Reading: Intrinsically Safe Barriers Questions and Answers
Inst Tools > Blog > Control Systems MCQ > Intrinsically Safe Barriers Questions and Answers
Learn critical questions and answers about intrinsically safe barriers to ensure safe operations in hazardous locations.
Last updated: August 31, 2024 8:18 pm
Control Systems MCQ Instrumentation MCQ PLC Tutorials
16 Min Read
Intrinsically Safe BarriersWhat is a safety barrier in the PLC systems?What is the primary purpose of a barrier in a PLC system?How does a Zener barrier function in a PLC system?In which type of area is an intrinsic safety barrier most critical in a PLC?What is a key difference between a Zener barrier and a galvanic isolator in a PLC system?What is the main advantage of a galvanic isolator over a Zener barrier?What is the primary difference between a passive and an active safety barrier in a PLC system?Which standard typically governs the use of intrinsic safety barriers in PLC systems?What is a key consideration when installing a safety barrier in a PLC system within an explosive environment?In a PLC system, why might you choose to use an intrinsic safety barrier instead of a standard fuse?How does a barrier ensure the safety of both personnel and equipment in a PLC system?What happens if a Zener barrier in a PLC system is not properly grounded?What key factor must be considered when selecting a Zener barrier for a PLC system?What is a typical application of galvanic isolators in PLC systems?Which of the following describes a limitation of intrinsic safety barriers?Why might an intrinsically safe PLC system require certification?How does the grounding of a Zener barrier affect its operation in a PLC system?What is the main reason for using barriers in PLC systems within hazardous environments?Which of the following is NOT a typical feature of an intrinsic safety barrier?Which environment would most likely NOT require the use of a safety barrier in a PLC system?What is the role of a resistor in a Zener barrier within a PLC system?In a PLC system, what might happen if a Zener diode in a Zener barrier fails?What could be a consequence of installing a barrier with an incorrect voltage rating in a PLC system?Which type of barrier would be most suitable for a PLC system in a highly corrosive environment?How does an optical isolator differ from a Zener barrier in a PLC system?In what scenario is the use of a galvanic isolator preferred over a Zener barrier in a PLC system?What is a common characteristic of all intrinsic safety barriers used in PLC systems?What is the primary function of a current-limiting resistor in an intrinsic safety barrier?Why are optical isolators considered highly reliable in PLC systems?How does a Zener barrier protect a PLC system during a fault condition?Which factor is crucial when installing a Zener barrier in a hazardous area?What is a characteristic of an active barrier in a PLC system?How does a passive barrier function in a PLC system?How do isolation amplifiers provide safety in PLC systems?What is the primary role of surge protection barriers in a PLC system?In what type of communication system are Fieldbus barriers typically used?What is a primary advantage of using Zener barriers in hazardous environments?What is a disadvantage of galvanic isolation barriers compared to Zener barriers?What is a disadvantage of surge protection barriers in PLC systems?What is an advantage of Fieldbus barriers in industrial communication systems?What is a common mistake when wiring galvanic isolation barriers in PLC systems?Why is it important to avoid long cable runs when wiring diode safety barriers?What should be considered when routing cables for intrinsic safety barriers in hazardous areas?How should a surge protection barrier be wired in relation to sensitive equipment?
The below video provides the detailed explanations for the intrinsic safe related questions in the control systems.
Question 1
A. A component that increases voltage for signals
B. A device that limits energy to prevent hazards
C. A tool used to enhance PLC programming
D. A sensor used for detecting system faults
Show the Answer
Question 2
A. To provide electrical isolation
B. To reduce power consumption
C. To prevent overloading
D. To ensure consistent signal strength
Show the Answer
Question 3
A. By providing current amplification
B. By regulating voltage
C. By enhancing signal frequency
D. By clamping voltage to a safe level
Show the Answer
Question 4
A. Utility areas
B. Hazardous areas
C. Offsite areas
D. Non-hazardous areas
Show the Answer
Hazardous areas
Question 5
A. Galvanic isolator increases signal strength
B. Zener barrier enhances current flow
C. Zener barrier isolates through a diode, galvanic uses a transformer
D. Galvanic barrier isolates through a diode, zener uses a transformer
Show the Answer
Question 6
A. Simpler design
B. Cheaper cost
C. No need for grounding
D. Higher current capacity
Show the Answer
Question 7
A. Passive barriers use transformers
B. Active barriers require external power
C. Active barriers increase voltage levels
D. Passive barriers amplify signals
Show the Answer
Question 8
A. ISO 9001
B. IEC 60079
C. IEEE 802.3
D. IEC 61508
Show the Answer
IEC 60079
Question 9
A. Reducing system redundancy
B. Ensuring proper grounding and bonding
C. Maximizing data transmission speed
D. Minimizing installation time
Show the Answer
Question 10
A. To simplify the circuit design
B. For higher current tolerance
C. To prevent ignition in hazardous areas
D. To save space
Show the Answer
Question 11
A. By boosting signals
B. By increasing power
C. By filtering noise
D. By limiting energy transfer
Show the Answer
Question 12
A. The system operates normally
B. The barrier fails to protect the hazardous area
C. The barrier reduces signal strength
D. It enhances the circuit’s performance
Show the Answer
Question 13
A. Signal frequency
B. Voltage rating
C. Color coding
D. Physical size
Show the Answer
Voltage rating
Question 14
A. Boosting power in circuits
B. Protecting against power surges
C. Isolating control signals in hazardous environments
D. Enhancing data transmission speed
Show the Answer
Question 15
A. They cannot be used in non-hazardous areas
B. They increase the power in a circuit
C. They are ineffective in preventing noise interference
D. They limit the amount of energy in a circuit
Show the Answer
Question 16
A. To improve system speed
B. To enhance energy efficiency
C. To ensure compliance with safety regulations
D. To reduce maintenance costs
Show the Answer
Question 17
A. It improves the speed of data transmission
B. It reduces the power consumption of the system
C. It allows excess voltage to be safely discharged
D. It increases the barrier’s signal strength
Show the Answer
Question 18
A. To reduce the system’s energy consumption
B. To prevent the ignition of explosive materials
C. To enhance signal processing
D. To improve system reliability
Show the Answer
Question 19
A. Amplifying signals
B. Regulating voltage
C. Providing fault protection
D. Limiting current
Show the Answer
Amplifying signals
Question 20
A. Chemical plants
B. Gas plants
C. Oil refineries
D. Residential automation
Show the Answer
Question 21
A. To boost voltage levels
B. To limit current flow
C. To amplify the signal
D. To enhance communication speed
Show the Answer
Question 22
A. Current flow is enhanced
B. Overvoltage protection is lost
C. Signal strength increases
D. The circuit is shorted and current flow will be stopped
Show the Answer
Question 23
A. Enhanced data accuracy
B. Potential failure to protect against overvoltage
C. Increased communication speed
D. Improved system efficiency
Show the Answer
Question 24
A. Zener barrier
B. Optical isolator
C. Intrinsic safety barrier
D. Galvanic isolator
Show the Answer
Galvanic isolator
Question 25
A. It enhances current flow
B. It uses light for signal transmission
C. It requires a ground connection
D. It uses Zener diode for signal transmission
Show the Answer
Question 26
A. When space is limited
B. When there is significant electrical noise
C. When high current flow is required
D. When cost is the primary concern
Show the Answer
Question 27
A. They require no maintenance
B. They increase system power
C. They amplify control signals
D. They limit energy in circuits
Show the Answer
Question 28
A. To reduce power consumption
B. To boost signal clarity
C. To prevent excessive current flow
D. To regulate voltage levels
Show the Answer
Question 29
A. They enhance system speed
B. They require no power source
C. They increase current flow
D. They are immune to electromagnetic interference
Show the Answer
Question 30
A. By amplifying the signal
B. By diverting excess energy to ground
C. By disconnecting the circuit
D. By increasing voltage
Show the Answer
Question 31
A. Color coding
B. Proximity to other equipment
C. Correct grounding
D. Operating temperature
Show the Answer
Correct grounding
Question 32
A. It enhances energy flow
B. It requires external power to operate
C. It simplifies circuit connections
D. It passively reduces current
Show the Answer
Question 33
A. It increases signal speed
B. It amplifies signals
C. It requires external power to operate
D. It passively limits voltage and current without external power
Show the Answer
Question 34
A. By increasing voltage output
B. By boosting current
C. By reducing power consumption
D. By providing electrical isolation between circuits
Show the Answer
Question 35
A. To reduce current flow
B. To increase signal speed
C. To prevent overvoltage from damaging equipment
D. To isolate circuits
Show the Answer
Question 36
A. Digital fieldbus networks
B. Analog communication
C. Serial communication
D. Wireless communication
Show the Answer
Question 37
A. High signal amplification
B. Simple design and cost-effectiveness
C. Requires no grounding
D. Enhances data speed
Show the Answer
Question 38
A. Lower reliability
B. Increased installation complexity and cost
C. Requires constant maintenance
D. Higher susceptibility to noise
Show the Answer
Question 39
A. They do not protect against continuous overvoltage conditions
B. They are less effective in non-hazardous areas
C. They cannot handle high current loads
D. They increase system speed
Show the Answer
Question 40
A. They amplify voltage
B. They are immune to electrical noise
C. They simplify wiring and reduce installation costs
D. They increase signal speed
Show the Answer
Question 41
A. Using shielded cables
B. Using too many wires
C. Wiring it in series with power supplies
D. Connecting the ground on both sides of the isolator
Show the Answer
Question 42
A. It increases signal clarity
B. It reduces voltage drop
C. It avoids potential capacitance and inductance issues
D. It simplifies installation
Show the Answer
Question 43
A. Using the thinnest cables available
B. Keeping them separate from non-IS cables
C. Keeping them separate from IS cables
D. Proximity to high-voltage cables
Show the Answer
Question 44
A. Directly into the power source
B. At the far end of the power line
C. In series with the equipment
D. In parallel to the equipment
Show the Answer
  • Zener Diode Barrier Principle
  • Zener Diode Voltage Regulators
  • Isolators and Barriers in Electrical Panel
  • What is a Signal Isolator? Principle
  • Safety Control Circuits – PLC Example
Siemens PLC programming: BCD, Integer, Double Integer, Real
PLC Based Product Sorting Machine System – Lift Control
PLC Timers Program
Basics of Loop Checks
Case Statement in SCL Language
Timers using Statement List (STL) PLC Programming
One Shot Rising PLC Example Program
100+ Questions and Answers on Industrial Automation and Control
Structured Text PLC Code for Sequential Process Data Storage
PLC Automatic Control of Two Outputs with one Input
Types of Noise in Electronics
How to Simplify PLC Coding Using Karnaugh Maps?
Real-time and historical SCADA Trends
What are Trends in SCADA?
Job Skills Required for Industrial Electrical Maintenance
Flow Measurement Objective Questions
PLC Project Examples for EcoStruxure Machine Expert
PLC Control Panel
Inside the PLC Control Panel: How Much Do You Know?
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
Two solenoid valves circuit
Solenoid Valves Questions & Answers – 4
pcb slip rings
Slip Rings in Robotics – Types, Applications, Advantages
Comparison of Level Meters - Level Measurement Instruments
Comparison of Level Meters – Level Measurement Instruments
On-Off Valve Problems
How to Solve On-Off Valve Problems?
Turbine Flowmeter Parts
What is a Turbine Flow Meter?
Catalytic-Bead-Sensor-2
Gas Detectors Working Principle
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
