Reading: PLC FBD Example for Tank Liquid Heating Control by Steam Flow
Inst Tools > Blog > PLC Tutorials > PLC FBD Example for Tank Liquid Heating Control by Steam Flow
Learn how to heat liquid in a tank by steam flow example using the language of functional block diagram (FBD) in a PLC.
Last updated: September 16, 2024 4:51 am
PID and control algorithms are one of the most used functions in PLC programs. As more and more systems demand accurate control of process variables, these algorithms and functions play a very important role.
Tank Liquid Heating Control by Steam FlowPLC FBD Example
Before using PID, we can also use some simple addition and subtraction formulae for controlling a process. Let us see a case of heating a tank here in this post. In this article, we will see how to heat liquid in a tank by steam flow, using the language of functional block diagrams, as it is easy to use and understand.
Let us understand the case scenario first. There is a tank with a liquid in it. It needs to be heated and maintained around a set temperature.
For this, a steam valve is used. When the temperature is below the setpoint, the valve will open at a rate of 0.1% / 10 seconds time. When the temperature is above the setpoint, the valve will close at a rate of 0.1% / 10 seconds time.
And to lock the valve at it’s minimum and maximum values, we compare it’s current opening percentage. If it is already 0%, then we prevent it from closing further by forcefully moving value 0 in it. If it is already 100%, then we prevent it from opening further by forcefully moving value 100 in it. Otherwise, there will be no limit in it’s addition and subtraction.
PLC FBD Example
Now, let us write the program. Refer to the below image. There is one PLC analog input – temperature sensor and one PLC analog output – steam valve.
If you see the image, the program is divided into two parts. In the first part of the left hand side, we open the valve and in the second part of the right hand side, we close the valve. As seen in the case, we check the temperature every 10 seconds. So, we use a timer initially which runs continuously for every 10 seconds.
If the temperature is less than equal to 45 degrees and the current steam valve opening is less than 100%, then we add the current value of valve with 0.1 after a 10 second pulse. For that, we use LE block, AND block and ADD block. To limit the valve opening, even if the temperature is low but the current steam valve opening is more than equal to 100%, then we forcefully move 100% in the valve and stop adding now.
If the temperature is more than equal to 45 degrees and the current steam valve opening is more than 0%, then we subtract the current value of valve with 0.1 after a 10 second pulse. For that, we use GE block, AND block and SUB block. To limit the valve opening, even if the temperature is high but the current steam valve opening is less than equal to 0%, then we forcefully move 0% in the valve and stop subtracting now.
The cycle thus goes on according to the temperature and at the same time, we also limit valve opening between it’s minimum and maximum values. This frequent opening and closing of the steam valve thus controls the temperature of the liquid.
In this way, we saw how to write a PLC program for heating liquid in the tank by steam flow, using a functional block diagram.
Read Now:
  • Traffic Lights Ladder Diagram using Timers
  • PLC Programming With a Move Instructions
  • PID Controllers in Closed Loop Control Systems
  • Motion Detection based Street Light PLC Logic
  • SAVE and BR Memory Instructions in Siemens PLC
Implement UDT in PLC Programming: User-Defined Data Type
Communication between InTouch Scada and Allen Bradley PLC
Sequential Operation of Output Bits using Two Push buttons
SFC Language in PLC Programming
Principle of Operation of PLC
Functional Block Diagram PLC Example for Traffic Light System
FactoryTalk Studio and SQL Server for Data Logging
#6 PLC Best Practices – Validate Timers and Counters
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
PLC Ladder Logic for Tanks Filling as per Priority
Two wire loop powered transmitters
Studio 5000 Tutorial PLC Programming for Digital Alarms
Studio 5000 Tutorial: PLC Programming for Digital Alarms
Wonderware Recipe Manager Plus
What is Recipe Management in SCADA?
Surface Grinding Process using PLC Program
RSLogix 5000 PLC Programming Procedure
PID Simulator
PID Simulator Download
Simulator in S7-1200 and S7-1500 PLC
How to Work With Simulator in S7-1200 and S7-1500 PLC?
PLC Program for Controlling Sequence of Conveyors with Interlocking
DC Machine
DC Machines Construction
Process Control Instrumentation Engineering Interview Questions
Industrial Electronics Objective Questions and Answers
PLC programming for clothes washing machine automation
LS Electric PLC Program Example: Clothes Washing System
Process Control & Instrumentation Objective Questions – Set 6
What is Transparent Solar Panel
What is Transparent Solar Panel? – Working Principle and Theory
Reflex Level Gauge Parts
What is Reflex Level Gauge?
Types of Potentiometers
Types of Potentiometers – What is a Potentiometer? – Applications
