Reading: PLC Analog Input Conversion Formula
Inst Tools > Blog > Formulas > PLC Analog Input Conversion Formula
Last updated: March 4, 2021 4:18 pm
Formulas PLC Tutorials
2 Comments
3 Min Read
For any unit conversion on any PLC, you can use four function math with the following for PLC Analog Input Conversion Formula, which assumes integer math, as follows :
PLC Conversion Formula
Formulas:
EU = ((EUSpan x (DATA – DataOffset))/DataSpan) + EUOffset
ProcessValue = EU / FACTOR
DataOffset = Data in input register at 4 mA (or zero analog signal of whatever range – for example 0 VDC on a 0-10 VDC transmitter)
DataSPan = Data at 20 mA – Data @ 4 mA
FACTOR = arbitrary factor (multiple of 10) needed to get proper resolution and accuracy
EU = Engineering Units x FACTOR
EUOffset = Engineering Units @ 4 mA x FACTOR
EUSpan = (Engineering Units @ 20 mA – Engineering Units @ 4 mA) x FACTOR
DATA = Actual data reading in input register
For Example,
A Pressure transmitter of range 0 to 60 psig is connected to an PLC analog input card. The PLC Analog input card raw count starting from 6240 for 4mA and 31208 for 20mA. PLC reading 18975 raw counts and calculate equivalent pressure transmitter reading.
Note: PLC raw counts may vary from system to system.
0-60 psig from 4-20 mA with resolution of 0.1 psig:
FACTOR = 10
Data @ 4 mA = 6240
Data @ 20 mA = 31208
DataOffset = 6240
DataSpan = 31208 – 6240 = 24968
EUOffset = 0 x 10 = 0
EUSpan = (60 – 0) x 10 = 600
DATA = 18975
EU = ((600 x (18975 – 6240)) / 24968) + 0 = 306
Process Value = 306 / 10 = 30.6 psig
Process Interlocks and Trips
Split Range Control Loop
Analyze a Cascade Control Loop
Ratio Controller Example
PID Tuning Procedure
Free Allen Bradley PLC Ladder Logic Training Course
PLC Logic GATE Program
How to Create Templates in FactoryTalk View Studio?
2 Comments
  • kingsley says:
    September 14, 2016 at 12:40 pm
    NICE ONE SIR,
    I APPRECIATE THIS
  • jignesh says:
    November 26, 2016 at 1:17 pm
    thank you so much sir..Its a very useful things..your work is really very good..
Proper Earthing Practices Used for PLC Control Panel
Schneider Electric: Car Parking System with Calculations in PLC
How to Design an Effective HMI? – Human Machine Interface
Zero Suppression and Zero Elevation Calculations
Auto Tiffin Box Filling Station
#1 PLC Best Practices – Split PLC Code into Modules
Communication between Factory IO and Siemens Tia Portal
PLC based Door Open and Closing System
Digital input signals in safety circuits
1oo2 Evaluation Safety Instruction in Safety PLC
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Comparison of Control Loops - Open, Closed, Cascade, Feedforward, Ratio
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Basics of Motion Controllers
Start Stop of one Motor from same Push button PLC program
Types of Scan Time in a PLC
#16 PLC Best Practices – Create Trend for Cycle Time on HMI
OB and FB Blocks in Siemens PLC
Procedure for Siemens S7-300 Download from PC to PLC
Difference between Signal Cables and Control Cables
PLC Ladder Logic Simulator Mobile Apps For Android
Galileo thermometer Principle
Galileo Thermometer
GSD File installation in Simatic Manager
How to Install GSD File in Step 7 PLC using Simatic Manager?
progressively sequenced control valves
Progressive Control Valve Sequence
Modbus
Modbus : History, Structure, Modes, Addressing, Functions
Boiler Level Switch
Float level switch Principle
11 KV Bus A to Bus B Phase Check Problem
Difference between BDV and PSV
