Reading: Why RTD installed after the Orifice Plate ?
Inst Tools > Blog > Temperature Measurement > Why RTD installed after the Orifice Plate ?
Last updated: December 29, 2018 10:41 am
2 Comments
1 Min Read
The location of the RTD (thermowell), positioned downstream of the orifice plate so the turbulence it generates will not create additional turbulence at the orifice plate. The American Gas Association (AGA) allows for upstream placement of the thermowell, but only if located at least three feet upstream of a flow conditioner.
A major reason for this is von K´arm´an vortex shedding caused by the gas having to flow around the width of the thermowell. The “street” of vortices shed by the thermowell will cause serious pressure fluctuations at the orifice plate unless mitigated by a flow conditioner, or by locating the thermowell downstream so that the vortices do not reach the orifice.
Also Read : Thermowell Case-Study
Thermowell Installation near Critical Equipment
General Specification of Thermowell
Temperature Error of 2-Wire, 3-Wire & 4-Wire RTD
Filled-bulb Temperature Sensors
Calibration of Temperature Sensor with Indicator
RTD Calculator : Calculate Temperature from Resistance
2 Comments
  • Joseph says:
    May 24, 2018 at 5:24 pm
    Please I need an installation hook-up procedure for interface shutdown signals between the Robershall panel and Safety System in control room. We need to install pressure switch and solenoid valve . it is to be configured in such a way that if the there fire in gas plant ESD will be initiated to shutdown the Flowstation and verse versa
  • islom says:
    November 10, 2018 at 10:20 pm
    which conditions can we use fromRTDs? Please give me full informations about this!!!!!!!
Components of RTD
Peltier Effect Theory
RTD Calibration Procedure
Difference between PT100, PT1000, Nickel RTD and Balco RTD
Difference Between RTD, Thermocouple and Thermistor
How to calculate the tolerance of a RTD sensor
Thermocouple Questions and Answers
Thermostat – Types, Working Principle, Advantages, Applications
RTD Questions & Answers
RTD Questions and Answers
Bimetallic strip thermostat
Mechanical Temperature Measuring Sensors
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
thermocouple types
What is a Thermocouple ?
Thermocouples Green Rot Effect
RTD with Thermowell
Temperature Sensor Accessories
How to calculate Thermocouple Temperature by measuring the output millivoltage
Insulation of Thermowell
Facts on Thermowell Insulation Thickness
RF and RTJ Flange Installed Gasket
Flange Joint Errors shutdowns root cause analyzed and eliminated
How do Electric Motors Work
All About Electric Motors and Universal Motors
S84 - IEC 61511 Standard for Safety Instrumented Systems
S84 / IEC 61511 Standard for Safety Instrumented Systems
Electrical & Electronics Measurements Objective Questions – Set 3
Strain gage load cells
Load Cell Healthiness Checks
Voltmeter Calibration
Calibration Procedure of Voltmeter and Ammeter
How a Diode Works Animation
How a Gate Works ?
Complementary Split Range Control
What is Complementary Split Range Control (CSRC)?
