Reading: Making Multi Way Switches using PLC
Inst Tools > Blog > PLC Tutorials > Making Multi Way Switches using PLC
Last updated: March 4, 2021 3:51 pm
3 Min Read
This is PLC Program for Making multi-way switches using PLC
Multi Way Switches using PLCSolutionList of Inputs/OutputsLadder diagram for PLC Multi-way SwitchesPLC Ladder Logic Description
We need to make multi-ways switches using PLC. Write the PLC program for the application using ladder diagram language.
Solution
Here we can consider two types of lamp for explanation so we can easily understand the concept.
For explanation purpose we can considered two locations and three locations of the switches installation.
Lamp 1 can be operated from the two different locations and the lamp 2 can be operated from the three different location.
List of Inputs
  • I1 :- SW1
  • I2 :- SW2
  • I15 :- SW3
  • I16 :- SW4
  • I10 :- SW5
List of Outputs
  • Q1 :- LAMP 1
  • Q2 :- LAMP 2
M memory
  • Memory coil :- M1
PLC Switch Control Logic
Network 1 :-
In this network we have used OR connection of switches SW1 and SW2 so LAMP 1(Q1) can be operated from two different locations.
Network 2 :-
Here we used OR gate logic of two switches SW3 and SW4 so memory coil (M1) can be operated from two different locations.
Network 3 :-
In this network we have used OR logic for two different types of locations. Here total three locations, but out of them, two locations are on first floor and third location of the switch in remote area. So LAMP 2 (Q2) can be operated by operating any one switch from three switches.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple multi-way switches making using PLC, we can use this concept in other examples also.
All parameters and graphical representations considered in this example are for explanation purpose only, parameters or representation may be different in actual applications. Also all interlocks are not considered in the application.
Author : Bhavesh
What is Ladder Diagram ?
PLC Traffic Light Control
Inductive Proximity Switch
PLC Sensor Scaling & Offset
How to Connect Proximity Switch
Types of PLC
Batch Simulator PLC Example Program using LogixPro Simulator
PLC based Automatic Bell System for a School
What is Fail-safe in Siemens PLC?
  • Md.Salim says:
    April 10, 2020 at 6:40 pm
    Thanks. …
How to Configure PID in Siemens PLC?
STL Programming – SET, RESET, ASSIGN
PLC Simulator using Excel
Modbus Communication between PLC and Energy Meter
CX-Programmer Products Sorting & Counting – Omron PLC
Garage Door Roller Shutter
Free Omron PLC Programming Course in HINDI
Elevator PLC Ladder Logic
Automating Car Parking with Advanced PLC Logic
Do’s and Don'ts in PLC
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
Siemens PLC Write Protection
How to Protect Siemens PLC using Password?
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
Difference Between Normal Counters and Fast Counters - PLC Basics
Difference Between Normal Counters and Fast Counters – Learn PLC
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Fieldbus Flow Transmitter Configuration
statuses of all lamps and relay coils in the circuit
Analyze the Relay Circuit and Find the Status ?
Capacitance Level Switch Working Principle
Programmable Logic Controller (PLC) Questions and Answers – 3
Differential Pressure Switch Calibration Procedure - Copy
Relay Parts
Difference Between NO and NC Contacts
