Reading: PLC Switch Actuation Status
Inst Tools > Blog > Practical Questions > PLC Switch Actuation Status
Determine the necessary PLC switch actuation status (i.e. low versus high process stimulus) to turn the yellow lamp on.
Last updated: March 11, 2021 11:45 pm
Practical Questions
1 Min Read
Suppose we have an Allen-Bradley MicroLogix 1000 controller connected to three process switches as shown in this illustration:
Determine the necessary switch actuation statuses (i.e. low versus high process stimulus) to turn the blue lamp on, given the following program running in the PLC:
Allen-Bradley MicroLogix 1000 controller ladder logic
Next, determine the necessary switch actuation statuses (i.e. low versus high process stimulus) to turn the yellow lamp on, given the same PLC program.
Answer
High temperature and low flow and high level are required to energize the blue lamp.
Low temperature and high flow and high level are required to energize the yellow lamp.
Share Your Answer / Comments
Credits : by Tony R. Kuphaldt – under CC BY 1.0
Instrument Salesperson Question
Programmable Logic Controller (PLC) Questions and Answers – 8
Moving Pressure Sensing Level Transmitter from Top to Bottom
Practical Level Sensors Questions and Answers
Re-calibrate the Foxboro DP Pneumatic Transmitter
Questions on Pneumatic Control Loop
Practical Process Control System Questions & Answers – 9
Programmable Logic Controller (PLC) Questions and Answers – 7
Pressure Level Transmitter Problems
Calculate the appropriate millivoltage values of a Thermocouple
Solenoid Valves Questions & Answers – 4
Questions on Level Switches
Simulate Different Values for Pressure Instrument Under Test
Calculate voltage across RTD
Resistance Temperature Detector (RTD) Questions – 2
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
Inclined Water Manometer
How much Pressure is applied to Inclined Water Manometer?
thermocouple Transmitter Formula
Calculate Process Temperature using a Thermocouple
Thermocouple Questions
Thermocouple Terminal block Questions
Identify the Pressure Gauge Error
Suppose the lamp refuses to light up
Indentify Faults in Simple Lamp Circuit including Failed Wires
Feedback Pneumatic Load cell Objective Questions
Electrical Heating Objective Questions and Answers
Problem on PLC, HMI, VFD, and Motor Circuit
Simatic S7 PLC Backup Steps
How to take Backup from Siemens S7-300 PLC?
Shaper Machine Hydraulic Circuit Design
Hydraulic Shaper Machine – Components, Circuit, Principle
Ultrasonic Flow Meters Working Principle
Instrumentation and Control Engineering Questions and Answers
Compression load cell Principle
Types of Load Cells
