Reading: PLC Automatic Irrigation System
Inst Tools > Blog > PLC Tutorials > PLC Automatic Irrigation System
Last updated: March 4, 2021 3:50 pm
3 Min Read
There are two different plants line in the garden. Both the plants types are different so we need to provide water as per demand of the plants. Design Automatic irrigation system for two different plants line using PLC ladder Logic.
Automatic Irrigation SystemPLC Solution :List of Inputs/OutputsLadder Logic – Automatic irrigation systemPLC Logic Description
PLC Automatic Irrigation System Ladder Logic Project
PLC Solution :
Here two types of methods are used for the plants.
For first plant line, we are using float switch because in this line it is necessary to maintain water level in the pool, so here water level will be controlled according to minimum level and maximum level.
In second plants line, we will operate different water pump as per moisture in the plants. If sensor detects low moisture, water pump will start and it will stop working when moisture is sufficient in the plants.
List of Inputs
  • I1 :- Minimum level
  • I2 :- Auto on
  • I3 :- Moisture sensor
  • I4 :- Maximum level
List of Outputs
  • Q1 :- Water pump for plants line A
  • Q2 :- Water pump for plants line B
Automatic Drip Irrigation System Using PLC
Network 1 :-
In this network we have used set reset logic for the water pump which is used for plants line A. When level is minimum in the pool, SET instruction will be executed and if level is normal, then reset condition will be executed.
Network 2 :-
Here water pump for the plants line A will be ON when both conditions (Set condition and auto on condition) are met.
Network 3 :-
When moisture is not available in the plants, water pump for the plants level B will be ON.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple automatic irrigation system for two different plants line using PLC; we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author : Bhavesh
Boiler Three Element Control
PLC Conveyor Logic Program
Data Compare Instructions
4-20mA Current loop
PLC PWM Control Logic
Omron PLC for Product Painting with Integrated Weighing System
CX Programmer Example: Perfume Mixing and Filling System
Types of Limit Switches – Principle, Advantages, Disadvantages
How to Convert Voltage to Current using Resistor ?
Free SCADA Training Course
PLC Ladder Logic for Lube Oil Pump Motor
Types of Allen Bradley PLC
Motor Speed Control using VFD and PLC Programming
Two Hand Control Logic using PLC
How to Delay a Sensor Signal in PLC?
Features of Scada Which are Must in an IoT System
How to Select the Right Encoder for Your Machine
How to Select the Right Encoder for Your Machine?
Sorting Defective Parts PLC Logic
Advanced PLC Programming for Defective Parts Sorting
PLC Programming for Garden Sprinkle System
PLC Programming for Garden Sprinkler System
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
PLC Example on Switch Program with Timers
Example of PLC Programming based on Logic Circuit
Thin Client in SCADA
What is Thin Client in SCADA? – Purpose, Advantages
Augmented Reality and Virtual Reality in Industrial Automation
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 2
Single Phase Voltage Source Inverter Quiz
Allen Bradley Powerflex VFD
Displacer Level Sensor Working Animation
How to Troubleshoot a PLC System
How to Troubleshoot a PLC System?
Surge Protection for the Fieldbus System
Electrical Machines MCQ Series 16
open vs closed loop
Open Loop and Closed Loop Animation
