Reading: Solenoid-controlled Valve Problem
Inst Tools > Blog > Practical Questions > Solenoid-controlled Valve Problem
Solenoid-controlled valve refuses to move when the operator pushes the switch. The control valve remains in fully-closed position.
Last updated: February 6, 2022 6:17 pm
Practical Questions
Suppose this solenoid-controlled valve refuses to move when the operator pushes the switch. Whether the switch is pressed or unpressed, the control valve remains in the fully-closed (down) position:
Solenoid-controlled Valve ProblemSolenoid-controlled Valve Solution
Another technician has already measured voltage between terminals H1 and H4 on the transformer, and 0 volts between terminals D and X1, in both pushbutton switch positions. At that point, he gave up and left the system for you to troubleshoot.
Identify the below-mentioned faults are possible to happen or not.
  • Fuse F3 blown (failed open)
  • Solenoid stuck in “energized” position
  • Solenoid stuck in “de-energized” position
  • Solenoid coil failed open
  • Solenoid coil failed shorted
  • Silencer plugged
  • Vent cap plugged
  • Wire open between terminals A and E
  • Wire open between terminals C and H
  • Wire open between terminals K and B
  • Valve V1 shut
  • Valve V2 shut
Identify the likelihood of each specified fault for this system. Consider each fault one at a time (i.e. no coincidental faults), determining whether or not each fault could independently account for all measurements and symptoms in this system.
Finally, identify the next diagnostic test or measurement you would make on this system.
Explain how the result(s) of this next test or measurement help further identify the location and/or nature of the fault.
A plugged vent on the valve actuator, while in theory capable of limiting the control valve’s upward motion, would not prevent any motion at all from occurring when full pressure is applied to the bottom of the diaphragm. This is why “Vent cap plugged” is checked as impossible rather than possible for this scenario.
A good “next test” would be to crack the fitting at port “C” of the solenoid valve. If there is pressure, it means the problem must lie past the solenoid (e.g. valve V1 shut, or a problem in the process control valve).
If there is no pressure at that point, either the solenoid valve is stuck in the “energized” position or there is a lack of supply pressure to the solenoid.
FaultsPossibleImpossible
Fuse F3 blown (failed open) ✓
Solenoid stuck in “energized” position✓
Solenoid stuck in “de-energized” position ✓
Solenoid coil failed open ✓
Solenoid coil failed shorted ✓
Silencer plugged ✓
Vent cap plugged ✓
Wire open between terminals A and E ✓
Wire open between terminals C and H ✓
Wire open between terminals K and B ✓
Valve V1 shut✓
Valve V2 shut✓
  • Spool Valve Symbols
  • PLC Switch Actuation Status
  • Identify Solenoid Valves Status
  • Calculate the Transmitter Values
  • Pressure Actuated Lifts Questions
  • Flow Reversed through Control Valve
Credits: Tony R. Kuphaldt
Pneumatic Moment-balance Differential Pressure Transmitter
How Overload Heaters used to Automatically Shut the Motor OFF ?
Simulate Different Values for Pressure Instrument Under Test
Programmable Logic Controller (PLC) Questions and Answers – 14
Programmable Logic Controller (PLC) Questions and Answers – 8
PLC Programming Question & Answer
  • Todd says:
    April 15, 2022 at 10:13 am
    Coil shorted open
Purge Type Level Transmitter Questions
Questions on Pneumatic Control Loop
Analyze the Relay Circuit and Find the Status ?
Solenoid Valves Practical Problems
Surface-mounted Water Pump
Programmable Logic Controller (PLC) Questions and Answers – 15
Differential Pressure Measurement across Baghouse
A Question on Density Gauge
10 Questions on Reforming Furnace Control System
Steam Eductor Question
Practical Process Control System Questions & Answers – 4
PLC program to control a water pump
PLC Program to Control a Water Pump
PLC program pushbutton switches
float-type level switch control a pump
Allen-Bradley PLC Program
Inter Discipline Check (IDC)
What is Inter Discipline Check (IDC)?
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
Artificial intelligence in supply chain management
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Difference between Current Transformer and Potential Transformer
Oxygen Measurement using Tunable Diode Laser System
Tunable Diode Laser Analyzer Working Principle
Limit Switch Questions and Answers
Top 50 Limit Switch Questions and Answers
