Reading: Miniature Circuit Breakers Questions and Answers
Inst Tools > Blog > Electrical MCQ > Miniature Circuit Breakers Questions and Answers
Understand the miniature circuit breakers with our detailed MCQ questions and answers for electrical engineers and electricians.
Last updated: August 31, 2024 8:13 pm
Electrical MCQ
14 Min Read
Miniature Circuit BreakersWhat does MCB stand for in electrical systems?Which of the following is a primary advantage of using MCBs over fuses?Which component inside an MCB ensures it trips during a short circuit?What is the main purpose of an MCB’s arc chute?How do MCBs generally trip in case of an overload condition?What is a Miniature Circuit Breaker (MCB)?What is a Residual Current Circuit Breaker (RCCB)?What is a Residual Current Circuit Breaker with Overcurrent Protection (RCBO)?What is an Air Circuit Breaker (ACB)?What is a Molded Case Circuit Breaker (MCCB)?What is an Earth Leakage Circuit Breaker (ELCB)?What is a Motor Protection Circuit Breaker (MPCB)?What is a Supplementary Protector (SP)?What is a Shunt Trip Circuit Breaker?What is an Earth Fault Relay (EFR)?What is a Ground Fault Circuit Interrupter (GFCI)?What is an Arc Fault Circuit Interrupter (AFCI)?What is a Type B MCB?What is a Type C MCB?What is a Type D MCB?What is a Type K MCB?What is a Type Z MCB?What is a Type A MCB?What is the typical trip rating for a Type B MCB?How does a Type C MCB differ in trip rating from a Type B MCB?What trip rating is associated with a Type D MCB?What trip rating does a Type K MCB have?What is the trip rating for a Type Z MCB?What does the breaking capacity of an MCB indicate?Why is it important to select the correct type of MCB for different applications?What feature of MCBs makes them more user-friendly compared to traditional fuses?In an MCB, what function does the bimetallic strip perform?Which type of MCB is commonly used in industrial applications due to its high breaking capacity?What does the term ‘tripping curve’ refer to in MCB specifications?Which feature of an MCB helps in preventing electrical fires?In which scenario would a Type K MCB be most appropriately used?How does an MCB contribute to the safety of an electrical system?What type of MCB would be selected for a circuit with predominantly resistive loads?What is the tripping characteristic of an MCB that is used for general lighting circuits?Which type of MCB is best suited for protecting circuits with high inrush currents, like motors?
This below video provides the detailed explanations for the MCB questions and answers.
Miniature Circuit Breakers (MCB) - Basic Questions and Types
Question 1
A. Main Circuit Breaker
B. Modular Circuit Breaker
C. Miniature Circuit Breaker
D. Micro Circuit Breaker
Show the Answer
Question 2
A. Easier reset after tripping
B. Higher current rating
C. Faster response time
D. Lower cost
Show the Answer
Question 3
A. Arc chute
B. Bimetal strip
C. Thermal sensor
D. Electromagnetic coil
Show the Answer
Question 4
A. To trip the circuit
B. To cool and extinguish the arc
C. To detect overcurrent
D. To measure current
Show the Answer
Question 5
A. Mechanical failure
B. Electromagnetic mechanism
C. Manual operation
D. Thermal mechanism
Show the Answer
Thermal mechanism
Question 6
A. A device for overcurrent protection
B. A device for surge protection
C. A switch for turning off lights
D. A device for detecting ground faults
Show the Answer
Question 7
A. A device for regulating voltage levels
B. A device for controlling power supply
C. A device for detecting earth leakage faults
D. A device for protecting against surges
Show the Answer
Question 8
A. A device that only protects against overcurrent
B. A device for voltage regulation
C. A device for frequency modulation
D. A device combining overcurrent and residual current protection
Show the Answer
Question 9
A. A breaker used in low voltage circuits
B. A breaker used for high current interruptions
C. A device for detecting ground faults
D. A breaker for surge protection
Show the Answer
Question 10
A. A device for voltage regulation
B. A breaker with adjustable trip settings for overcurrent
C. A device for detecting high-frequency noise
D. A breaker that automatically resets
Show the Answer
Question 11
A. A device for detecting ground faults and cutting off power
B. A device for frequency regulation
C. A device for protecting against voltage surges
D. A device for detecting phase imbalances
Show the Answer
Question 12
A. A breaker that only protects against short circuits
B. A breaker for frequency modulation
C. A breaker that includes overload and phase failure protection
D. A breaker for detecting voltage surges
Show the Answer
Question 13
B. A primary protection device for high-voltage circuits
C. A device offering backup protection for control circuits
D. A device for voltage regulation
Show the Answer
Question 14
A. A breaker that automatically resets
B. A breaker for voltage regulation
C. A breaker that can be tripped remotely
D. A breaker for detecting phase imbalances
Show the Answer
Question 15
A. A device for balancing three-phase loads
B. A relay for voltage regulation
C. A device for detecting and isolating voltage surges
D. A relay for monitoring earth fault currents and tripping the circuit
Show the Answer
Question 16
B. A device for protecting against high-frequency interference
C. A device for detecting and interrupting ground faults
D. A device for balancing the load between phases
Show the Answer
Question 17
B. A device for detecting and interrupting arc faults
C. A device for ground fault protection
D. A device for protecting against voltage surges
Show the Answer
Question 18
A. A breaker for general lighting and outlet circuits
B. A breaker for circuits with high inrush currents
C. A breaker for protecting sensitive electronic devices
D. A breaker for industrial motor protection
Show the Answer
Question 19
A. A breaker with a lower operating voltage
B. A breaker with a higher trip threshold than Type B
C. A breaker with built-in surge protection
D. A breaker with a faster response time
Show the Answer
Question 20
A. A breaker for circuits with very high inrush currents
B. A breaker for low voltage lighting
C. A breaker for general household wiring
D. A breaker for earth leakage protection
Show the Answer
Question 21
A. A breaker for circuits with inductive loads
B. A breaker for low voltage residential circuits
C. A breaker for HVAC systems
D. A breaker for high precision electronic devices
Show the Answer
Question 22
A. A breaker for high inrush current circuits
B. A breaker with built-in voltage regulation
C. A breaker for general lighting and outlet protection
D. A breaker extremely sensitive to low current faults
Show the Answer
Question 23
A. A breaker for low voltage lighting circuits
B. A breaker for mixed load circuits with moderate inrush current
C. A breaker for circuits with only resistive loads
D. A breaker for high inrush current circuits
Show the Answer
Question 24
A. 5-10 times rated current
B. 3-5 times rated current
C. 1-2 times rated current
D. 10-20 times rated current
Show the Answer
Question 25
A. Trips at 5-10 times rated current
B. Trips at 1-2 times rated current
C. Trips at 3-5 times rated current
D. Trips at 10-20 times rated current
Show the Answer
Question 26
A. 10-20 times rated current
C. 5-10 times rated current
D. 1-2 times rated current
Show the Answer
Question 27
B. 2-3 times rated current
C. 3-5 times rated current
D. 8-12 times rated current
Show the Answer
Question 28
Show the Answer
Question 29
A. Maximum resistance it can provide
B. Maximum current it can interrupt safely
C. Maximum power it can manage
D. Maximum voltage it can handle
Show the Answer
Question 30
A. To comply with building codes
B. To ensure proper protection
C. To reduce electricity bills
D. To match the circuit’s color
Show the Answer
Question 31
A. Higher durability
B. Smaller size
C. Lower cost
D. Visual indication of status
Show the Answer
Question 32
A. Measures current
B. Cools the circuit
C. Indicates circuit status
D. Trips during overload
Show the Answer
Question 33
A. Type C
B. Type B
C. Type D
D. Type K
Show the Answer
Type C
Question 34
A. The voltage rating
B. The physical shape of the MCB
C. The MCB’s response to different currents
D. The installation method
Show the Answer
Question 35
A. High current rating
B. Rapid tripping mechanism
C. Compact size
D. Adjustable settings
Show the Answer
Question 36
A. Domestic lighting
B. Inductive loads with high inrush
C. Sensitive electronics
D. Low power circuits
Show the Answer
Question 37
A. By enhancing signal strength
B. By monitoring voltage fluctuations
C. By automatically disconnecting faulty circuits
D. By lowering electricity costs
Show the Answer
Question 38
A. Type B
B. Type D
C. Type C
D. Type A
Show the Answer
Type B
Question 39
A. Type C
B. Type D
C. Type B
D. Type K
Show the Answer
Type B
Question 40
A. Type D
B. Type B
C. Type C
D. Type A
Show the Answer
Type D
  • Components of MCB Questions
  • MCB Nameplate Questions and Answers
  • MCB vs Fuse Questions and Answers
  • Industrial Automation Acronyms Questions
  • Electrician Tools MCQ Questions
Electrical Machines MCQ Series 6
Electric Circuits Objective Questions – Set 1
HVAC Multiple Choice Questions
Electric Circuits Objective Questions – Set 10
264 Quiz on Electrical Drawings and Symbols
Permanent Magnet DC Motor (PMDC) Questions
Synchronous Machines Power Angle Characteristics Questions
Electrical Welding Multiple Choice Questions and Answers (MCQ)
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
Top 300 Electricity and Magnetism Questions & Answers
175+ Transmission and Distribution Objective Questions and Answers
100 Electromagnetic Motor Starters Multiple Choice Questions
Electrical Machines MCQ Series 7
Electric Circuits Objective Questions – Set 7
Electrical Machines MCQ Series 5
Electrical Switch Questions and Answers
Top 50 Electrical Switch Questions and Answers
Alternator Objective Questions and Answers
125+ Alternator Objective Questions and Answers
Reluctance Motor Quiz
Electric Circuits Objective Questions – Set 17
DC Machine Quiz
Induction Motors Operating Characteristics Questions
DC Motors Objective Questions and Answers
175+ DC Motors Objective Questions and Answers
Microwave Barrier Level Switch Working Principle
Modern Instrumentation and Control Systems
buoyancy level transmitter
Displacer Level Transmitter Question & Answer
remote seal capillary type dp transmitter
flow Nozzle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
Jackshaft Belt Drive
Poorly Engineered, built & often Failing Plant Air Compressor Drives
