Reading: Parameter Optimization
Inst Tools > Blog > Multiple Choice Questions > Parameter Optimization
1. A conditionally stable system exhibits poor stability at :
a) Low frequencies
b) Reduced values of open loop gain
c) Increased values of open loop gain
d) High frequencies
Answer: b
Explanation: A conditionally stable system is the system which is stable only for certain values of K and exhibits poor stability at the reduced values of open loop gain.
2. The type 0 system has ______ at the origin.
a) No pole
b) Net pole
c) Simple pole
d) Two poles
Answer: a
Explanation: The type of the system is defined as the property of the system which has pole at the origin.
3. The type 1 system has ______ at the origin.
a) No pole
b) Net pole
c) Simple pole
d) Two poles
Answer: c
Explanation: The type of the system is defined as the pole at the zero and type 1 is defined as the 1 pole at the origin.
4. The type 2 system has at the origin.
a) No net pole
b) Net pole
c) Simple pole
d) Two poles
Answer: d
Explanation: Type of the system is defined as the number of pole at origin and type 2 is the 2 poles at the origin.
5. The position and velocity errors of a type-2 system are :
a) Constant, constant
b) Constant, infinity
c) Zero, constant
d) Zero, zero
Answer: c
Explanation: The position and velocity error of the type 2 system is zero and a constant value as for type 2 system velocity error is finite while acceleration error is infinite.
6. Velocity error constant of a system is measured when the input to the system is unit _______ function.
a) Parabolic
b) Ramp
c) Impulse
d) Step
Answer: b
Explanation: Velocity error constant of a system is measured when the input to the system is unit ramp function then only velocity error is finite but error due to other inputs are not defined.
7. In case of type-1 system steady state acceleration is :
a) Unity
b) Infinity
c) Zero
d) 10
Answer: b
Explanation: In case of type-1 system steady state acceleration is infinity as for the type less than 3 acceleration is not defined it is infinity.
8. If a step function is applied to the input of a system and the output remains below a certain level for all the time, the system is :
a) Not necessarily stable
b) Stable
c) Unstable
d) Always unstable
Answer: a
Explanation: If the input is bounded and output is also bounded then the system is always stable and step input is bounded and the output is always under certain li its then the system is stable.
9. Which of the following is the best method for determining the stability and transient response?
a) Root locus
b) Bode plot
c) Nyquist plot
d) None of the mentioned
Answer: a
Explanation: Root locus is the best method for determining stability of the transient response as it gives the exact pole zero location and also their effect on the response.
10. Phase margin of a system is used to specify which of the following?
a) Frequency response
b) Absolute stability
c) Relative
d) Conditional stability
Answer: b
Explanation: Phase margin of the system can be used for determining the absolute stability of the system.
Split-Range, Auto-Selector, Ratio & Cascade Systems
Experimentation of Transfer Function
Feedback and Non-feedback Systems Objective Questions
Pneumatic Systems Objective Questions
Concept of Stability in Control Systems
Robotic Control System – Part I
Electron Probe Microanalyser Questions & Answers
Pneumatic Control Mechanisms Objective Questions
Realization of Basic Compensators
Ion Analyzer Questions & Answers
Constructing Phase-Trajectories
Root Locus in Control Systems
Programmable Logic Controllers Multiple Choice Questions
Digital Circuits Questions & Answers
Logic Families Questions and Answers
NO2 Analyzer Questions & Answers
Fluorescent Spectrometer Questions & Answers
IR Instrumentation Questions & Answers
Advances in Control System
Fuzzy Logic Control
Biosensors Questions & Answers
Frequency Response MCQ
Bode Plots MCQ
Gamma Camera Questions & Answers
PLC Totalizer
PLC Program for Flow Totalizer
Turbine Flow Meter
All About Turbine Meters
Liquid Crystal Display Objective Questions
Fieldbus and Profibus
Difference between Fieldbus and Profibus
A Question on Density Gauge
Hierarchy of Calibration Organizations
Electronics Mini Projects
300+ Best Electronics Mini Projects
Explosive Limit in Fire and Gas System
What is an Explosive Limit? – Lower Explosive Limit (LEL)
