Reading: PLC Logic Example on Multiple Switches and Motors
Inst Tools > Blog > PLC Tutorials > PLC Logic Example on Multiple Switches and Motors
Learn the PLC logic example on multiple switches and motors with the ladder diagram.
Last updated: March 20, 2024 7:38 am
PLC Logic ExamplePLC Logic VideoInputs of PLCOutputs of PLCMultiple Switches and Motors Ladder LogicProgram ExplainedPLC Simulation Results
This PLC logic example is prepared for the engineering students to learn and practice the ladder logic. The design of the same PLC program for industrial usage will be different.
PLC Logic Example
Problem Statement:
There is a use of four toggle switches to control four motors.
If Switch 1 is ON, then Motor I will be ON.
If Switch 2 is ON, then Motor I and Motor II will be ON.
If Switch 3 is ON, then Motor I, Motor II, and Motor III will be ON.
If Switch 4 is ON, then Motor I, Motor II, Motor III, and Motor IV will be ON.
PLC Logic Video
We explained the above PLC example logic in the below video. Follow the step-by-step procedure prepared for the beginners.
Example of Multi-Switch to Multi-Motor Program in PLC Programming
Inputs of PLC
The list of the digital inputs for this PLC logic is mentioned below.
Switch 1: I0.0
Switch 2: I0.1
Switch 3: I0.2
Switch 4: I0.3
Outputs of PLC
The required digital outputs are listed below.
Motor 1: Q0.0
Motor 2: Q0.1
Motor 3: Q0.2
Motor 4: Q0.3
Here is the PLC logic for the given problem statement.
Program Explained
For this example, we used Schneider PLC software for programming.
In the above PLC program, we have used Normal Open Contact for Switch 1 (I0.0), Switch 2 (I0.1), Switch 3 (I0.2) and Switch 4 (I0.3)
Switch 1, Switch 2, Switch 3, and Switch 4 are connected in parallel for Motor 1, thus implementing OR logic gate.
For Motor 2, inputs switch 2, switch 3, and switch 4 are connected in parallel, thus implementing OR logic gate.
Switch 3 and switch 4 are implementing OR logic gate i.e., connected in parallel for Motor 3.
Only Switch 4 is connected to Motor 4.
For Motor 1 to be ON, either Switch 1 or Switch 2 or Switch 3 or Switch 4 should be ON.
To turn ON Motor 2, either Switch 2 or Switch 3 or Switch 4 should be ON.
When Switch 3 or Switch 4 is ON, then Motor 3 will turn ON.
Motor 4 will turn ON when Switch 4 is turned ON.
Next, we will see the PLC simulation results with different input switch ON and OFF combinations.
When Switch 1 is ON
PLC Ladder Logic for Four Motors drive Simultaneously
When the toggle switch 1 is turned ON, the current flows through it (here we are using the term “Current” in case of an electrical circuit, so here you can assume it as “Current” or simply call it as “Signal”).
As a result, Motor 1 gets ON. Other motors will remain OFF because Switch 1 is not connected to them.
When Switch 2 is ON
Multiple Switches and Motors Ladder Diagram
The current will flow through switch 2 when it is turned ON that will turn ON Motor 1 and Motor 2. It is so because switch 2 is connected to Motor 1 and Motor 2 only.
When Switch 3 is ON
How can we make the ladder logic for a toggle switch
When Switch 3 is turned ON, the current flows through it that will turn ON three motors i.e., Motor 1, Motor 2 and Motor 3. The input switch 3 is connected to these outputs only. Motor 4 will remain OFF as Switch 3 is not connected to it.
When Switch 4 is ON
PLC Fundamentals and Examples
Switch 4 will turn ON all the motors when turned ON. Switch 4 is connected to all the motors, when turned ON, Motor 2, Motor 2, Motor 3 and Motor 4 will turn ON.
  • Siemens Control System (TDC)
  • Electrical Diagram into PLC Program
  • How to Choose a PLC for a Project?
  • PLC Example to Control LEDs Via Switches
  • Siemens Communication using I-Device
RSLogix5000 PLC Program Backup procedure
DC Injection Braking in VFD
What is SCADA ? How does SCADA Works ?
STL Programming – SET, RESET, ASSIGN
Software Troubleshooting Errors and Faults in Siemens PLC
Comparison of Proportional Integral Derivative Controllers (PID)
ON Delay Timer using PLC
PLC Based Product Sorting Machine System – Lift Control
How a PLC do the Scaling for a Sensor ?
Timer in Studio 5000 – TON, TOF, RTO
Leave Operational Logic in the PLC
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
Instrumentation During the Detail Design Phase
What is Profibus
All About Fieldbus Protocols
What is a function call in TIA Portal
Difference Between FC and FB in Tia Portal
PLC Program for Selective Execution of the Application
PLC Selective Execution of the Application – Example Program
Check Block Consistency Tools
Check Block Consistency Tools in Simatic Manager
Bit Shift Registers PLC Program
PLC Light Sequence Control using Bit Shift Registers
DCS
DCS
Instrumentation and Control Engineer Subject
Competency Factors of Instrument & Control Engineer (Design Engineering)
Control Valve Parts
Control Valve Parts Questions and Answers
High-pressure Service Level Transmitters Misunderstood Zero Drifts
Interview Questions on Control Valves
Fire Alarm System Commissioning Procedure
PID Controller
Proportional Integral Derivative Controllers – PID MCQ
What is Fuzzy Logic
What is Fuzzy Logic? Advantages, Disadvantages, Applications
Power Plant Blackout
What Happens When the Power Plant Blackout?
