Mechanical Mini Projects List: top engineering project ideas for your final year students project selection.
S.No. | Mechanical Projects |
1 | Toggle Type Punch Machine Development |
2 | Pneumatic Grinding Machine Development |
3 | Hydro-Powered Sump Pump |
4 | Pneumatic Hacksaw Machine Engineering |
5 | Solar-Powered Water Distillation Unit |
6 | Pneumatic Can Crusher Construction |
7 | Pneumatic Multi-Axis Tilting Platform |
8 | Parallel Jaw Movable Vice Design and Fabrication |
9 | Compact and Efficient Water Purifier |
10 | Boring Fixture: Design and Production Strategy |
11 | Screw Less Vice: Design & Production |
12 | Solar-Powered Autonomous Boat for Research |
13 | Multi Axis Tilting Platform: Pneumatic Design |
14 | Design and Fabrication of a Tidal Energy Harvester |
15 | Triple Shaft Welding Fixture Design |
16 | Hydraulic Sheet Cutting Machine for G.I Sheet Fabrication |
17 | Gang Milling Fixture Design and Fabrication |
18 | Solar-Powered Portable Welding Machine |
19 | Pneumatic Holding Gripper Engineering |
20 | Constructing an Angle Plate Jig |
21 | Holes Boring Fixture: Design and Fabrication |
22 | Wooden Bench Vice Design and Fabrication |
23 | Pneumatic Bending-Bend Removing Machine |
24 | Open Type Screw Vice Engineering |
25 | Lathe Abrasive Belt Grinding Attachment Development |
26 | Connecting Rod Boring Fixture for Jig Boring Machine |
27 | Hydraulic Pipe Vice: Design and Fabrication |
28 | Water Filtration System using Renewable Energy |
29 | Shock Absorber Based Power Generation Design |
30 | Pneumatic Sheet Metal Cutting Machine |
31 | High-Efficiency Particulate Air (HEPA) Filter Manufacturing Unit |
32 | Hydraulic Metal Rod Bending Machine Design |
33 | Pneumatic Bearing Pressing Machine Construction |
34 | Compact E-Waste Shredding Machine |
35 | Eccentric Cam Vice: A Design and Fabrication Approach |
36 | Heat Recovery System from Industrial Exhaust |
37 | Open Type Screw Vice Fabrication |
38 | Automated Packaging System for Pharmaceuticals |
39 | Hand Operated Pipe Bending Machine: Hydraulic Operated |
40 | Unconventional Compressor for Heavy Truck (Demo Model) |
41 | Threading Clamp Design and Fabrication |
42 | Hydraulic Tail Stock Engineering |
43 | Cam Based Punching Machine Development |
44 | Pneumatic Bending/Bend Removing Machine |
45 | Compact and Mobile Surface Cleaning System |
46 | Solar-Powered Automatic Lawn Mower |
47 | Equalizer Clamp Engineering |
48 | Slotted Method Drilling Machine Fabrication |
49 | Remote Operated Floor Cleaner Development |
50 | Acrylic Sheet Bending Machine: Pneumatic Design |
51 | Manual Roller Bending Machine Design |
52 | Zig Saw Cutting Machine Fabrication |
53 | Solar-Powered Portable Air Cooler |
54 | Zig Saw Cutting Machine Fabrication |
55 | Portable and Foldable Camping Stove |
56 | Shock Absorber Based Power Generation Design |
57 | Robotic Textile Material Handler |
58 | Simple Pipe Clamp for Table Top: Design & Fabrication |
59 | Multi-Spindle Drill Head Engineering |
60 | Hydraulic Fork Lift for Industries Fabrication |
61 | Hinged Edge Angle Vice: Design and Build |
62 | Design and Fabrication of a Solar-Powered Car |
63 | Pneumatic Bending Machine Fabrication |
64 | Remote Operated Floor Cleaner Development |
65 | Drilling Vice: Design and Build |
66 | Design and Fabrication of a Hydrofoil Surfboard |
67 | Pneumatic Punching Machine Development |
68 | Automated Plant Watering System |
69 | Pneumatic Operated Stapler Machine Fabrication |
70 | Perpendicular Clamp: V Type Design & Fabrication |
71 | Design and Fabrication of Pneumatic Door Opener |
72 | V Type Perpendicular Clamp Engineering |
73 | Pneumatic Multi Purpose Grinding Machine |
74 | Automated Glass Cleaning System for Skyscrapers |
75 | Finger Clamp Design and Production |
76 | Quick Action Drill Press Vice Design |
77 | Solar-Powered Refrigerated Transport System |
78 | Bench Tapping Machine Fabrication |
79 | Triple Shaft Holding Fixture for Cutting Operation |
80 | Holding and Polishing Vice Engineering |
81 | Compact Garbage Compactor for Urban Areas |
82 | Mini Conveyor Using Geneva Mechanism |
83 | Gang Milling Fixture Development and Construction |
84 | Palm Cup Making Machine: Hydraulic Design |
85 | Pneumatic Paint Mixer and Dispenser |
86 | Quick Releasing Vice with Self Locking Mechanism |
87 | Robotic Assistant for Elderly Care |
88 | Y Joint Welding Fixture Design |
89 | Hydraulic Pipe Clamp Pressing Machine Construction |
90 | Motorized Screw Jack Design and Fabrication |
91 | Geneva Mechanism Based Punching Machine |
92 | Geneva Mechanism Based Punching Machine |
93 | Safety Clamp: Design & Fabrication |
94 | Design of Compact Modular Furniture |
95 | Motorized Screw Jack Construction |
96 | Knife Boring Fixture: Design & Fabrication |
97 | Pneumatic Braking System Development |
98 | Swivel Vice for Horizontal Milling Design and Fabrication |
99 | Pneumatic Bending Machine Engineering |
100 | Pneumatic Jigsaw Machine for Crafts |
101 | Swinging Strap Clamp Engineering |
102 | Compact CNC Plasma Cutting Machine |
103 | Pneumatic Can Crusher Construction |
104 | Advanced Gearbox Reconditioning Machine |
105 | Robotic System for Hazardous Material Handling |
106 | Toggle Clamp Design and Fabrication |
107 | Motorized Mechanical Jack with Remote Control Design |
108 | Automated Grass Cutter with Obstacle Detection |
109 | Design and Fabrication of a Magnetic Levitation Device |
110 | Dual Vice-DWG Development |
111 | Regular Profile Component Channel Jig Engineering |
112 | Acrylic Sheet Bending Machine: Pneumatic Design |
113 | Portable Gantry Crane for Workshops |
114 | Power Activated Toggle Clamp Engineering |
115 | Mechanical Pipe Vice: Design & Fabrication |
116 | Automated Solar-Powered Trash Compactor |
117 | Automated Ball Sorting Machine |
118 | Design and Fabrication of a Smart Helmet |
119 | Automatic Pneumatic Bumper Adjustment Mechanism |
120 | Conventional Lathe Key Way Attachment Design |
121 | Screw Type Puller: A Mechanical Design Project |
122 | High-Efficiency Solar Cooker with Storage |
123 | Compact Solar-Powered Oven for Outdoor Cooking |
124 | Solar-Powered Atmospheric Moisture Harvester |
125 | Split Pin Making Machine Design |
126 | Fast Action Bench Vice Design and Fabrication |
127 | Pneumatic Punching Machine Development |
128 | Hydraulic Metal Rod Bending Machine Design & Fabrication |
129 | Hydraulic Operated Lifting Table |
130 | Geneva Motor Punching-Wheel Engineering |
131 | Right-Angled Holding Welding Clamp Design |
132 | Pneumatic Multi-Purpose Grinding Machine |
133 | Design of a Compact Portable Shelter |
134 | Pneumatic Bending-Bend Removing Machine |
135 | Design and Fabrication of an Electric Tug for Airports |
136 | Fabrication of a Compact Benchtop Lathe |
137 | Split Pin Making Machine Design |
138 | Automated Double Hacksaw Project |
139 | Dual Vice-DWG Development |
140 | Pneumatic Jack for Four Wheeler Fabrication |
141 | Fabrication of a Small Scale Cement Mixer |
142 | Fabrication of Pneumatic Vice and Jack |
143 | Sandwich Jig: Design and Production |
144 | Toggle Clamp Design & Fabrication |
145 | Pneumatic Jack for Four Wheeler: Design & Fabrication |
146 | Solar-Powered Automated Irrigation System |
147 | Heavy Duty Pneumatic Vice for Operation |
148 | Pneumatic Bearing Pressing Machine Creation |
149 | Triple Shaft Welding Fixture Design |
150 | Tilting Vice for Angular Milling Design |
151 | Automated Brick Manufacturing Machine |
152 | Motorized Mechanical Jack with Remote Control Fabrication |
153 | Dual Mode Fixture for Various Machining Operation |
154 | Pedal Hacksaw for PVC Pipe Fabrication |
155 | Pneumatic Bending/Bend Removing Machine |
156 | Pneumatic Operated Stapler Machine Fabrication |
157 | Pneumatic Vice and Jack Fabrication |
158 | Strap Clamp Design & Fabrication |
159 | Robotic Arm for Precision Assembly |
160 | Right-Angled Holding Welding Clamp Design |
161 | Automated Solar Water Heating System |
162 | Fabrication of a Miniature Chain Saw |
163 | Mechanical Pipe Vice: Design & Fabrication |
164 | Advanced Grinding Fixture Development |
165 | Design and Fabrication of a Portable Sauna |
166 | Leaf Jig for Contour Profile Component Fabrication |
167 | Solar-Powered Compact Street Sweeper |
168 | Motorized Variable Speed Belt Drive Fabrication |
169 | Motorized Variable Speed Belt Drive Fabrication |
170 | Strap Clamp Design and Fabrication |
171 | Screw Less Vice Design & Production |
172 | Geneva Motor Punching-Wheel Engineering |
173 | Hydraulic Pipe Clamp Pressing Machine Construction |
174 | Unconventional Compressor for Heavy Truck (Demo Model) |
175 | Triple Shaft Holding Fixture for Cutting Operation |
176 | Hydraulic Pipe Bending Machine Creation |
177 | Shaping-Fixture for Cylindrical Rod Design |
178 | Fabrication of an Electric Potter’s Wheel |
179 | Threading Clamp Design & Fabrication |
180 | Hydraulic Tail Stock Engineering |
181 | Acrylic Sheet Bending Machine: Pneumatic Version |
182 | Pneumatic Lifting Table Engineering |
183 | Pneumatic Holding Gripper Development |
184 | Circular Flange Components: Channel Jig Fabrication |
185 | Pneumatic Braking System Design |
186 | Design of a Wave-Powered Boat |
187 | Pneumatic Forging Machine Design |
188 | Surface Grinding Fixture for Shearing Blade |
189 | Fabrication of an Electric Snow Melter |
190 | Angle Vice for Horizontal Milling: Design and Build |
191 | Grinding Angle on Threading Tool Design |
192 | High-Speed Engraving Machine with Precision Control |
193 | Pneumatic Shaping Drawing Production |
194 | Development of Angle Holding Double Jaw Vice |
195 | Design and Fabrication of a Miniature Bowling Machine |
196 | Compact Road Repair Machine |
197 | Automated Coin Sorting and Counting Machine |
198 | Welding Fixture for a Single Door-Frame |
199 | High-Speed Sheet Cutting Machine: Automatic Pneumatic Design |
200 | Fabrication of a Portable Biogas Plant |
201 | Solar-Powered Street Light with Motion Sensor |
202 | Swinging Strap Clamp Engineering |
203 | Multi Axis Modular Fixture Engineering |
204 | Unprotected Split Type Rigid Coupling: A Fabrication Project |
205 | Solar-Powered Livestock Management System |
206 | Pneumatic Drill Jig for Reducing Lead Time |
207 | Design and Fabrication of an Ice-Making Machine |
208 | Automated Fruit Sorting and Packaging System |
209 | Fabrication of a Miniature Jet Engine |
210 | Mini Conveyor Using Geneva Mechanism |
211 | Hydraulic Tail Stock Design and Fabrication |
212 | Parallel Jaw Movable Vice: Design & Fabrication |
213 | Solar-Powered Electric Fence for Agriculture |
214 | Tyre Coupling Fabrication |
215 | High-Pressure Pneumatic Machine Vice Fabrication |
216 | Compact and Portable Dishwasher |
217 | Symmetrical Cam Vice: Constructing and Designing |
218 | Key Way Attachment for Conventional Lathe Design |
219 | Manual Roller Bending Machine Design |
220 | Hybrid Manual-Electric Vehicle |
221 | High-Efficiency Wood Pellet Stove Design |
222 | Design and Fabrication of a Portable Crane |
223 | Quick Releasing Vice with Self-Locking Mechanism |
224 | Multi Process Cutter Development |
225 | Sensor Operated Pneumatic Automatic Punching Machine |
226 | Pneumatic Operated Robotic Arm |
227 | Hydraulic Angle Forming Machine Construction |
228 | Portable Hydraulic Lift for Automobiles |
229 | Heavy Duty Pneumatic Vice for Robust Operations |
230 | Hardness Testing Fixture Design & Fabrication |
231 | Flexible Hinged Clamp: Design and Construction |
232 | Y Joint Welding Fixture Design |
233 | Bench Tapping Machine Fabrication |
234 | Spider Clamp: Design & Fabrication |
235 | Fabrication of a Mini Hydraulic Press |
236 | Design of an Efficient Leaf Collector |
237 | Pipe Alignment Clamp: Design and Creation |
238 | Power Activated Toggle Clamp Engineering |
239 | Design and Fabrication of a Folding Bicycle |
240 | Safety Clamp Design and Fabrication |
241 | Surface Grinding Fixture for Shearing Blade |
242 | Glass Hole Drilling Machine Fabrication |
243 | Pneumatic Forging Machine Fabrication |
244 | Vertical Wind Turbine for Urban Applications |
245 | Automated Paper Recycling Machine |
246 | Design and Fabrication of a Personal Watercraft |
247 | Grinding Fixture Engineering |
248 | Underwater Surveillance System with Robotic Fish |
249 | Automated Soil Aeration Machine |
250 | Compound Vice with Pipe Holding Arrangement Design |
251 | Box Jig Design and Manufacturing Process |
252 | Multi-Spindle Drill Head Creation |
253 | Pneumatic Hacksaw Machine Creation |
254 | Pneumatic Forging Machine Fabrication |
255 | End Mill Grinding Fixture Design & Production |
256 | Spider Clamp Design and Fabrication |
257 | Pneumatic Shaping Drawing Production |
258 | Pneumatic Grinding Machine Fabrication |
259 | Gear & Spline Cutting Attachment in Lathe Design |
260 | Turn Over Table Type Drill Jig Engineering |
261 | Leaf Type Hinged Edge Clamp Construction |
262 | Pneumatic Acrylic Sheet Bending Machine Development |
263 | Foot Dust Vacuum Cleaning Machine Engineering |
264 | Multi-Axis Modular Fixture Engineering |
265 | Slotted Method Drilling Machine Fabrication |
266 | Automatic Pneumatic Bumper Adjust Mechanism |
267 | Shaping Fixture for Cylindrical Rod Design |
268 | Automated Bottle Capping and Labeling Machine |
269 | Modular Workbench for Variable Industrial Tasks |
270 | Automated Seed Planter and Soil Tester |
271 | Design and Creation of Multi-Process Cutter |
272 | Automated Double Hacksaw Project |
273 | Cylindrical-Sheet Forming Machine Engineering |
274 | Design and Fabrication of a Hoverboard |
275 | Reciprocating Water Pump Operation by Pedaling |
276 | Indexing Drill Jig for Inclined Profile Component |
277 | Pneumatic Powered Metal Sheet Bender |
278 | Hydraulic Puller Design and Engineering |
279 | Design and Fabrication of a Vertical Axis Mixer |
280 | Pedal-Powered Hacksaw for PVC Pipe |
281 | Robotic System for Precision Painting |
282 | Automated Wire Straightening and Cutting Machine |
283 | Fabrication of a Miniature Rock Climber |
284 | Robotic Aid for Disabled Individuals |
285 | Design and Fabrication of a Miniature Archimedes Screw |
286 | Pneumatic Drill Jig for Efficient Workflows |
287 | Automated Guided Cart for Material Transfer |
288 | Tilting Vice for Angular Milling: Design & Fabrication |
289 | Precision Temperature Control System for Industrial Ovens |
290 | Creating an Angle Type C Clamp |
291 | Automated Road Marking Machine |
292 | Hand Operated Edge Folding Machine Construction |
293 | Automated Soil Compaction Machine |
294 | Fabrication of a Wave Energy Harnessing Device |
295 | Automobile Pneumatic Clutch System Design |
296 | Hydraulic Tail Stock Design and Fabrication |
297 | Wooden Bench Vice Design & Fabrication |
298 | Wind-Powered Water Aeration System |
299 | Manual Hydraulic Grease Gun for Industries Construction |
300 | Pneumatic Forging Machine Design |
301 | “J” Type Pipe Clamp Design & Fabrication |
302 | Solar-Powered Night Vision Security Camera |
303 | Wedge Type Clamp Design & Production |
304 | Design and Fabrication of a Biodiesel Processor |
305 | Pneumatic Auto Feed Drilling Machine |
306 | Single Door-Frame Welding Fixture Design |
307 | Tyre Coupling Fabrication |
308 | Pedal-Powered Reciprocating Water Pump |
309 | Wedge Type Clamp Design and Production |
310 | Automated Window Cleaning Robot |
311 | Pneumatic Door Opener Design |
312 | Table Top Simple Pipe Clamp Design |
313 | Toggle Type Punch Machine Development |
314 | Three-Way C Clamp Vise Edging Clamp Fabrication |
- Agriculture Engineering Projects List​
- LED Projects for Electronics Students
- Automobile Engineering Projects
- Renewable Energy Projects for Students
- Mechanical Engineering Fabrication Projects
