Reading: Strain Gauge Pressure Sensor Principle
Inst Tools > Blog > Pressure Measurement > Strain Gauge Pressure Sensor Principle
Last updated: March 12, 2019 7:33 pm
Strain Gauge Pressure Sensor Principle :
When a closed container is subjected to the appilied pressure, it is strained (that is, its dimension changes).
Measurement of this strain with a secondary transducer like a strain gauge ( metallic conductor) becomes a measure of the appilied pressure.
That is, if strain gauges are attached to the container subjected to the applied pressure, the strain guages also will change in dimension depending on the expansion or contraction of the container.
The change in dimension of the strain guage will make its resistance to change. This change in resistance of the strain gauge becomes a measure of pressure appilied to the container (elastic container or cell).
There are two types of strain gauge pressure cells namely:
  1. flattened tube pressure Sensor
  2. Cylindrical type pressure Sensor
Flattened tube Pressure Sensor
The main parts of the arrangement are as follows:
  • An elastic tube which is flat and pinched at its two end as shown in diagram.
  • Two strain gauges are placed on this elastic tube: one is on the top and other is at the bottom of this elastic tube.
  • One end of the elastic tube is open to receive the applied pressure and its other end is closed.
Operation
The pressure to be measured is applied to the open of the tube. Due to pressure, the tube tends to round off, that is, the dimension changes (strained).
As the strain gauge are mounted on the tube, the dimension of the strain gauges also change proportional to the change in dimension of the tube, causing a resistance change of the strain gauges.
The change in dimension of the tube is proportional to the applied pressure. Hence the measurement of the resistance change of the strain gauges becomes a measure of the applied pressure when calibrated.
Cylindrical Type Pressure Sensor
The main parts of this arrangement are as follows:
  • A cylindrical tube with hexagonal step at its center. This hexagonal step helps fixing this device on to place where the pressure is to be measured.
  • The bottom portion of this cylindrical tube is threaded at its external and is open to receive the pressure to be measured.
  • The top portion of this cylindrical tube is closed and has a cap screwed to it.
  • On the periphery of the top portion of the cylindrical tube are placed two sensing resistance strain gauges.
  • On the cap (unstrained location) are placed two temperature compensating strain gauges.
Operation
The pressure to be measured is applied to the open end of the cylindrical tube. Due to the pressure, the cylindrical tube is strained, that is its dimension changes.
As the strain gauges are mounted on the cylindrical tube, the dimension of the sensing strain gauges also change proportional to the change in dimension of the cylindrical tube, causing a resistance changes of the strain gauges.
The change in dimension of the cylindrical tube is proportional to applied pressure.
Hence the measurement of the resistance change of the sensing strain gauges becomes a measure of the appilied pressure when calibrated.
Applications of Strain Gauge Pressure Sensors
  • The flattened tube pressure cell is used for low pressure measurement.
  • The cylindrical type pressure cell is used for medium and high pressure measurement.
Gage and Absolute Pressure Transmitters Principle
Double Block and Bleed Valves Opening or Closing Sequence
Inductance Type Pressure Transducers Principle
Bellows
Scaling Sensor Output to Engineering Units
Basics of Differential Pressure Transmitters
  • Ciga says:
    November 5, 2018 at 1:45 pm
    Please may you upload the diagram if you can, for the flattened tube pressure sensor. Thank you in advance.
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
Differential Pressure Transmitter with 5 Way Manifold Valve
Pressure Gauge Pulsation Damping
Pressure Switch Calibration Procedure
Pressure Transmitter Troubleshooting Tips
Pressure and Temperature Gauges
Inclined-limb Manometer Principle
What is Static Pressure Limit in DP Transmitter ?
Gauge Cock
Pressure Gauge Cocks
Linear Variable Displacement Transducer (LVDT)
What is LVDT ?
Differential Pressure Sensor for Filtration Monitoring
Pressure Transmitter Calibration Procedure
piping for a Different pressure flow transmitter
Impulse Piping standards for Field instruments
Direct Mounting of Diaphragm Seals Level Transmitter
What are the Mounting Techniques of Diaphragm Seals?
What are Pressure Sensing Lines
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Sample Raw DataSheet for Pressure Calibration
PLC Ladder Logic for Lube Oil Pump Motor
operational-amplifiers-questions-answers
Operational Amplifiers Questions & Answers
PLC programming for clothes washing machine automation
LS Electric PLC Program Example: Clothes Washing System
Flash Vessel All Level Instruments Stopped Working
Ammonia Flash Vessel All Level Instruments Stopped Working
Power Outlet
How does Electrical Power Outlet Work?
LED Projects for Engineering Students
K-Map Simplification Objective Questions
