Reading: What is a Tactile Sensor? Principle, Advantages, and Applications
Inst Tools > Blog > Common > What is a Tactile Sensor? Principle, Advantages, and Applications
A tactile sensor is also called a touch sensor. In this article, you will learn the principle, types, advantages, and applications.
Last updated: September 28, 2022 2:33 pm
R Jagan Mohan Rao
Common
A tactile sensor is also called a touch sensor. It is a type of device that captures and documents physical contact with an object. The touch sensor enables a device to detect the contact or close proximity of a general human user or operator.
Tactile Sensor PrincipleCapacitance Configuration of Tactile SensorDielectric Materials for the Capacitance SensorAdvantages of dielectric material (PDMS)Disadvantages of Dielectric Material (PDMS)Advantages of Capacitance Tactile sensorThe disadvantage of Capacitance Tactile sensorApplications of Capacitance Tactile sensor
A touch sensor works primarily when an object or individual comes into physical contact with the sensor. Touch sensors are sensitive to contact, pressure, or force. By their function, tactile sensors are broadly divided into vibration sensors, pressure, torque-force, temperature, etc.
The tactile sensors can be implemented in various configurations by using capacitive or resistive sensing technology.
Among several types of tactile sensors, the most popular are the three given below. Tactile sensors work on a variety of principles. Each type work on its own principle.
  • Capacitance – A change in capacitance is proportional to the pressure exerted on the two conductive plates with an elastomeric separator to ensure compliance.
  • Piezo-resistivity – It is based on the principle that its resistance varies with applied force. In other words, the piezoelectric materials can generate voltages when their deformation takes place.
  • Piezoelectricity – The change of resistance in the piezoelectric tough sensor depends on how large the voltage potential is generated when deforming the crystal lattice.
tactile sensor
Capacitive sensing configuration is a capacitive coupling-based technology. It can detect and measure anything that is conductive or has a dielectric difference with air.
Capacitive touch screens distinguish and detect the specific location of a contact based on electrical impulses from the human body, usually from the fingertips.
Therefore, capacitive touch screens can be used without applying any force to the screen surface. A capacitive sensor is a high-performance pressure sensor.
A capacitor is composed of two conductive plates with a dielectric material (insulating) sand witched between them.
The capacitance C is represented by
C = A * ε0 * (εr/d).
Where
A = Area of the separation of the two plates
ε0 = Permittivity of vacuum.
εr = Relative static dielectric permittivity.
d = Thickness of the dielectric.
Elastomeric materials such as polydimethylsiloxane (PDMS) and polyurethane (PU) are ideal for the dielectric layers.
PDMS is a silicone elastomer that is most widely used as a dielectric material for pressure sensors.
  • Commercial availability.
  • Non-toxicity.
  • Good reachability.
  • Biocompatibility.
  • Polydimethylsiloxane (PDMS) material has a low dielectric constant.
  • The capacitive response is low.
  • Sensitivity is also low.
  • Capacitive touch screen technology is popular and durable and is used in many applications.
  • Capacitive touch screens are very sharp and offer up to 90% transparency.
  • Due to their higher sharpness compared to resistive technology they are used in smartphones.
  • Good frequency response.
  • High spatial resolution.
  • Large dynamic range.
  • Susceptible to noise.
Tactile sensors appear in everyday life. One can find in
  • Elevator buttons.
  • Lamps that dim or brighten when we touch the base.
  • Robots.
  • Hardware for computer systems.
  • The security systems.
  • A common application for touch sensors is in touch screen devices of consumer electronics, mobile phones, and computing devices.
Apart from the above, there are also countless applications for tactile (touch) sensors that most people never know about.
The 5 Phases of Conducting Shutdown Maintenance
Most Commonly Used Raw Materials in a CNC Machine Shop
Hydraulic versus Pneumatic Systems
9 Best E-Book Apps for Students
Aluminum CNC Machining: A Complete Guide You Cannot Miss
Top US Universities that Offer Online Education
CNC Programming – Definition, Types, and Tips
Robot and Robotics – Laws, Components, Types, Advantages
Slip Rings in Robotics – Types, Applications, Advantages
Self-balancing Pneumatic Instrument Principles
Basic Principles of Solar Technology
Smart Transmitters Advanced Diagnostics
Moving Magnet Type Velocity Transducer
Introduction to Embedded Systems – Features, Types, Applications
Bracelet Scanner
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
How to Prevent Conveyor Problems
Common Conveyor Problems and How to Prevent Them
What is Linear Electric Motor
What is Linear Electric Motor?
How are Data Centers Cooled
How are Data Centers Cooled?
Working Principle of Water Chillers
HVAC Water Chillers Principle
Single layer PCB
Step-by-Step Guide: How PCBs are Manufactured from Start to Finish
Three Valve Manifold
3 Valve Manifold Operation
water treatment station
What is a Vent Filter? – Water Treatment Plant
Valve Glossary
Valve Terminology Glossary
What is a K Factor
Flow Meter K-factor and Calculations
Modbus in Industrial Networks
Alarm prioritization
What is Alarm Prioritization? – Types of Alarms
How to do Control Valve Sizing
How do you do control valve sizing in Layman’s terms?
Motor Losses and Efficiency Quiz
Components of Electrical Motor
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
Troubleshooting Fluid Systems Pressure Changes
