Reading: PLC Instruction List for Motor Reverse and Forward Direction
Inst Tools > Blog > PLC Tutorials > PLC Instruction List for Motor Reverse and Forward Direction
Explore how to create a PLC instruction list for motor control in forward and reverse directions to prevent damage.
Last updated: March 11, 2025 12:18 pm
10 Min Read
When a motor is rotated in a forward or reverse direction, care must be taken electrically too. Otherwise, the motor can be damaged. So, limit switches or encoders are installed in many systems to prevent the motor from getting damaged. Also, various factors like speed, acceleration time, and deceleration time play an important role. For this purpose, I have chosen this simple yet critical topic to write a PLC program. In this post, we will see how to write a PLC program for motor forward and reverse direction using instruction list language.
PLC Instruction List for MotorMotor Reverse and Forward Direction Control
Let us understand the case scenario first. We have a motor which can rotate in both the forward and reverse directions. When the motor is started, it moves at a slow speed for 5 seconds, then to full speed (in forward direction).
The motor is moving a load and when that load touches a limit switch, it again moves at a slow speed for 5 seconds and then stops. It then moves in reverse direction after 5 seconds. It moves at a slow speed for 5 seconds, then to full speed. The motor is moving a load and when that load touches a limit switch, it again moves at a slow speed for 5 seconds and then stops. The cycle repeats again.
We will write this logic using Machine Expert Basic software. The language used will be an instruction list. The following are the PLC inputs – forward limit switch and reverse limit switch. The following are the PLC outputs – motor forward and motor reverse.
Refer to the first rung below. The mnemonics used are – BLK (timer block), LD (NO contact), ANDN (and condition in negate way), and END_BLK (end of timer instruction). So, the sequence works as – if the motor is on in forward direction and forward limit has not been cut, then a timer of 5 seconds will run and after that, a full speed will be moved in the motor frequency. Before this time, the motor will run at slow speed.
Motor Forward Delay PLC Instruction List
Refer to the second rung below. The mnemonics used are – BLK (timer block), LD (NO contact), ANDN (and condition in negate way), and END_BLK (end of timer instruction). So, the sequence works as – if the motor is on in reverse direction and reverse limit has not been cut, then a timer of 5 seconds will run and after that, a full speed will be moved in the motor frequency. Before this time, the motor will run at slow speed.
PLC instruction list for motor forward and reverse control
Refer to the third rung below. The mnemonics used are – MPS (branch start), AND (and condition), ANDN (and condition in negate way), S (set coil), and MPP (branch end). So, the sequence works as in the first branch – if the system is running and the forward limit has not been cut, then the motor will run in forward direction. The sequence works as in the second branch – if the motor is running forward and the forward limit has been cut and motor reverse on delay has not been started, then too the motor will run in forward direction.
Motor direction control using PLC instruction list
Refer to the fourth rung below. The mnemonics used are – BLK (timer block), LD (NO contact), ANDN (and condition in negate way), S (set coil) and END_BLK (end of timer instruction).  So, the sequence works as – if the forward limit has been cut and the motor reverse has not been started, then a timer of 5 seconds will run and after that, the motor reverse on delay will start.
How to control motor direction using PLC instruction list
Refer to the fifth rung below. The mnemonics used are – BLK (timer block), LD (NO contact), ANDN (and condition in negate way), S (set coil) and END_BLK (end of timer instruction).  So, the sequence works as – if the motor reverse delay has started and the reverse limit has not been cut, then a timer of 5 seconds will start and after that, the motor will run in reverse direction.
PLC ladder logic vs instruction list for motor control
Refer to the sixth rung below. The mnemonics used are – LD (NO contact), ANDN (and condition in negate way), S (set coil) and AND (and condition). So, the sequence works as – if the motor is on in reverse direction, and the reverse limit has been cut and the motor forward delay has not been started, then too the motor will run in reverse direction.
PLC motor control instruction list for beginners
Refer to the seventh rung below. The mnemonics used are – BLK (timer block), LD (NO contact), ANDN (and condition in negate way), S (set coil) and END_BLK (end of timer instruction).  So, the sequence works as – if the reverse limit has been cut and the motor forward has not been started, then a timer of 5 seconds will run and after that, the motor forward on delay will start.
Programming a motor direction change using PLC instruction list
Refer to the eighth rung below. The mnemonics used are – BLK (counter block), LD (NO contact), R (reset pin), LDR (rising edge contact), ORR (or condition with rising edge contact), CU (count up pin) and END_BLK (end of counter instruction).  So, the sequence works as -whenever a new command for motor run has been triggered (not motor delay), the counter will increment till 5. The counter will reset in the last step when the motor forward has started once again.
How to program a PLC for motor direction reversal
Refer to the ninth rung below. The mnemonics used are – BLK (timer block), LD (NO contact), R (reset coil) and END_BLK (end of timer instruction).  So, the sequence works as – if the motor forward delay has started, then a timer of 5 seconds will run and after that, all the bits will be reset and the cycle will continue once again.
Industrial motor control using PLC instruction list programming
Refer to the tenth rung below. The mnemonics used are – R (or condition), LD (NO contact), AND (and condition), ANDN (and condition in negate way) and ST (normal coil).  So, the sequence works as – if the current counter value is 1 or 2, and the system is running, and motor reverse delay has not started, then the motor will run in forward direction.
PLC-based motor direction control with instruction list coding
Refer to the 11th rung below. The mnemonics used are – R (or condition), LD (NO contact), AND (and condition), ANDN (and condition in negate way) and ST (normal coil).  So, the sequence works as – if the current counter value is 3 or 4, and the system is running, and motor forward delay has not started, then the motor will run in reverse direction.
Using instruction list to control motor direction in PLCs
Refer to the 12th rung below. The mnemonics used are – MPS (branch start), AND (and condition), ANDN (and condition in negate way), MRD (branch extension), and MPP (branch end). So, the sequence works as in the first branch – if the motor is on in forward direction and the fast delay has not been completed, then 20 hz will be moved; otherwise 50 hz will be moved. The sequence works as in the second branch – if the motor is on in reverse direction and the fast delay has not been completed, then 20 hz will be moved; otherwise 50 hz will be moved. The sequence works as in the third branch – if the motor is off in both the directions, then 0 hz will be moved.
Best PLC programming practices for motor forward and reverse
In this way, we saw how to write a motor forward and reverse direction using an instruction list. Refer to the below image for more understanding.
Step-by-step PLC instruction list for motor control
  • Light Sequences Structured Text PLC Program
  • Schneider Electric PLC Problem Vacuum Cleaner
  • Motor Direction Control using Limit Switches
  • Star Delta Starter using Functional Block Diagram
  • While Do Statement in Structured Text PLC Program
Implement UDT in PLC Programming: User-Defined Data Type
Compare Online and Offline PLC Programs
How to Simplify PLC Coding Using Karnaugh Maps?
Introduction to PLC Ladder Diagrams
Electrical Ladder Diagram Control using Timers Example
Ferrules and Cross Ferruling
What is Hot Standby in PLC?
Scale and Normalize Instructions in PLC
PLC Logic for Stairway Lighting
Smart Automation Solutions: PLC Logic for Stairway Lighting
Pump and Mixer Operations Example PLC Timer-Based Control
Pump and Mixer Operations Example: PLC Timer-Based Control
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
Simulator in S7-1200 and S7-1500 PLC
How to Work With Simulator in S7-1200 and S7-1500 PLC?
Retrieve from memory card
How to Retrieve PLC Project From Memory Card?
Omron PLC increment and decrement
Increment & Decrement Instructions in CX-Programmer (OMRON)
Types of Industrial Relays
What is a Relay? Types of Industrial Relays
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Purpose of Isolation valve
Repeat Failures of Letdown Valves
Programmable Array Logic Objective Questions
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
Tungsten Grinders
How to Choose the Best Tungsten Grinders for Welders?
Instrumentation Bulk Material
Instrumentation Bulk Material Requirements in Oxygen Service
Open User Communication in Siemens Tia Portal - PLC to PLC
Open User Communication in Siemens Tia Portal – PLC to PLC
Measurements & Instrumentation Quiz – Set 9
