Reading: Inspecting the Trends of PV and SP on a Process Chart Recorder
Inst Tools > Blog > Practical Questions > Inspecting the Trends of PV and SP on a Process Chart Recorder
Inspecting the trends of PV and SP on a process chart recorder, you notice the poor quality of control loop.
Last updated: March 9, 2021 9:04 pm
Practical Questions
1 Min Read
Inspecting the trends of PV and SP on a process chart recorder, you notice the poor quality of control:
Trends of PV and SP
Trends of PV and SP on a process chart
The “wandering” of the process variable (PV) around setpoint may be due to excessive action on the part of the controller, or it may be due to load fluctuations in the process itself.
In other words, the instability may be the fault of the controller reacting too aggressively, or it may be that the controller is not working aggressively enough to counter changes in process load.
Identify a simple method to determine which scenario is true.
Hint: the way to check is as simple as pushing a single button, in most cases.
Answer:
Place the controller in manual mode and observe the PV trend!
Share your answers through below comments section.
  • How to Calibrate Load Cells?
  • PID Controller Theory
  • What is a Recorder?
  • PM of Instrument Compressor
  • How to Read Circular Chart Recorder
Credits: Tony R. Kuphaldt
Identify the Pressure Gauge Error
Pressure Level Transmitter Problems
Practical Process Control System Questions & Answers – 11
Calculate the Height of Glycerine
Thermocouple Terminal block Questions
Air Compressor Control Circuit Problem
How Much Pressure Indicated by Micromanometer?
DP Transmitter Located 10 feet Beneath the Vessel
PLC Program to Control a Water Pump
Programmable Logic Controller (PLC) Questions and Answers – 16
PLC Pump Permissive Interlocks
Programmable Logic Controller (PLC) Questions and Answers – 4
Solenoid Valves Questions & Answers – 1
Flapper Nozzle Questions
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Two solenoid valves circuit
Solenoid Valves Questions & Answers – 4
Determine Calibration Range of Pneumatic Pressure Transmitter
Baffle Nozzle Assembly Sensitive Mechanism
Determine Resistance value of Resistors
Bourdon Tube Gauge Spiral Spring
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
AB PLC Temperature Switch
Programmable Logic Controller (PLC) Questions and Answers – 17
hydraulic module
Identify all Spool Valve Positions
Ultrapure Water in the Semiconductor Industry
microwave flow detector applications
Microwave Flow Sensor – Working Principle and Applications
Magnetostrictive Level Transmitter Working Principle
Paddle switch Working Principle
Paddle Switch Working Principle
Capacitor and Symbols
Capacitance
Electronic Devices & Circuits Quiz – Set 8
Power Systems Projects
400+ Power Systems Projects – Best Electrical Project Ideas
Comparison of Proportional Integral Derivative Controllers (PID)
