Programmable Logic Controller (PLC) Questions
Suppose we have a Siemens S7-200 PLC connected to a pair of pushbutton switches and light bulbs as shown in this illustration:
Examine the following relay ladder logic (RLL) program for this Siemens PLC, determining the statuses of the two lamps provided neither switch is pressed by a human operator:
Furthermore, determine the necessary switch actuation statuses (i.e. pressed versus unpressed) to turn lamp Z on.
Answer :
Output Q0.1 will activate to energize lamp Y, but the other output (and lamp) will remain off.
To energize lamp Z, you must release (unpress) both switches.
Share Your Answer / Comments
Credits : Tony R. Kuphaldt – under CC BY 1.0
For More PLC Questions : CLICK HERE
I think that there is a mistake in your answer:
If neither switches are pressed, it means both of theme are conducting (they are normally closed switches) it means I.11 and I.07 are both at state “1”, but in the program in the first rung, the contacts are negated it means that Q0.1 will be de-energized = lamp Y is “off”.
I agree with azetou.
