Reading: Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Inst Tools > Blog > Analyzers > Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Last updated: September 14, 2016 10:58 pm
Analyzers Calibration
3 Comments
3 Min Read
ORP stands for Oxidation-Reduction Potential. In practical terms, it is a measurement to oxidize contaminants. It’s as simple as that
The Oxidation-Reduction Potential (ORP) Sensor measures the ability of a solution to act as an oxidizing or reducing agent. Use the ORP Sensor to measure the oxidizing ability of chlorine in swimming pools or to determine when the equivalence point has been reached in an oxidation-reduction reaction.
Checking ORP is a simple method to monitor the effectiveness of a sanitizer or the quantity of anti-oxidants in a liquid. In generalized terms for humans, a higher ORP is better for outside of the body, while a lower ORP is preferred for consumption due to the high anti-oxidant value.
The oxidation/reduction potential is the electrometric difference measured in a solution between an inert indicator electrode and a suitable reference electrode. The electrometric difference is measured in millivolts and is temperature dependent.
Calibration or Verification Procedure:
1. Allow the calibration standard (a Zobell solution: read the warning on the label before use) to equilibrate to ambient temperature.
2. Remove the probe from its storage container and place it into the standard.
3. Select measurement ‘mode.
4. Wait for the probe temperature to stabilize, and then read the temperature.
5. If the instrument is to be calibrated, do Steps 6 and 7. If the instrument calibration is to be verified, then go to Step 8.
6. Look up the millivolt (mv) value at this temperature from the millivolt versus temperature correction table usually found on the standard bottle or on the standard instruction sheet. You may need to interpolate millivolt value between temperatures. Select “calibration mode”, then “ORP”. Enter the temperature-corrected ORP value into the instrument.
7. Select measurement mode. The readings should remain unchanged within manufacturer’s specifications. If they change, re-calibrate. If readings continue to change after re-calibration, try a new Zobell solution or consult manufacturer. Go to Step 9.
8. If the instrument instruction manual states that the instrument is factory calibrated, then verify the factory calibration against the Zobellsolution. If they do not agree within the specifications of the instrument, try a new Zobell solution. If it does not agree, the instrument will need to be re-calibrated by the manufacturer.
9. After the calibration has been completed, rinse the probe with deionized water and store the probe according to manufacturer’s instructions.
10. Record the calibration information on the calibration log sheet.
Shunt Calibration of a Strain Gauge Load Cell
Selection of Master Instrument for Calibration
How to Test a Pressure Switch ?
RTD Calibration
Sodium Analyzer Problems and Troubleshooting Steps
Instrument Errors – Zero, Span, Linearity
3 Comments
  • ray says:
    October 3, 2015 at 10:51 pm
    I used to be very happy to find this web site. I wanted to thanks for your time for this wonderful read !!
  • lakhan says:
    February 16, 2016 at 9:22 am
    I dont have word for thanking you.my all questions and problems solves after see this site. This is amazing and its language is very simple for understanding. I have one question how to measure level by pressure difference in mmh2o.
    • S Bharadwaj Reddy says:
      February 16, 2016 at 4:56 pm
      Hello Lakhan, Plz Click Here For Measurement of Pressure Difference in mmh20. Thanks
Capacitance Level Switch Calibration
Difference between Repeatability and Reproducibility
Smart Transmitter Calibration Tutorial Part 1
Flow Meter Calibration
Selection of Industrial Temperature Calibrator
Moisture Calculator
Specific Conductance Calibration Procedure
What is Infrared Flue Gas Analyzer? – Working Principle
Displacer Level Transmitter Calibration Procedure
Displacer Level Transmitter Calibration using Water & Process Liquid
pH sensor calibration procedure
Multiphase Flow Meter Calibration Procedure
Sensor Trim and Output Trim in Smart Transmitter
What is Sensor Trim and Output Trim in Smart Transmitter?
Instrument Maintenance and Calibration System
Differential Pressure Switch Calibration Procedure - Copy
As-Found and As-Left data during Calibration
Why it is important to note As-Found and As-Left data during Calibration?
Technologies for Oxygen Gas Measurement
Inverse Time Circuit Breaker
What are Inverse Time and Instantaneous Trip Circuit Breakers?
SIS Design - Safety Instrumented System
SIS Design – Safety Instrumented System
Irrigation based Projects
Irrigation based Projects for College Students
Induction Motor Operating Characteristics
Pumps Quiz
Pumps Quiz
Field Instruments Selection Aid
Asynchronous Down Counter Objective Questions
