Reading: Optimal Control Problems – Part 1
Inst Tools > Blog > Multiple Choice Questions > Optimal Control Problems – Part 1
1. The output of the system is considered near :
a) 1
b) 2
c) 3
d) 0
Answer: d
Explanation: Our main objective in the optimal control problem is to reduce the performance index of the system as minimize the output and make it near equal to zero.
2. A performance index written in terms of :
a) 1 variable
b) 2 variable
c) 3 variable
d) 5 variable
Answer: b
Explanation: Generally the performance index be of any variables but in standard form we consider the performance index to be in 2 variable only.
3. Matrix Q is :
a) Positive semi definite symmetric matrix
b) Positive definite non-symmetric matrix
c) Negative definite symmetric matrix
d) Negative definite non-symmetric matrix
Answer: a
Explanation: Matrix Q defines positive definite or non-definite symmetric matrix which is used in the performance index so as to give equal weightage to each element.
4. Matrix R is :
Answer: a
Explanation: Matrix R defines positive definite or non-definite symmetric matrix which is used in the performance index so as to give equal weightage to each element.
5. The major requirement of making the output of the system small in output regulator problem is :
a) The system must be controllable
b) The system must be stable
c) The system must be observable
d) The system must be LTI
Answer: c
Explanation: We are concerned with making the output of the output regulator problem small this is achieved when the system is observable.
6. Minimum principle was given by:
a) Pontryagin
b) Hamiltonian
c) Bellman
d) Jacobi
Answer: a
Explanation: The minimum principle to minimize the performance index is given by Pontryagin.
7. Dynamic programming is developed by:
a) Pontryagin
b) Hamiltonian
c) Bellman
d) Jacobi
Answer: c
Explanation: Dynamic programming for minimizing the performance index is given by Bellman.
8. The performance index is reduced by:
a) State variable constraint
b) Input constraint
c) Control function minimization
d) Control function constraint
Answer: c
Explanation: Once the performance index is calculated the next task is to find the control function which is used to minimize the performance index.
9. Minimum principle is based on :
a) Concepts of calculus of variations
b) Principle of calculus
c) Principle of invariant imbedding
d) Principle of optimality
Answer: a
Explanation: Minimum principle of Pontryagin is based on the concept of calculus of variations.
10. Dynamic programming is based on :
a) Principle of calculus
b) Principle of invariant imbedding
c) Principle of optimality
d) All of the mentioned
Answer: d
Explanation: Dynamic programming is based on principle of calculus, invariant imbedding and optimality and these are the basic laws of the nature and does not need complex mathematical development to explain its validity.
Gas Chromatography Questions & Answers
UV Visible Spectrometers Questions and Answers
Concept of Stability in Control Systems
Analytical Measurement Multiple Choice Questions
Surface Spectroscopic Techniques
X-Ray Spectroscopy Questions & Answers
Polar Plots MCQ
Fuzzy Logic Control
Ion Analyzer Questions & Answers
Gamma Camera Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Robotic Control System – Part I
Measurement and Instrumentation Objective Questions – Part 5
Mathematical Preliminaries
Control Systems Multiple Choice Questions
Gas Solid Chromatography Questions & Answers
Digital Circuits Questions & Answers
Digital Control Systems
Signal Reconstruction
Time Response Analysis
Design Considerations for Higher Order Systems
Sulphur Di-oxide Monitoring Questions & Answers
Instrumentation of Ion Spectroscopy
Actuators Questions and Answers
Smart Drip Irrigation System Using PLC
Generator Action in a Motor
Special Purpose Diodes Interview Questions & Answers
OPC Protocol
History of OPC Protocol
Thermal Conductivity Detector (TCD)
Thermal Conductivity Detector (TCD) Principle
quadruple block valve
What is Safety Instrumented Functions ?
liquid flow control loop
Liquid Flow Control Loop Controller Action
