Reading: Process Control High Level Alarm Fault Analysis
Inst Tools > Blog > Control Systems > Process Control High Level Alarm Fault Analysis
Last updated: October 4, 2019 7:23 pm
Control Systems Practical Questions Process
1 Min Read
An operator reports a high level alarm (LAH-12) displayed at the control room for the last 13 hours of operation, in this sour water stripping tower unit (where sulfide-laden water is “stripped” of sulfur compounds by the addition of hot steam).
Over that time period, the sightglass (level gauge LG-11) has shown the liquid level inside vessel C-406 drifting between 2 feet 5 inches and 2 feet 8 inches:
Process High Level Alarm Example
Click on the Image to Zoom
Identify the likelihood of each specified fault in this process.
Consider each fault one at a time (i.e. no coincidental faults), determining whether or not each fault could independently account for all measurements and symptoms in this process.
Level Transmitter Fault Analysis
Answer :
The below table shows the possible and  Impossible cases for the process high level.
Share Your Answers via Comments
Articles You May Like :
Failsafe Wiring Practices
Difference between PLC & DCS
Process Control Loops
Shutdown Philosophy
Fire & Gas system Alarm
Modbus Function Command Formats
PLC Practice Questions
Purge Type Level Transmitter Questions
10 Questions on Reforming Furnace Control System
Moving Pressure Sensing Level Transmitter from Top to Bottom
Single Loop Controller Questions
Steady-State Process Gain
Determine the Status of Lamps and Relays in the Circuit ?
Proportional Controller Principle
Ziegler-Nichols Open-Loop Method
Questions on Level Switches
Industrial Automation and Control Systems (IACS)
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Integral controller eliminates offset error
How Integral Controller Reduces offset error ?
PID Controller Functionality
PID Controller Loop Tuning Tips
Capacitive Field Effects on Conductors-4
Capacitive Coupling Effects
What is Timeout in Communication Protocols
What is Timeout in Communication Protocols?
Process Control Automation PLC Quiz
Question on Remote Seal with Capillary Tubing Transmitter
Proportional Control Theory
Proportional-only Offset
Closed Tank Level Measurement using DP Transmitter
Cat and Mouse type Level Indicator
Cyclic Interrupts TIA Portal
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
Corona Discharge
Corona Discharge in Power Transmission Lines
Advantages & Disadvantages of Variable Speed Drives
Relay Principle
Advantages & Disadvantages Electromagnetic Relays
Type D Chopper Objective Questions
Difference between Intrinsically Safe and Flameproof Equipment ?
How to Remove Control Valve Stem Packing Procedure
The Replacement Procedure for Control Valve Stem Packing
