Reading: Servo Tank Gauges Working Principle
Inst Tools > Blog > Level Measurement > Servo Tank Gauges Working Principle
Last updated: December 31, 2017 3:13 pm
Level Measurement
3 Min Read
Tank gauging is the generic name given to the measurement of liquids (product) in bulk storage tanks with the aim of quantifying how much product is in the tank, “gauging the contents of a tank”. Today, the oil & gas industry uses the static measurement of the tank contents to account for product stored and product moved into and out of the tank.
There are many instruments and systems available that can provide the combination of measurements that will allow an accurate quantity assessment and, hence, good inventory management. In Practice, we use both Radar and Servo Level Transmitters for Tank Gauges.
Servo Tank Gauges Principle
The Servo tank gauging system is based on the principle of displacement measurement. A small displacer is accurately positioned in the liquid medium using a servo motor. The displacer is suspended on a measuring wire that is wound onto a finely grooved drum housing within the instrument.
Servo Tank Gauge Level Principle
The drum is driven via coupling magnets, which are completely separated by the drum housing. Outer magnets are connected to the wire drum whilst the inner magnets are connected to the drive motor. As the magnets turn, the magnetic attraction causes the outer magnets to turn as well, resulting in turning the entire drum assembly. The weight of the displacer on the wire creates a torque on the outer magnets generating the change of magnetic flux. These changes generated between the drum assembly are detected by a unique electromagnetic transducer on the inner magnet. The drive motor is actuated to balance the voltage generated by the variations of magnetic flux to equal the reference voltage defined by the operating command.
Servo Level Transmitter Working Principle
When the displacer is lowered and touches the liquid, the weight of the displacer is reduced because of the buoyant force of the liquid. As a result, the torque in the magnetic coupling is changed and this change is measured usng Hall sensor, which are temperature compensated. The signal, an indication of the position of the displacer, is sent to the motor control circuit. As the liquid level rises and falls, the position of the displacer is adjusted by the drive motor. The rotation of the wire drum is precisely evaluated to determine the level value, which is accurate to an outstanding +/‐ 0.7 mm.
Servo Tank Gauge System Operation
Non Contact RADAR Level Transmitter Principle, Limitations, Design, Installation and Calibration
Cable Float Level Switch Working Principle
Non Contacting Radar Level Transmitter Animation
Magnetic Float Level Switch Working Animation
Magnetic Level Gauge Working Principle Animation
DP Level Transmitter Auto Calibration
  • MINESHKUMAR says:
    April 27, 2018 at 3:07 pm
    ERS(ELECTRONIC REMOTE SENSOR ) TYPE LEVEL TRANSMITTER, IF ANY BODY HAVE PLEASE SEND ME DETAIL. NOW PROBLEM IS HART NOT CONNECT. DISPLAY SHOW DEVICE NOT FOUND. WE CHECK OUR SIDE IS CLEAR BUT THEN ALSO STILL PROBLEM STAND THEIR.
    ANY BODY HAS SOLUTION LET ME INFORM [email protected]
Difference between Transparent Level Gauge and Reflex Level Gauge
Siemens Pressure Transmitter with Remote Seals Calculations
Conductive Level Switch Principle
How to Find LRV and URV of Closed Tank DP Level Transmitter
Radar and Ultrasonic Level Transmitter Practical Problems Troubleshooting
Closed Tank Level Measurement using DP Transmitters
Density Measurement using Remote Seal Transmitters
Remote Seal Differential Pressure Transmitters Principle
Capacitance Level Switch Working Principle
Closed Tank Non-Zero-Based Direct Mount Application
Open and Closed Tank Level Calculations
DP Transmitters Level Measurement Principle
DP Transmitters Level Measurement Principle Video
Level Indicators Working Principle
Magnetic Float Level Sensor Principle
Magnetic Float Level Transmitter Working Principle
Level Transmitter Design
Level Transmitter and Level Gauge Design Tips
Two pressure transmitters
Pressure Transmitters Leg Compensation Technique
Memory Devices Objective Questions – Part 3
Comparison of Accuracy and Precision
Difference between Accuracy and Precision
stepper motors Animation
Fundamentals of DC Motor Animation
Thermocouple Software compensation
Useful Trigonometry Website for Students Math Help
The Impact of Knowledge Management Platforms on Business Operations
Star-Delta PLC programming with 1 button
How to Program a Star-Delta System using 1 Button in PLC?
PLC Program to Drain Same Products from Two Tanks
Stability in Frequency Domain
