Reading: What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Inst Tools > Blog > Electrical Basics > What is a Motor Disconnector Switch? – Purpose, Principle, Factors
A motor disconnector switch is a device used to safely disconnect a motor from its power source for maintenance or safety purposes.
Last updated: January 17, 2024 10:18 am
Electrical Basics
7 Min Read
A motor disconnector switch is a device used to safely disconnect a motor from its power source and ensure the motor is turned off completely for maintenance or safety purposes.
Motor Disconnector SwitchWhat is the purpose of using a motor disconnector switch?How does a motor disconnector switch work?Types of motor disconnector switchesFactors to consider for selecting a motor disconnector switch
A motor is a device that is required in almost all applications, be it a simple fan to a big wind turbine fan. Because it helps in moving things either in linear or rotating form, motors find a big use in many processes.
What many don’t know is that there is a device that can be used as a switch to provide power to the motor. This is called a motor disconnector switch.
A motor disconnector switch is of great use for worker safety, bringing downtime to a low value and ensuring that you have the freedom to isolate a motor from the circuit if not in use. So, it is necessary for electrical engineers to understand how does it work. In this post, we will see the concept of a motor disconnector switch.
Suppose there is a motor that is operated in auto or manual mode. Auto mode will be controlled by PLC and manual mode will have push buttons in the electrical panel for operating it.
Now, suppose the PLC has failed and the operator is now operating the motor through manual mode. But what happens if the motor only fails? And what if some operator is working near the motor and someone has accidentally pressed the start button from the panel?
In that case, the life of the operator near the motor can be endangered as any accident can happen. In that scenario, it would be better if someone had isolated the motor only from operation. This can then be done by a motor disconnector switch.
Now, you would ask that instead of separately installing it, one could have also turned off the circuit breaker of the motor. But, in an electrical panel, instead of finding the circuit breaker by reading a drawing or if the panel is located at a faraway location from the motor, it would make sense if some device is present right near the motor to turn it off. This will be done by this switch easily.
The main purpose of this switch is to thus isolate the motor connection when required and bring it back into the picture once the maintenance work has been assured. There is no concern of any live power getting in contact with the technician and any accident can thus be avoided.
Also, instead of opening a live running panel, finding an MCB and then turning it off would better make way for this method for isolating a motor.
Refer to the below image. As shown, it is made up of contact with the outside world. This contact is operated by the technician to turn on or off the power supply. This contact is usually a handle or a toggle switch.
The motor disconnector switch is mounted on an enclosure, which ensures that the operator does need not to open the panel and come in contact with any live wire inside. This handle goes inside the panel through a rod-type connection to the contactor inside. Turning on or off the switch will accordingly operate the contactor. Due to this, the motor will get its power supply accordingly.
Motor Disconnector Switch Principle
One of the main points is how is it installed. The mounting method is important because this is the technology that allows the operator to operate the motor without touching any electrical part inside. Once the switch is turned off, the motor cannot operate in any mode even if the contactor has its input supply present.
As long as the switch is off, the input supply will not be passed to the output supply of the contactor. This switch comes in a package, with a contactor and a switch mechanism. You cannot buy it separately, otherwise, there is no use in working with it.
  • Fused Disconnect Switch
  • Non-Fused Disconnect Switch
  • Rotary Disconnect Switch
  • Knife Switch
  • Load Break Switch
  • Safety Switch
  • Magnetic Disconnect Switch
  • Motor Circuit Breaker
  • Push Button Disconnect Switch
  • Toggle Disconnect Switch
1. Check the current rating of the motor disconnector switch. It must always be above the rated motor current rating. It is similar to how you select a circuit breaker.
2. The motor disconnector switch should not consume much space in the panel.
3. The motor disconnector switch should comply with certificates like EN 60947-1, EN 60947-3, IEC 60947-1, IEC 60947-3, or UL60947-4-1. This ensures that the switch is safe to use and industry standard.
4. The handle must be smooth to operate and not rigid.
5. The motor disconnector switch should be resistant to any environmental changes, or nearby surroundings, or chemical reactions.
  • What is an Electrical Conduit?
  • Single Core and Multi-Core Cables
  • Difference Between HV and LV Cables
  • Types of Cables in Industrial Automation
  • Flame Resistant and Retardant Cables
Benefits of SIMOCODE over Intelligent MCC
Design and Implement Motor Control – Electrical Engineering
Difference Between Core and Shell Transformers
Electrical Engineering Documents – Engineers Questions
What is a Semiconductor Fuse?
Current Transformer Selection, Operation & Maintenance
Difference Between Circuit Breaker and Fuse
Testing and Inspection of Bonding and Grounding Systems
Difference between Soft Starter and VFD
What is a Relay? Types of Industrial Relays
Motor STAR – DELTA Starter Working Principle
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Electrical Energy Management System and SCADA in Power System
Preventive Maintenance of Variable Frequency Drive
Electrical Link Box
What is a Link Box?
Difference Between NEMA and IEC Motors
Difference Between NEMA and IEC Motors?
What is Trunking
Difference Between Trunking and Conduit
Why Three-phase Voltage is 440 Volts
Why Three-phase Voltage is 440 Volts?
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Connection between PLC and Contactor
Silicon-Controlled Rectifier (SCR)
Introduction to Thyristor – History, Types, Principle, Advantages
Microsoft MS-200 certification
Best Preparation Tool You Can Get Online for Microsoft MS-200
H2 S and Total Sulfur Using Lead Acetate Principle
H2S Measurement Using Lead Acetate Principle
Programmable Logic Controller (PLC) Questions and Answers – 3
Emergency ShutDown Valve Working Principle
ESDV : How it Works ?
reactor vessel
Touch Potential
Methods to Reduce Step Potential and Touch Potential in Substation
Differential Pressure Transmitter Zero Suppression
Basics of DP Transmitter Suppression and Elevation
