Reading: What is Photoionization Detector (PID)?
Inst Tools > Blog > Fire & Gas System > What is Photoionization Detector (PID)?
Last updated: September 25, 2019 1:31 pm
Fire & Gas System
2 Min Read
The Photoionization Detector (PID) applies ultraviolet light to the detectable gas to ionize it. This causes an ion current to be generated. The sensor measures this current to determine the gas concentration.
It detects a wide range of gases, irrespective of whether they are organic or inorganic. It is generally used to measure ppb to ppm levels of concentration of volatile organic compounds (VOCs).
This detector is used to measure toxic gaes.
The sensor consists of an ionization chamber for letting in the detectable gas (gas to be measured), an ultraviolet lamp for applying light, and positive and negative electrodes for detecting ion currents.
The detectable gas enters the ionization chamber and is exposed to ultraviolet light from the light source (ultraviolet lamp). This causes the gas to release electrons, generating cations.
The generated cations and electrons are drawn by the positive and negative electrodes, which causes a current to be generated. Since this current is proportional to the gas concentration, the sensor measures the current value to determine the concentration of the detectable gas.
Ionizing a detectable gas requires the application of photon energy larger than the ionization energy specific to that gas. Photon energy is expressed in the unit electron volt (eV). This sensor uses a lamp having photon energies such as 10.6 eV and and 11.7 eV. The larger the photon energy is, the larger the amount of detectable gas the sensor can ionize.
Source – rikenkeiki
Gas Detectors Working Principle
Interview Questions on Smoke Detection System
Interview Questions on Gas detection System
Basics of Fire Detection System
Objective Questions of Building Fire and Gas Detectors
Deluge Valve Operation
Importance of Fire & Gas Detection System
Deluge Valve Working Principle
Flame Detectors Working Principle
What is Gas Suppression Systems ?
Catalytic Type Gas Sensor Principle
Point IR Detectors Vs Open Path IR Detectors
Why Negative Readings in Gas Detectors ?
Overview of Fire/Smoke/Flame/Heat/Gas Detectors
Fire Extinguisher Operation
Basics of Fire Extinguisher
Gas Detectors Practical Problems and Troubleshooting
Fire Alarm System Commissioning Procedure
Chlorine Cylinders
Chlorine Gas Hazards
Gas Detectors Bump Testing
What is Bump Testing ?
Fixed Gas Detectors vs. Portable Gas Detectors
Why Fire and Gas Detectors are 3-Wire types instead of 2 Wire
Why Fire and Gas Detectors are 3-Wire types instead of 2 Wire?
oxygen Safety Analyzer
Oxygen Safety Analyzer
Ziegler-Nichols Closed Loop Tuning Procedure
ball Valve Animation
Basics of Ball Valves
dissolved-oxygen-probe-calibration-procedure
Dissolved oxygen probe calibration procedure
Three-Phase Wye Wiring System
4-Wire, Three-Phase Wye Wiring System
how-to-select-a-fuse
How to Select a Fuse ?
What is Fuzzy Logic
What is Fuzzy Logic? Advantages, Disadvantages, Applications
AI Projects for Engineering Students - Artificial Intelligence
AI Projects for Engineering Students – Artificial Intelligence
