Write a PLC Timers Program for the following plc example.
PLC Timers
Construct a PLC timing circuit that will output (using output O:2/0) a 0.5 second pulse every two seconds (i.e. on for 0.5s then off for 2s).
If a switch (using I:1/0) is closed and a 1 second pulse every two seconds if the switch is open.
Ladder Logic
You can share a detailed explanation of the above PLC ladder logic in the comments section.
Author: Dr. D. J. Jackson
- What is Ladder Diagram?
- PLC Math instructions
- Ladder Diagram in PLC
- PLC Data Comparison
- PLC Program Examples
Please explain it sir. I cannot understand clear.
And thanks for documentation sir.
Explained I want to know very good and pratique PLC PROGRAMMING
