Reading: Liapunov’s Stability Criterion – Part I
Inst Tools > Blog > Multiple Choice Questions > Liapunov’s Stability Criterion – Part I
6 Min Read
1. If the system is asymptotically stable irrespective that how close or far it is from the origin then the system is:
a) Asymptotically stable
b) Asymptotically stable in the large
c) Stable
d) Unstable
Answer: b
Explanation: For the good control system system must be stable and if the system is asymptotically stable irrespective that how close or far it is from the origin then the system is asymptotically stable in large.
2. A system is said to be locally stable if:
a) The region S (e) is small
b) There exist a real number >0 such that || x (t0) || <=r
c) Every initial state x (t0) results in x (t) tends to zero as t tends to infinity
d) They are unstable
Answer: a
Explanation: By the definition of Liapunov’s stability criteria a system is locally stable if the region of system is very small.
3. The system is asymptotically stable at the origin if :
a) It is stable
d) It is unstable
Answer: d
Explanation: By the definition of Liapunov’s stability criteria the system is asymptotically stable at the origin if there exist a real number >0 such that || x (t0) || <=r and every initial state x (t0) results in x (t) tends to zero as t tends to infinity .
4. The system is asymptotically stable in the large at the origin if :
a) It is stable
d) Both a and c
Answer: d
Explanation: By the definition of Liapunov’s stability criteria the system is asymptotically stable in the large at the origin if there exist a real number >0 such that || x (t0) || <=r and every initial state x (t0) results in x (t) tends to zero as t tends to infinity.
5. The stability of non-linear systems:
a) Disturbed steady state coming back to its equilibrium state
b) Non-linear systems to be in closed trajectory
c) In limit cycles that is oscillations of the systems
d) All of the mentioned
Answer: d
Explanation: For the stability of non-linear systems as they differ from the linear systems as they have disturbed state coming back to its equilibrium and in closed trajectory and in limit cycles that is oscillations in the system.
6. The direct method of Liapunov is :
a) Concept of energy
b) Relation of stored energy
c) Using the equation of the autonomous systems
Answer: d
Explanation: Liapunov has two methods as direct and indirect and the direct method of Liapunov is using concept of energy, relation of stored energy and using the equation of the autonomous systems.
7. The results for the energy :
a) Energy of the system is non-negative
b) Energy of the system decreases as t increases
c) Energy is non-negative and decreases as t increases
d) Energy is negative
Answer: c
Explanation: Energy is defined as the work done or force which produces certain displacement and the results for the energy are that energy of the system in non-negative and it decreases as t increases.
8. The visual analogy of the Liapunov energy description is:
a) Ellipse
b) Circle
c) Square
d) Rectangle
Answer: a
Explanation: For the results of the Liapunov energy the loci is traced by the Liapunov energy description and is a ellipse.
9. The idea that the non-negative scalar functions of a system state can also answer the question of stability was given in Liapunov function:
a) True
b) False
Answer: a
Explanation: The stability of the liapunov function can be determined with the help of the scalar functions of a system state.
10. The method of investigating the stability using Liapunov function as the ________________
a) Direct method
b) Indirect method
c) Not determined
d) Always unstable
Answer: a
Explanation: Liapunov’s stability is the major factor of the autonomous functions and it can be determined with the help of the direct method.
Gas Chromatography Questions & Answers
State Variable Analysis – Part I
Tuning of PID Controllers
Top 1000 Analytical Instrumentation Questions & Answers
Controllability & Observability
Linear Approximation of the Non-Linear System MCQ
Pumps Quiz
Parameter Optimization : Servomechanims
Measurement and Instrumentation Objective Questions – Part 4
Signal Flow Graphs Objective Questions
X-Ray Diffractometers Questions & Answers
State Models for Linear Continuous Time Systems
Inductively Coupled Plasma Mass Spectrometer
Hydrocarbons Questions & Answers
pH Measurement Questions & Answers
Liquid Chromatography Questions & Answers
Digital Control Systems
Compensation Techniques : Control Systems
Silica Analyzer Questions & Answers
Advances in Control System
Neural Networks
Analyzers Based on Gas Density Questions & Answers
Loop-powered 4-20 mA transmitter
Loop-powered 4-20 mA Transmitter Circuit Voltage drop
Digital Electronics Objective Questions – Set 4
Split Range in Foundation Fieldbus
Foundation Fieldbus Split Range Valves
Power Systems MCQ Series 16
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
RTD with Thermowell
Temperature Sensor Accessories
Parity Generators Objective Questions
PlantPAx DCS
Introduction to PlantPAx Distributed Control System
