  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: What is a Thin Film Deposition System? How do they work?
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Common > What is a Thin Film Deposition System? How do they work?
In this overview, we will discuss how thin film deposition system works and how each system completes deposition.
Last updated: February 9, 2022 9:21 pm
Common
Thin film deposition systems are an essential part of the manufacturing process. Products ranging from smartphones to solar panels would not exist without thin film deposition. While these systems have an integral role in materials science, their function and operation can be quite complicated.
What is a Thin Film Deposition System?How Does a Thin Film Deposition System Work?Magnetron SputteringE-beam EvaporationThermal EvaporationFinal Thoughts
There are various deposition techniques and even more configurations for thin film deposition systems. Each technique, some of which we cover below, has its own advantages for application.
In this overview, we will discuss how thin film deposition works and how each system completes deposition.
The thin-film deposition is a vital part of the electronics manufacturing process. These systems are, in part, responsible for the creation of diodes, microprocessors, and transistors.
A thin film deposition system is a tool for those working in materials science to deposit thin film coatings onto various materials.
Made from materials such as metals or oxides, thin film deposition systems place a thin layer of atoms onto substrates (usually silicon wafers) during the assembly process. These systems are essential to producing semiconductor and fibre lasers, consumer electronics, and many types of medical implants.
Depending on a user’s requirements, there are different systems and methods of thin film deposition. With a tool like Korvus Technology’s Hex series system, users have access to different deposition systems and tools. Thin film deposition applications are boundless, including:
  • Contact metallisation
  • EM sample preparation
  • Sputter deposition
  • Research of new coatings
The Hex series allows for state-of-the-art deposition and analysis focused on students’ needs with multiple, interchangeable configurations.
Different products and projects require different systems and techniques of thin film deposition.
Thin Film Deposition Systems
The thin-film deposition is either chemical deposition or physical deposition. Different thin film deposition systems have their own processes and applications.
Depending on the chemical reaction taking place, chemical deposition breaks down into additional categories, such as chemical vapour deposition and atomic layer deposition (ALD).
In a physical deposition process known as physical vapour deposition, which we discuss below, high-energy techniques vaporize solid materials in a vacuum for deposition onto a target material.
Two methods of PVD include sputtering and evaporation.
Magnetron sputtering is a plasma-based physical vapour deposition method. Plasma ions interact with the material and cause atoms to sputter, or spray, which creates the thin film on the substrate.
This is how thin film deposition works in most electrical or optical production settings.
E-beam Evaporation
E-beam evaporation uses a high-energy electron beam evaporator to evaporate the material. This vapour then creates a thin film for deposition. This method is commonly used for solar panels and glass.
Thermal Evaporation
Another evaporation method, thermal evaporation is a simple form of physical vapour deposition. This method creates a reaction through extreme heat to vaporize the target material.
Thermal evaporation is useful for creating OLEDS and thin-film transistors.
Final Thoughts
Many of the technologies we use every day would not exist without thin film deposition. Knowing these systems and how thin film deposition works is the first step towards choosing the most appropriate method for any project. Explore other blog posts to learn more about thin film deposition systems and the revolutionary HEX series by Korvus Technology.
Recommended Articles
What is Cloud Computing? Types of Cloud Services, Components
The Aghorn Hydrogen Sulfide Accident – H2S Gas
Circular Chart Recorder Calibration Procedure
7 Investments for Single Mothers
Control of Pneumatic Cylinder and Motor
208kSubscribersSubscribe
Recent Comments
Related Articles
How To Choose A Surge Protector?
Evolution of Air Compressors
Use Dumps to Ace Certbolt Microsoft AZ-204 Exam
different types of threads based on 4 standards
Different Types of Threads based on 4 Standards
Robot Anatomy
Robot – Anatomy, Configuration, Reference Frame, Characteristics
What is a Differential Mode Signal
Difference Between Differential Mode and Common Mode
Advantages and Disadvantages of Pneumatic Instruments
Circuit diagram of Liquid level measurment using Adruino C
Level Measurement and Control using Arduino C
More Articles
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Questions on Single Loop Controller
Single Loop Controller Questions
Pressure Regulators vs Pressure Control Valves
Pressure Control Valves vs Pressure Regulators
Thermocouple Types
Types of Thermocouples
DP transmitter Errors
DP Transmitter Calibration Errors
Process Air Compressor Overhauls Eliminated
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Air Consumption Calculation for Control Valves
Air Consumption Calculation for ON/OFF Valves
