Reading: PLC Programming for Baking with Auto and Manual Modes
Inst Tools > Blog > PLC Tutorials > PLC Programming for Baking with Auto and Manual Modes
Master PLC programming for baking machines in automatic and manual modes with temperature control, time settings, and start/stop functions.
Last updated: October 21, 2024 10:04 pm
7 Min Read
This article discusses the PLC program for controlling the Bread Oven machine in Automatic and Manual mode using the Schneider PLC. In Manual or Auto mode, the temperature parameters of the Oven must be Set before the baking process is carried out. This Bread Oven has 2 buttons that can be used to Start the baking process and Stop the baking process. In Auto Mode, the Baking time parameter must be Set before the Baking process is carried out. In Auto Mode, the Alarm indicator will be Active when the baking process is complete.
PLC Programming for BakingAddressingProgramming
This PLC program uses 3 buttons and 1 Selector Switch, the TURN_ON (I0.0) button is used to turn ON the system, the TURN_OFF (I0.1) button is used to turn OFF the system. The WARM_ON_BUTTON (I0.3) button is used to Start the Baking Process, and the WARM_OFF_BUTTON (I0.4) button is used to Stop the Baking Process.
Selector Switch MODE (I0.2) is used to select the system to Run in Auto or Manual mode.
Before the Baking Process is carried out, the Oven temperature Set Value in the memory word SV_TEMPERATURE (MW0) must be Set.
Manual Mode
The Baking process is carried out when the WARM_ON_BUTTON (I0.3) button is Pressed. The OUT_OVEN (Q0.0) Output will be ON and if the WARM_OFF_BUTTON (I0.4) button is Pressed, the OUT_OVEN (Q0.0) output will be OFF.
Auto Mode
In Auto mode, the “Preset Value” of the timer TIMER_AUTO (TM0) can be Set, and the time unit used is minutes.
The system will Run if the WARM_ON_BUTTON (I0.3) button is Pressed. The output OUT_OVEN (Q0.0) will be ON and the Baking Process is carried out.
The OUT_OVEN (Q0.0) output will be OFF if the WARM_OFF_BUTTON (I0.4) button is Pressed or when the TIMER_AUTO (TM0) timer has finished counting.
The OUT_ALARM (Q0.1) output will be ON when the TIMER_AUTO (TM0) timer has finished counting.
Food Machinery PLC Controlled Tunnel Oven
Addressing
CommentInput (I)Output (Q)Memory WordMemory BitsTimer
TURN_ONI0.0
TURN_OFFI0.1
MODEI0.2
WARM_ON_BUTTONI0.3
WARM_OFF_BUTTONI0.4
OUT_OVEN Q0.0
OUT_ALARM Q0.1
SV_TEMPERATURE  MW0
SYSTEM_ON   M0
MANUAL   M1
AUTO   M2
IR_OVEN_MANUAL   M3
IR_OVEN_AUTO   M4
IR_TIMER   M5
TIMER_AUTO    TM0
Programming
RUNG 0 (SYSTEM ON)
In this Rung, the memory bit SYSTEM_ON (M0) will be in the HIGH state when the TURN_ON (I0.0) button is Pressed. The memory bit SYSTEM_ON (M0) remains in the HIGH state even though the TURN_ON (I0.0) button has been Released, because it uses the SET Coil Instruction.
RUNG 1 (SYSTEM OFF)
If the TURN_OFF (I0.1) button is Pressed, the memory bit SYSTEM_ON (M0) will become LOW state. Because it uses the RESET Coil Instruction.
RUNG 2 (AUTO MANUAL MODE)
In this rung, the output memory bit MANUAL (M1) will be in the HIGH state if the NO contact of memory bit SYSTEM_ON (M0) in the HIGH state and the value in memory word SV_TEMPERATURE (MW0) is not equal to zero “0”.
When the NO contact of the Selector Switch MODE (I0.2) in the HIGH state, then the output memory bit AUTO (M2) in the HIGH state. The memory bit MANUAL (M1) will be in the LOW state.
RUNG 3 (MANUAL ON)
In this Rung, when the NO contact of memory bit MANUAL (M1) in the HIGH state and the WARM_ON_BUTTON (I0.3) button is Pressed, the memory bit IR_OVEN_MANUAL (M3) will be in the HIGH state. The memory bit MANUAL (M1) remains in the HIGH state even though the WARM_ON_BUTTON (I0.3) button has been Released, because it uses the SET Coil Instruction.
PLC Temperature Control in Bread Ovens
RUNG 4 (MANUAL OFF)
In this Rung, because it uses the RESET Coil Instruction, the memory bit IR_OVEN_MANUAL (M3) will be in the LOW state if the WARM_OFF_BUTTON (I0.4) button is Pressed.
RUNG 5 (AUTO MODE)
In this Rung, when the NO contact of memory bit AUTO (M2) in the HIGH state and the WARM_ON_BUTTON (I0.3) button is Pressed, the output memory bit IR_OVEN_AUTO (M4) will be in the HIGH state and the TIMER_AUTO (TM0) timer Starts counting up to 2 minutes.
When the TIMER_AUTO (TM0) timer has finished counting, the output memory bit IR_TIMER (M5) will be in the HIGH state.
The output memory bit IR_OVEN_AUTO (M4) will be in the LOW state if the WARM_OFF_BUTTON (I0.4) button is Pressed.
PLC Control for Baking Machines Logic
RUNG 6 (OUT OVEN)
In this Rung, if the NO contact of memory bit IR_OVEN_MANUAL (M3) or IR_OVEN_AUTO (M4) in the HIGH state, then the Output OUT_OVEN (Q0.0) will be ON.
In Auto mode, if the NC contact of memory bit IR_TIMER (M5) in HIGH state, then the Output OUT_OVEN (Q0.0) will be OFF.
RUNG 7 (OUT ALARM)
In this Rung, the output OUT_OVEN (Q0.0) will be OFF and OUT_ALARM (Q0.1) will be ON if the NO contact of memory bit IR_TIMER (M5) in the HIGH state.
  • Railway Crossing Gate Control PLC Program
  • PLC Product Painting with Weighing System
  • Studio 5000 PLC Program for Digital Alarms
  • Vacuum Cleaner Programming in Omron PLC
  • XG5000 PLC Logic for Automatic Exhaust Fan
Programmable Logic Controller Maintenance Check Points
Create User-Defined Data Types and Function Blocks in Studio 5000
STAR DELTA Programming using PLC Controller
Siemens HMI Training – Using UDTs with Faceplates
One Shot Rising and One Shot Falling Instructions in PLC
PLC Ladder Logic for Start-up Control of Boilers
Functions of SCADA
PLC Logic Functions
What are FIFO and LIFO Sequences in PLC?
Data Handling Instructions in PLC Programming
Difference between Motion Controller and PLC
What is Resources Tab in the Siemens PLC?
Siemens PLC Interview Questions & Answers
Siemens PLC Interview Questions and Answers
Connection between PLC and Contactor
PLC Program for Traffic Light Sequence using Functional Blocks
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
What is PLC Redundancy
What is PLC Redundancy?
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
Level Transmitter configuration in PLC
Scaling with Parameters (SCP) Instruction in PLC
Difference Between Remote IO and Distributed IO Systems
Solenoid Valve Terminology
How a Solenoid valve works
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Electronic Amplifiers Objective Questions
P&ID Guidelines for Pumps
Filled-bulb Temperature Measurement
Filled-bulb Temperature Sensors
Formula for Linear mA to Square root mA conversion
