In this article, we shared the ohms law objective questions and answers for electrical and electronics engineers.
Ohms Law Objective Questions
The below list provides all the multiple-choice questions related to basics and examples of problems on ohms law.
1. A closed switch has a resistance of
A) | zero |
B) | about 50 ohms |
C) | infinity |
D) | about 500 ohms |
2. The resistance of a few meters of wire conductor in a closed electrical circuit is
A) | low |
B) | practically zero |
C) | very high |
D) | high |
3. For which of the following substances the temperature coefficient of resistivity is positive?
A) | Electrolyte |
B) | Germanium |
C) | Carbon |
D) | Aluminium |
4. Which of the following materials has the least resistivity?
A) | Zinc |
B) | Copper |
C) | Mercury |
D) | Lead |
5. The resistance of a copper wire 200 m long is 21 ω.​
If its thickness (diameter) is 0.44 mm, its specific resistance is around
A) | 1.2 x 10-8 ​​ω-m |
B) | 1.4 x 10-8 ​​ω-m |
C) | 1.8 x 10-8 ​​ω-m |
D) | 1.6 x 10-8 ​​ω-m |
6. Temperature coefficient of resistance is expressed in terms of
A) | ohms/ohm°C |
B) | mhos/ohm°C |
C) | mhos/°C |
D) | ohms/°C |
7. Specific resistance of a conductor depends upon
A) | dimensions of the conductor and composition of conductor material. |
B) | dimensions of the conductor. |
C) | composition of conductor material. |
D) | resistance of the conductor |
8. Heat in a conductor is produced on the passage of electric current due to
A) | reactance |
B) | capacitance |
C) | impedance |
D) | resistance |
9. Which resistor will be physically larger in size?
A) | 10ω, 50W |
B) | 1kω, 1W |
C) | 1Mω, 1/2W |
D) | 100ω, 10W |
10. A light bulb draws 300 mA when the voltage across it is 240 V.​
The resistance of the light bulb is
A) | 800 ω |
B) | 600 ω |
C) | 400 ω |
D) | 1000 ω |
11. A 3 ω resistor having 2 A current will dissipate the power of
A) | 6 watts |
B) | 8 watts |
C) | 2 watts |
D) | 4 watts |
12. With rise in temperature the resistance of semiconductors
A) | decreases |
B) | increases |
C) | remains constant |
D) | first increases and then decreases |
13. Voltage dependent resistors are usually made from
A) | graphite |
B) | charcoal |
C) | nichrome |
D) | silicon carbide |
14. For determining the polarity of the voltage drop across a resistor, it is necessary to know the
A) | value of emf in the circuit. |
B) | value of current. |
C) | direction of current flowing through the resistor. |
D) | value of resistor. |
15. Three resistances of 10 ohms, 15 ohms, and 30 ohms are connected in parallel.​
The total resistance of the combination is
A) | 10 ohms |
B) | 55 ohms |
C) | 15 ohms |
D) | 5 ohms |
16. Which of the following materials possesses the least specific resistance?
A) | Iron. |
B) | Aluminium. |
C) | Silver. |
D) | Copper. |
17. The temperature coefficient of resistance of an insulator is
A) | positive and independent of temperature. |
B) | positive and dependent on temperature |
C) | negative and dependent on temperature. |
D) | negative and independent of temperature. |
18. Two resistors R1 and R2 give combined resistance of 4.5 ω when in series and 1 ω when in parallel, the resistances are
A) | 4 ω and 0.5 ω |
B) | 1.5 ω and 3 ω |
C) | 1 ω and 3.5 ω |
D) | 2 ω and 2.5 ω |
19. Conductance is reciprocal of
A) | resistance |
B) | reluctance |
C) | capacitance |
D) | inductance |
20. If the length of a wire of resistance R is uniformly stretched to n times its original value, its new resistance is
A) | ​​n R |
B) | ​​R/n |
C) | ​​n2R |
D) | ​​R/n2 |
21. Four wires of same material, the same cross-sectional area and the same length when connected in parallel give a resistance of 0.25 ω.​
If the same four wires are connected is series the effective resistance will be
A) | 4 ω |
B) | 2 ω |
C) | 1 ω |
D) | 3 ω |
22. Voltage dependent resistors are used
A) | to supress surges |
B) | for inductive circuits |
C) | as heating elements |
D) | as current stabilizers |
23. The resistance of a parallel circuit consisting of two branches is 12 ohms.​
If the resistance of one branch is 18 ohms, what is the resistance of the other?
A) | 36 ω |
B) | 64 ω |
C) | 48 ω |
D) | 18 ω |
24. In a series circuit with unequal resistances
A) | the lowest resistance has the highest current |
B) | In a series circuit with unequal resistances |
C) | the lowest resistance has the highest voltage drop |
D) | the highest resistance has the highest voltage drop |
25. Two resistances R1 and R2 are connected in series across the voltage source where R2 > R1. The largest drop will be across
A) | either R1 or R2 |
B) | R2 |
C) | none of these answers |
D) | R1 |
26. If a wire conductor of 0.2 ohm resistance is doubled in length, its resistance becomes
A) | 0.4 ohm |
B) | 1.0 ohm |
C) | 0.8 ohm |
D) | 0.6 ohm |
27. A network consists of linear resistors and ideal voltage source.​
If the value of the resistors are doubled, then voltage across each resistor is
A) | not changed. |
B) | halved. |
C) | doubled. |
D) | increased four lines. |
28. The specific resistance of all metals is most affected by
A) | Degree of illumination |
B) | Applied magnetic field |
C) | Temperature |
D) | Pressure |
29. A resistance having rating 10 ohms, 10 W is likely to be a
A) | wire wound resistor |
B) | metallic resistor |
C) | variable resistor |
D) | carbon resistor |
30. Four resistances 80 ω, 50 ω, 25 ω and R are connected in parallel.​
Current through 25 ω resistance is 4 A.​
Total current of the supply is 10 A.​
The value of R will be
A) | 40.25 ω |
B) | 76.56 ω |
C) | 66.66 ω |
D) | 36.36 ω |
31. A rheostat differs from a potentiometer in the respect that it
A) | has lower wattage rating |
B) | has higher wattage rating |
C) | offers large number of tappings |
D) | has large number of turns |
32. Two resistors are said to be connected in series when
A) | both carry the same value of current |
B) | total current equals the sum of branch currents |
C) | same current passes in turn through both |
D) | sum of IR drops equals the applied e.m.f. |
33. Which of the following statements is correct regarding resistance?
A) | The resistance of a conductor is the hindrance by which the conductor opposes the flow of current through it. |
B) | The resistance of a wire does not depend upon its material. |
C) | The resistance of wire is independent of the temperature for most of the materials |
D) | None of these answers |
34. With three resistances connected in parallel, if each dissipates 20 W the total power supplied by the voltage source equals
A) | 40 W |
B) | 60 W |
C) | 10 W |
D) | 20 W |
35. A thermistor has
A) | negative temperature coefficient |
B) | zero temperature coefficient |
C) | positive temperature coefficient |
D) | variable temperature coefficient |
36. Specific resistance of a substance is measured in
A) | ​​ωm2 |
B) | ​​ω-m |
C) | ​​m/ω |
D) | ​​ω/m |
37. The resistance of two wires is 25 ω when connected in series and 6 ω when joined in parallel. The resistance of each wire is
A) | 10 ω, 15 ω |
B) | 20 ω, 30 ω |
C) | 5 ω, 10 ω |
D) | 10 ω, 20 ω |
38. With rise in temperature the resistance of pure metals
A) | decreases |
B) | remains constant |
C) | increases |
39. Resistance of a wire always increases if
A) | temperature is reduced. |
B) | number of free electrons available become more. |
C) | number of free electrons available become less. |
D) | temperature is increased. |
40. Varistors are
A) | insulators |
B) | non-linear resistors |
C) | carbon resistors |
D) | resistors with zero temperature coefficient |
41. In equal resistances are first connected in series and then connected in parallel.​
What is the ratio of the maximum to the minimum resistance?
A) | ​​n2 |
B) | ​​n |
C) | ​​1/n |
D) | ​​1/n2 |
42. Resistance of material always decreases if
A) | temperature of material is decreased |
B) | temperature of material is increased |
D) | number of free electrons available become more |
43. The resistance of a straight conductor does not depend upon its
A) | Length |
B) | Material |
C) | Shape of cross-section |
D) | Temperature |
44. In a circuit containing two unequal resistors connected in parallel
A) | The voltage drop is larger across larger resistances |
B) | The voltage drop is same across both the resistances |
C) | The current is larger in larger resistance |
D) | The current is same in both the resistors |
45. The specific resistance of a wire depends upon
A) | Its dimensions |
B) | Its length |
C) | Its cross-sectional area |
D) | Its material |
46. The temperature coefficient of resistance of a wire is 0.0008°C.​
If the resistance of the wire is 8 ohm at 0°C, what is the resistance at 100°C?
A) | 8.08 Ohm. |
B) | 7.92 Ohm. |
C) | 8.64 Ohm. |
D) | 7.20 Ohm |
47. A current of 16 amperes divides between two branches in parallel of resistances 8 ohms and 12ohms respectively.​
The current in each branch is
A) | 4.6A,9.6A |
B) | 6.4 A, 6.9 A |
C) | 4.6A, 6.9A |
D) | 6.4 A, 9.6 A |
48. In an ordinary heater if the length of the coil is halved, then a given quantity of water will boil
A) | More time |
B) | None of these answers |
C) | Less time |
D) | Same time |
49. Twelve 1 ω resistance are used as edges to form a cube.​
The resistance between two diagonally opposite corners of the cube is
A) | 6/5 ω |
B) | 1 ω |
C) | 5/6 ω |
D) | 3/2 ω |
50. Which of the following is an ohmic conductor?
A) | Thermionic valves |
B) | Constanton |
C) | Electrolyte |
D) | Transistors |
51. Which of the following quantities remain the same in all parts of a series circuit?
A) | Resistance |
B) | Current |
C) | Voltage |
D) | Power |
52. You have to replace 1500 ω resistor in radio.​ You have no 1500 ω resistor but have several 1000 ω ones which you would connect
A) | two in parallel and one in series |
B) | three in parallel |
C) | three in series |
D) | two in parallel |
53. An open resistor, when checked with an ohm-meter reads
A) | high but within tolerance |
B) | zero |
C) | low but not zero |
D) | infinite |
54. Two copper conductors have equal length.​
The cross-sectional area of one conductor is four times that of the other.​
If the conductor having smaller cross-sectional area has a resistance of 40 ohms the resistance of other conductors will be
A) | 20 ohms |
B) | 160 ohms |
C) | 80 ohms |
D) | 10 ohms |
55. The insulation resistance of a cable of length 10 km is 1 Mega Ohm’s.​
For a length of 100 km of same cable, the insulation resistance will be
A) | 1 Mega Ohm |
B) | 0.1 Mega Ohm |
C) | 10 Mega Ohm |
D) | 0.01 Mega Ohm |
56. The temperature coefficient of resistance of some material is negative. The material is
A) | Germanium |
B) | Iron |
C) | Aluminium |
D) | Copper |
57. The temperature coefficient of resistance of conductors is
A) | Neutral |
B) | Negative |
D) | Positive |
58. Three resistances each of R Ω are corrected to form a triangle.​ The resistance between any two terminals will be
A) | 3/2 R Ω |
B) | 3 R Ω |
C) | 2/3 R Ω |
D) | R Ω |
59. In a circuit a 33 ω resistor carries a current of 2 A. The voltage across the resistor is
A) | 66V |
B) | 132V |
C) | 33V |
D) | 80 V |
60. The example of non-ohmic resistance is
A) | Carbon resistance |
B) | Copper wire |
C) | Diode |
D) | Tungsten wire |
61. Reciprocal of specific resistance is
A) | Conductive resistance |
B) | Specific conductance |
C) | Plate resistance |
D) | Conductive reactance |
62. The resistance of a conductor varies inversely as
A) | temperature |
B) | resistivity |
C) | area of cross-section |
D) | length |
63. How are 500 ω resistors connected so as to give an effective resistance of 750ω?
A) | Three resistors of 500 ω each, in series. |
B) | Two resistors of 500 ω each, in parallel and the combination in series with another 500 ω resistor. |
C) | Three resistors of 500 ω each, in parallel |
D) | Two resistors of 500 ω each, in parallel. |
64. Three parallel resistive branches are connected across a dc supply.​
What will be the ratio of the branch currents I1 : I2 : I3 if the branch resistances are in the ratio R1 : R2 : R3 : : 2 : 4 : 6 ?
A) | 2 : 4 : 6 |
B) | 3 : 2 : 6 |
C) | 6 : 2 : 4 |
D) | 6 : 3 : 2 |
Click Here for Answers
Next Quiz:
- Batteries Multiple Choice Questions
- Transformer Multiple Choice Questions
- Motor Starters Multiple Choice Questions
- Electrical Drawings and Symbols Quiz
- Electrical Safety and Grounding Quiz
