non-linearities causes malfunctioning
(c)    Less expensive
(d)    Generally free from problems of non-linearities
Ans: b
(a)    the control action depends on the size of the system
(b)    the control action depends on system variables
(c)    the control action depends on the input signal
(d)    the control action is independent of the output
Ans: d
(a)    Open loop system
(b)    Closed loop system
(c)    Both (a) and (b)
(d)    Neither (a) nor (b)
Ans: b
(a)     good stability
(b)     slow response
(c)    good accuracy
(d)    sufficient power handling capacity
Ans: b
(a)     Clutch
(b)     Eyes
(c)    Needle of the speedometer
(d)    Steering wheel
(e)    None of the above
Ans: c
(a)     Transient response
(b)     Error response
(c)     Dynamic response
(d)     Either of the above
Ans: a
(a)     computer control system
(b)     digital data system
(c)    stochastic control system
(d)    adaptive control system
Ans: c
(a)     open
(b)     closed
(c)    partially closed
Ans: a
(a)     feedback
(b)     stimulus
(c)     signal
(d)     gain control
Ans: b
(a)     Servomechanism
(b)     Feedback
(c)    Output pattern
(d)    Input pattern
Ans: b
(a)    Digestive system
(b)    Perspiration system
(c)    Ear
(d)    Leg movement
Ans: b
(a)     Brain
(b)     Hands
(c)     Legs
(d)     Eyes
Ans: d
(a)     Auto-pilot for an aircraft
(6)     Direct current generator
(c)    Car starter
(d)    Electric switch
Ans: a
(a)     Vernistats
(b)     Microsyns
(c)     Resolvers
(d)     Any of the above
Ans: d
(a)     The gain of the system should be decreased
(b)     The gain of the system should be increased
(c)    The number of poles to the loop transfer function should be increased
(d)    The number of zeros to the loop transfer function should be increased
Ans: b
(a)      Integrator
(b)      Differentiator
(c)      Phase lead compensator
(d)      Phase lag compensator
Ans: a
(a)    two phase induction motor
(b)    Three phase induction motor
(c)    direct current series motor
(d)    universal motor
Ans: a
(a)     Band width
(b)     Overall gain
(c)     Distortion
(d)     Instability
Ans: a
(a)    oscillations
(b)    step input
(c)    negative sign
(d)    positive sign
Ans: d
(a)    reference and output
(b)    reference and input
(e)    input and feedback signal
(d)    output and feedback signal
Ans: a
Also Read : Open Loop and Closed Loop Animation
(a)    Ward Leonard control
(b)    Field controlled D.C. motor
(c)    Stroboscope
(d)    Metadyne
Ans: b
(a)    saturation in amplifying stages
(b)    loss of gain
(c)    vibrations
(d)     oscillations
Ans: a
(a)    input reference signal is zero
(b)    zero stored energy
(c)    ne initial movement of moving parts
(d)    system is at rest and no energy is stored in any of its components
Ans: d
(a)    The order of the system
(b)    The time constant
(c)    The output for any given input
(d)    The steady state gain
Ans: c
(a)    remains unaffected
(b)    decreases by the same amount as the gain increase
(c)     increases by the same amount as the gain decrease
(d)     decreases by the same amount as the gain decrease
Ans: c
(a) Frequency
(b) Loop gain
(c) Forward gain
(d) All of the above
Ans: d
(a) rises slowly
(b) rises quickly
(c) decays slowly
(d) decays quickly
Ans: d
(a) The time constant of the system
(b) Damping of the system
(c) The gain of the system
(d) The time constant and suppress the oscillations
Ans: d
(a) All the co-efficients can have zero value
(6) All the co-efficients are always non-zero
(c) Only one of the static error co-efficients has a finite non-zero value
Ans: c
(a)    The system is relatively stable
(b)    The system is highly stable
(c)    The system is highly oscillatory
Ans: c
(a)    It leads to slow speed of response
(b)    It leads to low relative stability
(c)    Noise is proportional to band width
Ans: c
(a)     Underdamping
(b)     Overdamping
(c)    Poor stability at reduced values of open loop gain
(d)    Low-level oscillations
Ans: d
(a)     Error detector
(b)     Final control element
(c)     Sensor
(d)     Oscillator
Ans: d
(a)     final control element
(b)     amplifier
(c)     comparator
(d)     sensor
(e)    none of the above
Ans: a
(a)     sensor
(b)     clipper
(c)     comparator
(d)     amplifier
Ans: c
(a)    Servo signal
(b)    Desired variable value
(c)    Error signal
(d)    Sensed signal
Ans: a
(a)    digital
(b)    linear
(c)    non-linear
(d)    discontinuous
Ans: d
(a)    momentum
(b)    velocity
(c)    displacement
(d)    mass
Ans: d
(a)     voltage
(b)     current
(c)     capacitance
(d)     charge
Ans: a
(a)     velocity
(b)     pressure
(c)     air flow
(d)     air flow rate
Ans: d
(a)     head
(b)     liquid flow
(c)    liquid flow rate
(d)    none of the above
Ans: a
(a)     charge
(b)     resistance
(c)    reciprocal of inductance
(d)    reciprocal of conductance
Ans: b
(a)     current
(b)     charge
(c)     inductance
(d)     capacitance
Ans: a
(a)    heat flow
(b)    reciprocal of heat flow
(c)    reciprocal of temperature
(d)    temperature
Ans: d
(a) charge
(b) current
(c) inductance
(d) resistance
Ans: c
Also Read : Automation Interview Questions
(a) inertia forces
(b) internal forces
(c) stored energy
(d) friction
Ans: c
(a) Input
(b) Actuating
(c) Feedback
(d) Reference
Ans: b
(a) disturbance
(b) command
(c) control element
(d) reference input
Ans: a
(a)    Linear and time-in variant systems
(b)    Linear and time-variant systems
(c)    Linear systems
(d)    Non-linear systems
Ans: a
(a)     Signal flow graph
(b)     Analogous table
(c)     Output-input ratio
(d)    Standard block system
Ans: a
(a)    Manipulated variable
(b)    Zero sequence
(c)    Actuating signal
(d)    Primary feedback
Ans: c
(a)     servomotors
(b)     induction relays
(c)    gear trains
Ans:
(a)     system stability
(b)     sensitivity
(c)    gain
(d)    effects of disturbing signals
Ans: a
(a)     Ramp input signal
(b)     Sinusoidal input signal
(c)    Unit impulse input signal
(d)    Exponentially decaying signal
Ans: c
(a)     The system is at rest and no energy is stored in any of its components
(b)     The system is working with zero stored energy
(c)     The system is working with zero reference signal
Ans: a
(a)    reduced velocity lag error
(b)    increased velocity lag error
(c)    increased speed of response
(d)    reduced time constant of the system
Ans: a
(a)    amplidyne set
(b)    resistance-capacitance parallel circuit
(c)    motor-generator set
Ans:
(a) capacitance
(b) reciprocal of capacitance
(c) current
(d) resistance
Ans: b
(a) Laplace Transform and Fourier Integral
(b) Laplace Transform
(c) Fourier Integral
(d) Either (b) or (c)
Ans: a
(a) smaller damping ratio
(b) larger damping ratio
(c) constant damping ratio
Ans: a
(a) acceleration
(b) velocity
(c) position
(d) all of the above
Ans: d
(a)    low frequencies
(b)     reduced values of open loop gain
(c)    increased values of open loop gain
Ans: b
(a) no pole
(b) net pole
(c) simple pole
(d) two poles
Ans: a
(a) no pole
(b) net pole
(c) simple pole
(d) two poles
Ans: c
(a) no net pole
(b) net pole
(c) simple pole
(d) two poles
Ans: d
(a)    constant, constant
(b)    constant, infinity
(c)    zero, constant
(d)    zero, zero
Ans: c
(a) parabolic
(b) ramp
(c) impulse
(d) step
Ans: b
(a) unity
(b) infinity
(c) zero
(d) 10
Ans: b
(a) not necessarily stable
(b) stable
(c) unstable
(d) always unstable
(e) any of the above
Ans: a
(a) Root locus
(b) Bode plot
(c) Nyquist plot
Ans: a
(a) Frequency response
(b) Absolute stability
(c) Relative stability
(d) Time response
Ans: c
(a)     Lead-compensation
(b)     Lag-compensation
(c)     Lead-lag compensation
Ans: b
(a)     Nyquist Criterion
(b)     Quasi linearization
(c)     Functional analysis
(d)     Phase-plane representation
Ans: a
(a)     Phase-lead
(b)     Phase-lag
(d)     Either (a) and (b)
Ans: a
(a)     is independent of frequency
(b)     is inverseh’proportional to frequency
(c)     increases linearly with frequency
(d)     decreases linearly with frequency
Ans: c
Also Read : Programmable Logic Controller Questions
(a)     Low-level oscillations
(b)     High-level oscillations
(c)     Conditional stability
(d)     Overdamping
Ans: a
(a)     Acceleration
(b)     Speed
(c)    Speed and acceleration
(d)    Displacement
Ans: b
(a)     Control valve
(b)     Potentiometer
(c)    Electro-pneumatic converter
(d)    Servomotor
Ans: b
(a)     The range of air output as measured variable varies from maximum to minimum
(b)     The range of measured variables from set value
(c)    The range of measured variables through which the air output chan¬ges from maximum to minimum
Ans: c
(a)    pressure signal to electric signal
(b)    pressure signal to position change
(c)    electric signal to pressure signal
(d)    position change to pressure signal
Ans: b
(a)     Differential bellows and straingauge
(b)     Selsyn
(c)     Strain gauge
(d)     Strain gauge and potentiometer
Ans: a
(a)     Microsyn
(b)     Selsyn
(c)    Synchro-resolver
(d)    Synchro-transformer
Ans: c
(a)    provide larger settling lime
(b)    delay the response
(c)    reduce steady state error
Ans: c
(a)     Root locus
(b)     Bode
(c)     Nyquist
(d)     Nichols
Ans: a
(a)     lag at all frequencies
(b)     lag at high frequencies and lead at low frequencies
(c)     lag at low frequencies and lead at high frequencies
Ans: c
(a)     Static friction
(b)     Backlash
(c)     Saturation
Ans: c
(a)     Bode-Nyquist stability methods
(b)     Transfer functions
(c)    Root locus design
(d)    State model representatives
Ans: d
(a)    at rest without any energy stored in it
(b)    working normally with reference input
(c)    working normally with zero reference input
(d)    at rest but stores energy
Ans: d
(a)     Induction relay
(b)     Thermocouple
(c)    LVDT
Ans: c
(a)    reduces damping
(b)    reduces the gain margin
(c)    increases input noise
(d)    increases error
Ans: c
(a)     oscillatory
(b)     critically damped
(c)     overdamped
(d)     underdamped
Ans: d
(a)     increases
(b)     minimizes
(c)     does not have any effect on
Ans: b
(6)     system gain
(c)     system stability and gain
Ans: b
(a)     Constant current
(b)     Constant voltage
(c)    Constant current as well as constant voltage
(d)    Constant current, constant voltage and constant power
Ans: d
(a)     Displacement
(b)     Velocity
(c)     Acceleration
Ans: d
(a)     Thermocouple
(b)     Potentiometer
(c)     Gear train
(d)     LVDT
Ans: a
(a)     Systems having complexities and non-linearities
(b)     Systems having stability problems
(c)    Systems having multiple input dis¬turbances
Ans: d
(a)     Alternating current
(b)     Direct current
(c)     A.C. voltage
(d)     D.C. voltage
Ans: d
(a)    universal motor
(b)    single phase induction motor
(c)    two phase induction motor
(d)    three phase induction motor
Ans: c
(a)     small bandwidth
(b)     negative time constant
(c)    large negative transfer function pole
Ans: c
(a)     The poles of the transfer function for a set of parameter values
(b)     The bandwidth of the system
(c)    The response of a system to a step input
(d)    The frequency response of a system
Ans: a
Answers available in the Quiz.
Instrumentation Quiz
Next Quizzes:
  • PLC Questions & Answers
  • Industrial Instrumentation Quiz
  • Quiz on Industrial Automation
  • Motors Quiz Questions
  • Control Valves Test
Components of Mass Spectrometer Questions & Answers
Pumps Quiz
150+ Measuring Instruments Questions and Answers
Flame Emission Photometers Questions & Answers
6 Comments
  • MOHAMMAD IRSHAD says:
    December 24, 2020 at 12:48 pm
    QN. Input of a controller what is write answer ?
    Servo signal or Error signal .
    NOTE:- Some where Servo and Some where Error.
    December 24, 2020 at 12:59 pm
    QN. The on-off controller is a –
    Discontinuous or Non-linear.
    NOTE:- Some where Discontinuous and somewhere Non-linear.
  • hossein ahmadi says:
    January 14, 2021 at 5:58 am
    i think question 4 answer should be (b)
    beacause in positive feedback
    • Muhammad Hamza says:
      September 29, 2021 at 4:52 pm
      yes, it has to be ( b), becauses error=vref-v(feedback). and +ve feedback means its less then reference input.So controller will increase the proportional gain in case of a PID.
    January 14, 2021 at 6:03 am
    hi sir
    please put some DCS questions with answer if it possible
    thanks very much
  • Ankul Kumar says:
    July 19, 2021 at 8:56 am
    Sir advance control system ke mcq bataye please
Performance Indices
Allen Bradley PLC Interview Questions and Answers
Instrument Technician Interview Questions and Answers
Electronics & Instrumentation Engineering Interview Questions For Freshers
Design Considerations for Higher Order Systems
Solution of State Equations
Measurement and Instrumentation Objective Questions – Part 1
Instrumentation Diagrams Multiple Choice Questions
X-Ray Fluorescence Spectrometry Questions and Answers
Industrial Automation Components
Industrial Automation Components Questions and Answers
Linear Approximation of the Non-Linear System MCQ
Time Response Analysis
Time Response of Second Order Systems – II
Instrumentation and Control Engineering Questions and Answers
Nonlinear Control Systems
Constructing Phase-Trajectories
Control Systems Stability and Algebraic Criteria
Concept of Stability in Control Systems
Analytical Measurement Multiple Choice Questions
Piping and Instrument Drawing
Difference between PFD and P&ID with Example
Thermowell Wake Frequency Calculation
Range Finders
Range Finders – Ultrasonic, Light, & Global Positioning Systems
Automatic Coffee Machine
Automatic Coffee Vending Machine – PLC Logic Programming
Difference Between LDR and Photodiode
Dip Tube Type Level System
Questions on Dip Tube Type Level System
Technical Evaluation for DCS and ESD - Distributed Control System
Technical Evaluation for DCS and ESD – Distributed Control System
Pressure Gauge Functional Testing
