Reading: #7 PLC Best Practices – Validate and Alert for Paired Inputs/Outputs
Inst Tools > Blog > PLC Tutorials > #7 PLC Best Practices – Validate and Alert for Paired Inputs/Outputs
Alarm the operator when input/output states occur that are physically not feasible. Validate and alert for paired inputs/outputs in PLC.
Last updated: September 21, 2021 1:46 pm
If you have paired signals, ensure that both signals are not asserted together. Alarm the operator when input/output states occur that are physically not feasible.
ExampleExamples for toggling paired signals that could be damaging
Consider making paired signals independent or adding delay timers when toggling outputs could be damaging to actuators.
Security ObjectiveTarget Group
The integrity of PLC variables ResilienceProduct Supplier Integration / Maintenance Service Provider
Guidance
Paired inputs or outputs are those that physically cannot happen at the same time; they are mutually exclusive. Though paired signals cannot be asserted at the same time unless there is a failure or malicious activity, PLC programmers often do not prevent that assertion from happening.
Validation is easiest to directly do in the PLC because the PLC is aware of the process state or context. Paired signals are easier to recognize and track if they have sequential addresses (e.g., input 1 and input 2).
Another scenario where paired inputs or outputs could cause problems is when they are not asserted at the same time, but toggled quickly in a way that damages actuators.
Example
Examples of paired signals:
  1. START and STOP
  • Independent start & stop: Configure start and stop as discrete outputs instead of having a single output that can be toggled on/off. By design, this does not allow simultaneous triggers. For an attacker, it is way more complicated to rapidly toggle on / off if two different outputs have to be set.
  • Timer for restart: Also consider adding a timer for a re-start after a stop is issued to avoid rapid toggling off start/stop signals.
2. FORWARD and REVERSE
3. OPEN and CLOSE
If the PLC / MCC accepts a discrete input, this provides an easy option for an attacker to cause physical damage on actuators. The well-known scenario for toggling outputs to do damage would be an MCC, but this practice applies to all scenarios where toggling outputs could do damage.
A proof of concept where rapidly toggling outputs could cause real damage was the Aurora Generator Test in 2007 conducted by the Idaho National Laboratory, where toggling outputs out of sync caused circuit breaker damage.
Why?
Beneficial for…?Why?
          Security1. If PLC programs do not account for what is going to happen if both paired input signals are asserted at the same time, this is a good attack vector.
2. Both paired input signals being asserted is a warning that there is an operational error, programming error, or something malicious is going on.
3.  This avoids an attack scenario where physical damage can be caused to actuators.
    Reliability1. Paired input signals can point to a sensor being broken or mis-wired or that there is a mechanical problem like a stuck switch.
2. Quickly toggling start and stop could also be done by mistake, so this also prevents damage that might be done inadvertently.
Maintenance/
References
Standard/frameworkMapping
  MITRE ATT&CK for ICSTactic:  TA010 – Impair Process Control
Technique:  T0836 – Modify Parameter, T0806 – Brute Force I/O
  ISA 62443-3-3SR 3.5: Input Validation
SR 3.6: Deterministic Output
  ISA 62443-4-2CR 3.5: Input Validation
CR 3.6: Deterministic Output
  ISA 62443-4-1SI-2: Secure coding standards
SVV-1: Security requirements testing
MITRE CWECWE-754: Improper Check for Unusual or Exceptional Conditions
Source: PLC Security
Site Commissioning Steps for PLC Programmers
Basics of PLC Programming
PLC Compressor Control Ladder Logic
Rules for Writing SCL Language in Tia Portal
Will PLCs become obsolete?
Various Causes for PLC Going in Stop Mode
PLC Simulator using Excel
Up Counter PLC Program
PLC Tag Naming Conventions
PLC Ladder Diagram program
Contacts and Coils in PLC Ladder Logic
PLC Temperature Control using Pulse Width Modulation
PLC Temperature Control using Pulse Width Modulation (PWM)
PLC Interlock Example
PLC Interlock Logic with First Input Priority
PLC Programmer Salary and Future Career Scope
PLC program Permissive Circuit
PLC Electric Motor Interlocks
PLC Star-Delta starter with interlock
Schneider PLC Example Program for Star-Delta System
How to Upload PLC Program in Siemens PLC if Upload Icon is Disabled
Upload Option Disabled in Siemens PLC
AC Voltage Controllers Multiple Choice Questions
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
Direct operated (direct acting) solenoid valves
Solenoid Valves Types & Functions
4-20mA Image
4-20mA Graphical Calculations
Feedforward Control
Feedforward Vs Feedback Control
Spectral Method of Analysis Questions & Answers
Components of Bourdon Tube Pressure Gauge
Components of Bourdon Tube – Questions and Answers
