In this article, we shared the synchronous motor multiple choice questions and answers.
Synchronous Motors MCQ Questions
The below list provides all the multiple-choice questions related to the synchronous motors.
1. In case one phase of a three-phase synchronous motor has short-circuited the motor will
| A) | run with excessive vibrations |
| B) | run at 2/3 of synchronous speed |
| C) | take less than the rated load |
| D) | not start |
2. A synchronous motor that works on a leading power factor and does not drive a mechanical load is called as
| A) | none of these answers |
| B) | static condenser |
| C) | synchronous condenser |
| D) | condenser |
3. If in a synchronous motor, driving a given mechanical load and drawing current at a leading power factor from constant voltage supply its field excitation is increased, its power factor
| A) | will remain unchanged |
| B) | will become less |
| C) | will become more |
| D) | none of these answers |
4. Armature of a synchronous machine is kept fixed because
| A) | of difficulty of providing high voltage insulation on rotor |
| B) | of reducing number of slip rings on the rotor |
| C) | armature is associated with large power as compared to the field circuits |
| D) | all of these answers |
5. A synchronous motor is running with normal excitation. When the load is increased, the armature current drawn by it increases because
| A) | power factor is decreased |
| B) | none of these answers |
| C) | Er (net resultant voltage) in armature is increased |
| D) | Eb (back e.m.f.) becomes less than V (applied voltage) |
| E) | speed of the motor is reduced |
6. As the load is applied to a synchronous motor, the motor takes more armature current because
| A) | the rotor by shifting its phase backward causes motor to take more current |
| B) | the back e.m.f. decreases causing ah increase in motor current |
| C) | the rotor strengthens the rotating field causing more motor current |
| D) | the increased load has to take more current |
7. A synchronous motor working at leading power factor can be used as
| A) | noise generator |
| B) | phase advancer |
| C) | voltage booster |
| D) | mechanical synchronizer |
8. Slip rings are usually made of
| A) | copper or aluminium |
| B) | silver or gold |
| C) | brass or steel |
| D) | carbon or graphite |
9. The armature current of the synchronous motor has higher values for
| A) | low excitation only |
| B) | both high excitation only and low excitation only |
| C) | none of these answers |
| D) | high excitation only |
10. An important advantage of a synchronous motor over wound round induction motor is that
| B) | its speed is independent of supply frequency |
| C) | its power factor may be varied at will |
| D) | its speed may be controlled more easily |
11. In a synchronous motor, the magnitude of stator back e.m.f. Eb depends on
| A) | both the speed and rotor flux |
| B) | d.c. excitation only |
| C) | load on the motor |
| D) | speed of the motor |
12. In a synchronous motor, the maximum power developed depends on all of the following except
| A) | rotor excitation |
| B) | direction of rotation |
| C) | supply voltage |
| D) | maximum value of coupling angle |
13. If the field winding of an unloaded salient pole synchronous motor is open circuited, the motor will
| A) | run as induction motor |
| B) | stop |
| C) | function as static condenser |
| D) | burn with dense smoke |
14. The rotor copper losses, in a synchronous motor, are met by
| A) | supply lines |
| B) | d.c. source |
| C) | motor input |
| D) | armature input |
15. The shaft of synchronous motor is made of
| A) | alnico |
| B) | chrome steel |
| C) | mild steel |
| D) | stainless steel |
16. When a 3-phase synchronous generator is supplying a zero power factor lagging load, the armature field affects the main field in the following way
| A) | directly opposes it |
| B) | augments it directly |
| D) | cross-magnetises it |
17. If the field of a synchronous motor is under-excited, the power factor will be
| A) | unity |
| B) | lagging |
| C) | leading |
| D) | zero |
18. While starting a salient pole synchronous motor by induction motor action and connecting field discharge resistance across field, starting and accelerating torque is produced by
| A) | induction motor torque in damper winding |
| B) | reluctance motor torque due to saliency of the rotor |
| C) | eddy current and hysteresis’ torque in pole faces |
| D) | induction motor torque in field winding |
| E) | all of these answers |
19. A synchronous motor will always stop when
| A) | supply voltage fluctuates |
| B) | excitation winding gets disconnected |
| C) | supply voltage frequency changes |
| D) | load in motor varies |
20. Synchronous motor always runs at
| A) | more than synchronous speed |
| B) | less than synchronous speed |
| D) | the synchronous speed |
21. The construction of a synchronous motor resembles
| A) | a series motor |
| B) | an induction motor |
| C) | an alternator |
| D) | a rotary converter |
22. Hunting in a synchronous motor takes place
| A) | when supply voltage fluctuates |
| B) | when load varies |
| C) | motor is under loaded |
| D) | when power factor is unity |
23. A synchronous motor can operate at
| A) | unity power factor only |
| B) | lagging power factor only |
| C) | leading power factor only |
| D) | lagging, leading and unity power factors |
24. Which of the following motors will be used in electric clocks?
| A) | D.C. shunt motor |
| B) | D.C. series motor |
| C) | A.C. induction motor |
| D) | A.C. synchronous motor |
25. In a synchronous motor, the damping winding is generally used to
| B) | reduce the eddy currents |
| C) | provide starting torque only |
| D) | prevent hunting and provide the starting torque |
| E) | reduce noise level |
26. The size of a synchronous motor decreases with the increase in
| A) | all of these answers |
| B) | flux density |
| C) | speed |
| D) | horse power rating |
27. The synchronous motor is not inherently self-starting because
| A) | a rotating magnetic field does not have enough poles |
| B) | the rotating magnetic field is produced by only 50 Hz frequency currents |
| C) | the force required to accelerate the rotor to the synchronous speed in an instant is absent |
| D) | the starting device to accelerate the rotor to near synchronous speed is absent |
28. A synchronous motor develops maximum power when the load angle is
| A) | 60° |
| B) | 45° |
| C) | 90° |
| D) | 120° |
29. Which of the following methods is used to start a synchronous motor ?
| A) | Damper winding |
| B) | Resistance starter in the armature circuit |
| C) | Damper winding in conjunction with star-delta starter |
| D) | Star-delta starter |
30. When the rotor speed, in a synchronous machine, becomes more than the synchronous speed during hunting, the damper bars develop
| A) | synchronous motor torque |
| C) | inductor motor torque |
| D) | d.c. motor toque |
| E) | induction generator torque |
31. For V-curves for a synchronous motor the graph is drawn between
| A) | power factor and field current |
| B) | armature current and power factor |
| C) | field current and armature current |
| D) | terminal voltage and load factor |
32. If in a synchronous motor, driving mechanical load and drawing current at lagging power factor from constant voltage supply, its field excitation is increased, then its power factor
| B) | become less |
| C) | remain constant |
| D) | become more |
33. A synchronous motor can be used as a synchronous capacitor when it is
| A) | over-loaded |
| B) | over-excited |
| C) | under-loaded |
| D) | under-excited |
34. The percentage slip in case of a synchronous motor is
| A) | 1 |
| B) | 0.01 |
| C) | zero |
| D) | 0.005 |
35. The operating speed of a synchronous motor can be changed to new fixed value by
| A) | changing the supply voltage |
| B) | using brakes |
| C) | changing the load |
| D) | changing frequency |
36. Stability of a synchronous machine
| A) | decreases with increase in its excitation |
| B) | remains unaffected with increase in excitation |
| C) | increases with increase in its excitation |
| D) | any of these answers |
37. The speed regulation of a synchronous motor is always
| A) | zero |
| B) | positive |
| C) | 0.005 |
| D) | 0.01 |
38. When the stator windings are connected in such a fashion that the number of poles are made half, the speed of the rotor of a synchronous motor
| A) | increases to two times the original value |
| B) | decreases to half the original value |
| C) | remains same as the original value |
| D) | tends to becomes zero |
39. In a 3-phase synchronous motor, the negative phase sequence exists when the motor is
| B) | over-loaded |
| C) | under-loaded |
| D) | supplied with unbalanced voltage |
40. The magnitude of field flux in a 3-phase synchronous motor
| A) | varies with the load |
| B) | varies with power factor |
| C) | varies with speed |
| D) | remains constant at all loads |
41. Due to which of the following reasons a synchronous motor fails to pull into synchronism after applying D.C. field current ?
| A) | Low short circuit ratio |
| B) | High core losses |
| C) | High field current |
| D) | Low field current |
42. In a synchronous motor it the back e.m.f. generated in the armature at no load is approximately equal to the applied voltage, then
| A) | the torque generated is maximum |
| B) | the excitation is said to be zero percent |
| C) | the motor is said to be fully loaded |
| D) | the excitation is said to be hundred percent |
43. The induced e.m.f. in a synchronous motor working on leading power factor will be
| A) | less than the supply voltage |
| C) | more than the supply voltage |
| D) | equal to the supply voltage |
44. Which of the following resistances can be measured by conducting insulation resistance test on a synchronous motor?
| A) | Phase to phase winding resistance |
| B) | Rotor winding to earthed shaft |
| C) | All of these answers |
| D) | Stator winding to earthed frame |
45. A three-phase synchronous motor will have
| A) | one slip-ring |
| B) | three slip-rings |
| C) | two slip-rings |
| D) | no slip-rings |
46. A synchronous motor can be started by
| A) | pony motor |
| B) | any of these answers |
| C) | providing damper winding |
| D) | D.C. compound motor |
47. The oscillations in a synchronous motor can be damped out by
| A) | oscillations cannot be damped |
| B) | providing damper bars in the rotor pole faces |
| C) | maintaining constant excitation |
| D) | running the motor on leading power factors |
48. An over-excited synchronous motor is used for
| A) | power factor corrections |
| B) | low torque loads |
| C) | fluctuating loads |
| D) | variable speed loads |
49. When V is the supply voltage and R is the rotor resistance per phase, the mechanical power developed by the synchronous motor will be proportional to
| A) | ​​V/R2 |
| B) | ​​R/V2 |
| C) | ​​V/R |
| D) | ​​V2/R |
50. When load on an over-excited or underexcited synchronous motor is increased, rate of change of its armature current as compared with that of power factor is
| A) | equal |
| B) | more |
| C) | less |
| D) | twice |
51. The coupling angle or load angle of synchronous motor is defined as the angle between the
| A) | rotor and the stator poles of the same polarity |
| C) | rotor and the stator poles of opposite polarity |
| D) | rotor and stator teeth |
52. Which of the following losses, in a synchronous motor, does not vary with load?
| A) | Windage loss |
| B) | Copper losses |
| C) | Any of these answers |
| D) | None of these answers |
53. In which of the following motors the stator and rotor magnetic field rotate at the same speed?
| A) | Reluctance motor |
| B) | Universal motor |
| C) | Induction motor |
| D) | Synchronous motor |
54. If excitation of a synchronous motor running with a constant load is decreased from its normal value, ignoring effects of armature reaction, it leads to
| A) | increase in both armature current and power factor which is lagging |
| B) | increase in both armature current and power factor angle |
| C) | increase in torque angle but decrease in back e.m.f. |
| D) | increase in back e.m.f. but decrease in armature current |
55. In a synchronous motor, the magnitude of stator back e.m.f. Eb depends on
| C) | d.c. excitation only |
| D) | load on the motor |
56. In a synchronous motor, the armature current has large values for
| B) | both high and low excitation |
| C) | high excitation only |
57. At no-load, the armature current in a synchronous motor
| A) | leads the applied voltage by 90° |
| B) | lags the applied voltage by 90° |
| D) | is zero |
| E) | is in phase with the applied voltage |
58. In a 3-phase, 4-pole, 50 Hz synchronous motor, the frequency, pole number and load torque all are halved. The motor speed will be
| B) | 1500 r.p.m. |
| C) | 3000 r.p.m. |
| D) | 750 r.p.m. |
59. The efficiency of a properly designed synchronous motor will usually fall in range
| A) | 75 to 80% |
| B) | 99 to 99.5% |
| C) | 85 to 95% |
| D) | 60 to 70% |
60. The maximum value of torque that a synchronous motor can develop without losing its synchronism is known as
| A) | synchronising torque |
| B) | slip torque |
| C) | breaking torque |
| D) | pull-out torque |
61. A synchronous machine with large air gap has
| A) | a higher synchronizing power which makes the Machine less sensitive to load variations |
| B) | a higher value of stability limit |
| C) | a small value of inherent regulation |
62. To limit the operating temperature an electrical machine should have proper
| A) | speed |
| B) | power factor |
| C) | current rating |
| D) | voltage rating |
63. A 3-phase synchronous motor is running clockwise. If the direction of its field current is reversed
| A) | the winding of the motor will burn |
| B) | the motor will run in the reverse direction |
| C) | the motor continue to run in the same direction |
| D) | the motor will stop |
64. If one-phase of a 3-phase synchronous motor is short-circuited, motor
| A) | will not come upto speed |
| B) | will refuse to start |
| C) | will fail to pull into step |
| D) | will overheat in spots |
65. Under which of the following conditions is hunting of synchronous motor is likely to occur?
| A) | Small and constant load |
| B) | Over-loading for long periods |
| C) | Periodic variation of load |
| D) | Over-excitation |
66. A synchronous motor running with normal excitation adjusts to load increases essentially by increase in
| A) | armature current |
| B) | power factor |
| C) | torque angle |
| D) | back e.m.f. |
67. The speed of the synchronous motor
| A) | increases with increase in load |
| B) | always remains constant |
| C) | decreases as load increases |
| D) | varies with power factor |
68. The torque angle, in a synchronous motor, is the angle between
| A) | the supply voltage and the back e.m.f. |
| B) | magnetising current and back e.m.f. |
| D) | the rotating stator flux and rotor poles |
69. Exciters of synchronous machines are
| A) | any of these answers |
| B) | d.c. shunt machines |
| C) | d.c. compound machines |
| D) | d.c. series machines |
70. Slip-rings in a synchronous motor carry
| A) | alternating current |
| B) | direct current |
| C) | no current |
71. The working of a synchronous motor is similar to
| B) | turbine |
| C) | gear train arrangement |
| D) | transmission of mechancial power by shaft |
| E) | distribution transformer |
72. A synchronous motor installed at the receiving end substation operates with such an excitation that it takes power at lagging power factor.​
Now if the applied voltage of the synchronous motor goes down, the power factor of the synchronous motor will
| A) | go down |
| B) | improve |
| D) | remain same |
73. The net armature voltage of a synchronous motor is equal to the
| A) | vector difference of Eb and V |
| B) | arithmetic sum of Eb and V |
| C) | vector sum of Eb and V |
| D) | arithmetic difference of Eb and V |
74. A synchronous motor has a better power factor as compared to that of an equivalent induction motor. This is mainly because
| A) | synchronous motor has large airgap |
| B) | synchronous motor has no slip |
| C) | stator supply is not required to produce magnetic field |
| D) | mechanical load on the rotor remains constant |
75. In a synchronous motor which loss varies with load?
| A) | Windage loss |
| B) | Bearing friction loss |
| C) | Core loss |
| D) | Copper loss |
76. If the load (or torque) angle of a 4-pole synchronous motor is 6° electrical, its value in mechanical degrees is
| A) | 4 |
| B) | 2 |
| C) | 3 |
| D) | 6 |
77. The standard full-load power factor ratings for synchronous motors are
| A) | unity or 0.8 leading |
| B) | unity or zero |
| C) | unity or 0.8 lagging |
| D) | zero or 0.8 leading |
78. Synchronsizing power of a synchronous machine is
| B) | inversely proportional to the synchronous reactance |
| C) | direcly proportional to the synchronous reactance |
| D) | equal to the synchronous reactance |
79. Power factor of a synchronous motor is unity when
| A) | the armature current is zero |
| C) | the armature current is minimum |
| D) | the armature current is maximum |
80. Which of the following losses is not dissipated by tile stator core surface in a synchronous motor?
| A) | Iron losses in the stator |
| B) | None of these answers |
| C) | Windage losses |
| D) | Copper losses in the slot portion of the conductors |
| E) | Eddy current losses in the conductors |
81. Higher the applied ____voltage will be the stator flux and____ will be the pull-in torque
| A) | lower, greater |
| B) | greater, lower |
| C) | lower, lower |
| D) | greater, greater |
82. The angle between the rotating stator flux and rotor poles is called____ angle
| A) | torque |
| B) | synchronizing |
| C) | power factor |
| D) | obtuse |
83. The power factor of a synchronous motor is better than that of an induction motor because
| A) | stator supply is relieved of responsibility of producing magnetic field |
| B) | synchronous motor runs at synchronous speed |
| C) | mechanical load on the motor can be adjusted |
| D) | synchronous motor has large air gap |
84. The minimum armature current of the synchronous motor corresponds to operation at
| A) | zero power factor leading |
| B) | 0.707 power factor lagging |
| C) | 0.707 power factor leading |
| D) | unity power factor |
85. Which of the following motors is nonself starting?
| A) | synchronous motor |
| C) | Wound round induction motor |
| D) | Squirrel cage induction motor |
86. Change of D.C. excitation of a synchronous motor changes
| B) | applied voltage of the motor |
| C) | any of these answers |
| D) | power factor of power drawn by the motor |
| E) | motor speed |
87. The mechanical displacement of the rotor with respect to the stator, in the polyphase multipolar synchronous motor running at full load, is of the order of
| A) | five degrees |
| B) | ten degrees |
| C) | two degrees |
| D) | zero degree |
88. Dust and dirt accumulation on motor winding will result in
| A) | increased core losses |
| B) | shorting of coils |
| C) | eddy current flow |
| D) | a rise in winding temperature |
89. The maximum power developed in a synchronous motor occurs at a coupling angle of
| A) | 180° |
| B) | 90° |
| C) | 30° |
| D) | 60° |
90. In a synchronous motor, damper windings are provided on
| B) | pole faces |
| C) | stator frame |
| D) | rotor shaft |
91. A synchronous motor can develop synchronous torque
| A) | when under loaded |
| B) | while over-excited |
| C) | only at synchronous speed |
| D) | below or above synchronous speed |
92. If the field circuit of an unloaded salient pole synchronous motor gets suddenly open-circuited, then
| A) | it continues to run at the same speed |
| B) | it runs at a slower speed |
| C) | the motor stops |
| D) | it runs at a very high speed |
93. The power developed by a synchronous motor will be maximum when the load angle is
| A) | 120° |
| B) | zero |
| C) | 90° |
| D) | 45° |
94. For power factor correction, synchronous motors operate at
| A) | no-load and under-excited fields |
| B) | no-load and greatly over-excited fields |
| C) | normal load with minimum excitation |
| D) | normal load with zero excitation |
95. If the synchronous motor, properly synchronized to the supply is running on no load and is having negligible loss then
| A) | the stator current will be very small |
| C) | the stator current will be very high |
| D) | the back e.m.f. will be more than the supply voltage |
| E) | the stator current will be zero |
96. The duration of a sudden short-circuit test on a synchronous motor is usually about
| A) | one minute |
| C) | one second |
| D) | one hour |
97. In which of the following motors the stator and rotor fields rotate simultaneously?
| A) | Induction motor |
| B) | Synchronous motor |
| C) | Reluctance motor |
| D) | D.C. motor |
| E) | Universal motor |
98. The speed of a synchronous motor
| A) | decreases as the load decreases |
| B) | increases as the load increases |
| C) | always remains constant |
99. Synchronous motors are
| A) | essentially self-starting |
| C) | not-self starting |
| D) | self-starting |
100. The angle between the rotor poles and stator poles, in a synchronous motor, is known as
| A) | power factor angle |
| B) | synchronizing angle |
| C) | angle of retardation |
| D) | torque angle |
101. Synchronous motors are generally not self-starting because
| A) | the direction of instantaneous torque reverses after half cycle |
| B) | startes cannot be used on these machines |
| C) | starting winding is not provided on the machines |
| D) | the direction of rotation is not fixed |
102. A synchronous motor can be made self starting by providing
| A) | damper winding on rotor poles |
| B) | damper winding on stator |
| C) | damper winding on stator as well as rotor poles |
103. By which of the following methods the constant speed of a synchronous motor can be changed to new fixed value?
| A) | By changing the load. |
| B) | By changing the applied voltage |
| C) | By changing the supply frequency |
| D) | By interchanging any two phases |
104. The maximum speed variation in a 3- phase synchronous motor is
| A) | 2 percent |
| B) | 4 percent |
| C) | zero |
| D) | 10 percent |
| E) | 6 percent |
105. The back e.m.f. of a synchronous motor depends on
| A) | speed |
| B) | load |
| C) | load angle |
106. The armature current of the synchronous motor
| A) | has large values for low excitation only |
| B) | has large values for low and high excitation |
| D) | has large values for high excitation only |
107. Hunting in a synchronous motor cannot be due to
| A) | variable supply voltage |
| B) | windage friction |
| C) | variable load |
| D) | variable frequency |
108. While starting a synchronous motor by induction motor action, the field winding is usually
| A) | connected to D.C. supply |
| C) | short-circuited by low resistance |
| D) | kept open-circuited |
109. The ratio of starting torque to running torque in a synchronous motor is
| A) | two |
| B) | infinity |
| C) | one |
| D) | zero |
110. The back e.m.f. in the stator of a synchronous motor depends on
| B) | rotor speed |
| C) | flux density |
| D) | number of poles |
| E) | rotor excitation |
111. The maximum constant load torque under which a synchronous motor will pull into synchronism at rated rotor supply voltage and frequency is known as
| A) | pull-out torque |
| B) | pull-up torque |
| C) | pull-in torque |
112. A synchronous motor connected to infinite bus-bars has at constant full load, 100% excitation and unity power factor.​
On changing the excitation only, the armature current will have
| A) | no change of power factor |
| B) | leading power factor with under-excitiltion |
| C) | lagging power factor with over-excitation |
| D) | leading power factor with over-excitation |
113. When V is the applied voltage, then the breakdown torque of a synchronous motor varies as
| A) | ​​V |
| B) | ​​V3/2 |
| C) | ​​V2 |
| D) | ​​1/V |
114. A synchronous motor is running on a load with normal excitation. Now if the load on the motor is increased
| A) | power factor will decrease and armature current will increase |
| B) | power factor will increase but armature current will decrease |
| C) | power factor as well as armature current will decrease |
| D) | power factor as well as armature current will increase |
115. A rotory converter can also be run as a
| A) | d.c. series motor |
| B) | synchronous motor |
| C) | d.c. compound motor |
| D) | d.c. shunt motor |
| E) | induction motor |
116. In a synchronous motor, the forced vibrations will be maximum when driving
| A) | a centrifugal blower |
| B) | a reciprocating air compressor |
| E) | a centrifugal pump |
117. When the voltage applied to a synchronous motor is increased, which of the following will reduce?
| A) | Pull in torque |
| C) | Both Stator flux and Pull in torque |
| D) | Stator flux |
118. When the field of a synchronous motor is under-excited, the power factor will be
| A) | unity |
| B) | lagging |
| C) | zero |
| D) | leading |
119. Mostly, synchronous motors are of
| A) | smooth cylindrical type machines |
| B) | induction type machines |
| C) | salient pole type machines |
| D) | alternator type machines |
120. In a synchronous motor, V-curves represent the relation between
| A) | field current and power factor |
| B) | power factor and speed |
| C) | field current and speed |
| D) | armature current and field current |
121. The maximum torque which a synchronous motor will develop at rest for any angular position of the rotor, at rated stator supply voltage and frequency, is known as
| A) | synchronous torque |
| B) | reluctance torque |
| C) | locked-rotor torque |
| D) | pull up torque |
122. In a synchronous motor, the breakdown torque is
| B) | inversely proportional to applied voltage |
| C) | directly proportional to applied voltage |
| D) | directly proportional to the square of the applied voltage |
123. A pony motor is basically a
| A) | small induction motor |
| B) | D.C. shunt motor |
| C) | D.C. series motor |
| D) | double winding A.C./D.C. motor |
124. The effect of increasing the load on a synchronous motor running with normal excitation is to
| A) | decrease both armature current and power factor |
| B) | increase both its armature current and power factor |
| C) | decrease armature current but increase power factor |
| D) | increase armature current but decrease power factor |
Click Here for Answers
Next Quiz:
- PLC Questions & Answers
- Industrial Instrumentation Quiz
- Quiz on Industrial Automation
- Motors Quiz Questions
- Control Valves Test
