Reading: How to Read and Understand an Electrical Single Line Diagram?
Inst Tools > Blog > Electrical Basics > How to Read and Understand an Electrical Single Line Diagram?
Learn how to read and understand an electrical single line diagram (SLD) with an example circuit.
Last updated: September 28, 2022 2:37 pm
R Jagan Mohan Rao
Electrical Basics
2 Comments
3 Min Read
An electrical single line diagram abbreviated as SLD is also referred to as a one-line diagram. It is a simplified drawing of the whole system or a portion of the power system that shows the electrical placement of all major equipment.
How Single Line Diagrams are useful?How it is helpful to various users?Example of Single Line Diagram (SLD)
A single line diagram is a simplified explanation for representing a three-phase power system.
The required information is added to give the engineer or a system operator the full picture of the electrical system. It also includes the system protection schemes.
  • They are very useful for planning maintenance activities.
  • Helps in rerouting power after a fault.
  • Useful for switching orders to change system configurations.
  • Helps to view the relationships between smaller sections of the power system and the overall system.
Line crew: Single line diagram drawing tells the worker at a glance where the disconnecting means is located. It shows how all alternate sources may be isolated.
System operators: Use the single-line diagrams to identify the electrical placement of breakers, switches, transformers, regulators, and so on in substations that may indicate alarms. The restoration of power can be possible by identifying.
Electrical engineers: Use single line diagrams to understand system behavior and to make changes to the power system to improve performance.
End-users: Use the single-line diagrams to identify their electrical equipment, circuits, and protection apparatus.
Familiarity:
Familiarity with electrical symbols helps one to understand the overall system connections.
The above single line diagram shows right from generation to distribution stage. From the above one-line drawing, one can easily understand that the line shown from power generation, number breakers, HT/LT transformer, power control Center (PCC), then Motor control center, finally to feeders.
The red box represents the circuit breakers. The blue circle overlapped represents the transformer from HT to LT power. Greyline represents three-phase power in a single conductor.
The single line diagram is divided into two portions, from generation to substation are shown in a dotted grey line box. Another box represents the power control center, motor control centers and connecting them with feeders.
Current transformers are shown in two places with indicators.
A neutral ground resistor (NGR) is shown connected to a neutral line to provide protection to the generator against earth faults.
Circuit breakers are shown at various places for isolation of power for the transformer, PCC, and MCC.
  • Types of MCB
  • Circuit Breaker Animation
  • Oil Circuit Breakers
  • How to Select a Fuse?
  • Residual Current Circuit Breaker
Things to Know When Measuring Voltage
Stepper Motor Working Principle
Worldwide Voltage & Frequency Values
Electrical Power Grid Automation
Why CT Secondary Should Never Be Kept Open?
2 Comments
  • Thomas ohide says:
    February 19, 2021 at 12:37 pm
    Send more about motor control wiring diagram
  • Tegegn Tadessse says:
    February 3, 2022 at 10:07 pm
    Its educating ways for md, so for thanks.
What is a Lightning Arrester? How does it work?
Why is IGBT used in VFD?
What is a Line Choke or Reactor in a VFD?
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Download Electrical Enclosure Book
Formula of AMP, KW, KVA, HP for AC and DC Voltages
Various Control Methods in Servo Motor Drives
Understanding Protection Relays
Understanding Protection Relays – 50, 50N, 51, 51N
Corona Discharge
Corona Discharge in Power Transmission Lines
VFD Pros and Cons - Variable Frequency Drives
VFD Pros and Cons – Variable Frequency Drives
Rotary Encoder
Rotary Encoder Interview Questions and Answers
V1000 Family Programming Simulator Tool
MCCB (Molded Case Circuit Breaker)
Industrial Circuit Breakers – Most Common Types – Principle
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
Pressure Transmitter Troubleshooting Tips
Electrical Machines MCQ Series 1
Intrinsic Safe Calculation
PLC Program for Automatic Parameter initialization
PLC Program for Automatic Parameter Initialization When Power UP
Moving Iron Vane Meter Movement
SIS Fault Tolerance
SIS Hardware Fault Tolerance – Methods to Overcome HFT issues
double-pumps unit unloading valves
What is an Unloading Valve? – Types, Principle
Blowdown Valve (BDV) and Shutdown Valve (SDV)
Difference between Blowdown Valve (BDV) and Shutdown Valve (SDV) ?
