Reading: Pressure Gauge Accessories Questions and Answers
Inst Tools > Blog > Instrumentation MCQ > Pressure Gauge Accessories Questions and Answers
Pressure gauge accessories questions and answers such as snubbers, siphons, pulsation dampeners, adapters, fittings, isolators, etc.
Last updated: July 25, 2024 4:21 am
Instrumentation MCQ Pressure Measurement
7 Min Read
Learn about the various pressure gauge accessories questions and answers such as Snubbers, syphons, gauge cocks, overpressure protectors, pulsation dampeners, adapters, fittings, diaphragm seals, pressure gauge isolators, and cooling elements.
Pressure Gauge Accessories QuestionsWhat is the primary function of a snubber in a pressure gauge?What is the purpose of a pigtail siphon in pressure gauge installations?Why is a gauge saver used in a pressure gauge setup?What is the main role of a gauge cock in a pressure gauge assembly?How does a pulsation dampener benefit a pressure gauge?What does a diaphragm seal do in a pressure gauge system?What is the function of a magnetic mount in relation to a pressure gauge?Why is a needle valve important in a pressure gauge setup?How does a swivel adaptor benefit pressure gauge installations?How does an overpressure protector safeguard pressure gauges?What is a gauge isolator primarily used for?What function does a protective cover serve for a pressure gauge?Why is a ball valve used in pressure gauge setups?How does a U siphon protect a pressure gauge?What is the primary role of a gauge union in pressure gauge installations?What is a panel mounting kit designed to do?What is the primary function of a pulsation dampener in a pressure gauge system?What role does a adaptor play in pressure gauge installations?Why is a pigtail siphon important in steam applications?What is the use of a cock in pressure gauge systems?
This video provides detailed explanations of pressure gauge accessories questions for instrumentation engineers.
Pressure Gauge Accessories - Instrument and Control Quiz
Question 1
A. To seal connections
B. To reduce pressure spikes
C. To prevent backflow
D. To filter contaminants
Show the Answer
Question 2
A. To cool down the process fluid
B. To prevent direct contact with hot vapors
C. To prevent freezing
D. To absorb vibrations
Show the Answer
Question 3
A. To protect the gauge from overpressure
B. To measure differential pressure
C. To dampen pulsations
D. To isolate the gauge
Show the Answer
Question 4
A. To stabilize pressure
B. To filter the process media
C. To measure flow rate
D. To provide a shut-off mechanism
Show the Answer
Question 5
A. It filters out contaminants
B. It stabilizes pressure readings
C. It prevents overpressure
D. It absorbs vibrations
Show the Answer
Question 6
A. It reduces vibrations
B. It filters process media
C. It isolates the gauge from the process fluid
D. It measures high pressures
Show the Answer
Question 7
A. To absorb shocks
C. To stabilize pressure
D. To provide easy attachment and detachment
Show the Answer
Question 8
A. To protect against overpressure
B. To regulate and control flow precisely
C. To measure temperature
Show the Answer
Question 9
A. It allows easy orientation adjustment of the gauge
B. It measures flow rate
C. It filters the process media
D. It reduces vibrations
Show the Answer
Question 10
A. By filtering contaminants
B. By isolating the gauge from the process media
C. By sealing off the gauge during overpressure
D. By absorbing shocks
Show the Answer
Question 11
A. To measure differential pressure
B. To reduce vibrations
C. To regulate flow precisely
D. To isolate the gauge for maintenance
Show the Answer
Question 12
A. To protect the gauge from physical damage
B. To stabilize the pressure readings
C. To enhance readability
D. To measure high pressures
Show the Answer
Question 13
A. To filter out particulates
B. To measure fluid levels
C. To control the flow with quick operation
D. To dampen pressure fluctuations
Show the Answer
Question 14
A. By absorbing vibrations
B. By filtering contaminants
C. By cooling down steam before it reaches the gauge
D. By preventing backflow
Show the Answer
Question 15
A. To stabilize pressure readings
C. To filter process fluids
D. To allow for easy disconnection and reconnection
Show the Answer
Question 16
A. To filter out contaminants
B. To measure high pressures
C. To secure gauges onto control panels neatly
D. To absorb shocks and vibrations
Show the Answer
Question 17
A. To reduce vibration
B. To smooth out pressure fluctuations
C. To prevent overpressure
Show the Answer
Question 18
A. To measure temperature
B. To dampen pressure spikes
C. To filter out contaminants
D. To connect gauges of different thread sizes
Show the Answer
Question 19
A. To prevent gauge from overheating
B. To stabilize flow rate
C. To measure differential pressure
D. To filter out impurities
Show the Answer
Question 20
A. To absorb vibrations
C. To filter contaminants
D. To act as a shut-off valve
Show the Answer
  • Pressure Gauge Pulsation Damping
  • Temperature Sensor Accessories
  • Pressure Gauge with Block and Bleed Valve
  • Pressure Gauge Calibration Procedure
  • Prepare Pressure Gauge Datasheet
Pressure Gauge Calibration according to Standard DKD-R-6-1
Pressure Transmitter Manifolds
Advantages of Pneumatic Systems in the Automotive Industry
GATE Instrumentation Questions and Answers
When to use a Diaphragm Seal?
Basics of Differential Pressure Transmitters
Pressure and Temperature Gauges
What is Sensor Trim and Output Trim in Smart Transmitter?
Fluidic Systems Objective Questions
Bellows Pressure Sensors Working Principle Animation
Inductive Transducers Objective Questions
Data Transmission Objective Questions
Pressure Gauges Zero Adjustment
Effects of Capillary Tubing on Pressure Measurement
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
Submersible Pressure Transmitter
What is a Submersible Pressure Transmitter? Principle, Advantages
Filtering and Dynamic Compensation Objective Questions
Fiber Optic Measurement Techniques
Fiber Optic Measurement Multiple Choice Questions (MCQ)
How to Measure Pressure in Inches of Water Column
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Measurement of Phase Angle Objective Questions
Induction Motor Operation
Induction Motor Over and Under Voltage Problems
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
How does the IIoT work - Industrial Internet of Things
How does the IIoT work? – Industrial Internet of Things
Difference between Smart Transmitter and Ordinary Transmitter
Fieldbus Control
Fieldbus Control
Lightning Arrester Basics and Terminology
Difference between Motion Controller and PLC
