Reading: SCADA & Telemetry Systems
Inst Tools > Blog > Control Systems > SCADA & Telemetry Systems
Last updated: May 9, 2019 5:40 pm
Control Systems
A similar control system architecture to Direct Digital Control (DDC) – assigning a single microprocessor to the task of managing multiple control functions, with digital communication between the microprocessor units – is used for the management of systems which are by their very nature spread over wide geographical regions. Such systems are generally referred to as SCADA, which is an acronym standing for Supervisory Control And Data Acquisition.
The typical SCADA system consists of multiple Remote Terminal Unit (RTU) devices connected to process transmitters and final control elements, implementing basic control functions such as motor start/stop and PID loop control.
These RTU devices communicate digitally to a Master Terminal Unit (MTU) device at a central location where human operators may monitor the process and issue commands.
SCADA RTU TELEMETRY
A photograph of an RTU “rack” operating at a large electric power substation is shown here:
RTU
Some RTU hardware, such as the substation monitoring system shown above, is custom manufactured for the application.
Other RTU hardware is more general in purpose, intended for the monitoring and control of natural gas and oil production wells, but applicable to other applications as well.
The Fisher ROC 800 – shown in the photograph below – is an example of an RTU designed to operate with a minimum of electrical power, so that a single solar panel and battery will be sufficient for year-round operation in remote environments.
The particular unit shown is installed in a natural gas metering station, where is monitors gas pressure, temperature, and flow rate, and also controls the injection of an “odorizing” compound into the gas to give it a bad smell:
RTU System
Standard programmable logic controllers (PLCs) are ideal candidates for use as RTU devices. Modern PLCs have all the I/O, networking, and control algorithm capability necessary to function as remote terminal units.
Commercially available Human-Machine Interface (HMI) software allowing personal computers to display PLC variable values potentially turns every PC into a Master Terminal Unit (MTU) where operators can view process variables, change setpoints, and issue other commands for controlling the process.
A photograph of such HMI software used to monitor a SCADA system for a set of natural gas compressors is shown here:
HMI Screen
Another photograph of a similar system used to monitor and control drinking water reservoirs for a city is shown here:
HMI Graphics
A concept closely related to SCADA is that of telemetry, the word literally meaning “distance measuring” (i.e. measuring something over a distance).
The acronym SCADA, by containing the word “control,” implies two-way communication (measurement and control) between the master location and the remote location. In applications where the flow of information is strictly one-way (simplex) from the remote location to the master location, “telemetry” is a more apt description.
Telemetry systems find wide application in scientific research. Seismographs, river and stream flowmeters, weather stations, and other remotely-located measurement instruments connected (usually by radio links) to some centralized data collection center are all examples of telemetry.
Any industrial measurement (-only) application spanning a large distance could likewise be classified as a telemetry system, although you will sometimes find the term “SCADA” applied even when the communication is simplex in nature.
Difference between DCS & PLC Systems
What is Safety Control System ?
Centralized vs Decentralized Automation Systems
Heuristic PID Tuning Procedure
What is Process Automation? – Simple Automation Example
Selector Control Functions
Loop Calibrator to Simulate a 4-20 mA Signal
Tuning a Temperature Process Control Loop
Vendor View of Supplying Industrial Process Control & Safety Systems
How-to do Security of SCADA Systems?
What is Electromagnetic Noise Interference?
Functional Safety Terms in Industrial Automation
Functional Safety Terminology in Industrial Automation
How to Train Your Maintenance Team for Industrial Automation Systems
Feedforward Control
Feedforward Vs Feedback Control
Nuisance Alarms
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Basic Process Control System
Commissioning Checklist for Industrial Automation System
Commissioning Checklists for Industrial Automation Systems
Features of PID Controller
Features of PID Controller actions
two-way communication between PLC systems
Transferring Data Across PLC Systems – TSEND_C and TRCV_C
Pump and Mixer Operations Example PLC Timer-Based Control
Pump and Mixer Operations Example: PLC Timer-Based Control
Difference between RCCB and RCBO
Perfume filling system PLC program
CX Programmer Example: Perfume Mixing and Filling System
Fire and Gas system Audible and Visual Alarms
Learn PLC Programming
Basics of Ladder Diagram in PLC Programming
Material Certificate versus Positive Material Identification (PMI)
AC Circuits Multiple Choice Questions
