Reading: Calculate Hydraulic System Fluid Pressure
Inst Tools > Blog > Practical Questions > Calculate Hydraulic System Fluid Pressure
Last updated: June 2, 2020 6:22 pm
Practical Questions
6 Min Read
In this hydraulic system, a force of 25 pounds is applied to the small piston (area = 10 in2 ). How much force will be generated at the large piston (area = 40 in2 )?
Hydraulic System Fluid PressureHydraulic Cylinder Question 1Hydraulic Cylinder Question 2Hydraulic Cylinder Question 3Hydraulic Cylinder Question 4
Also, calculate the fluid’s pressure.
Finally, explain how Pascal’s Principle relates to this scenario.
Answer:
Force at large piston = 100 pounds. Fluid pressure = 2.5 PSI.
Pascal’s principle states that any pressure applied to a contained fluid will be experienced at all points throughout that fluid. Thus, pressure generated by the 25 lb of force on the small piston creates a pressure (2.5 PSI) distributed throughout the fluid’s volume which is experienced in full at the large piston to create the 100 lb force there.
The 5 inch dimension is extraneous information, included for the purpose of challenging students to identify whether or not information is relevant to solving a particular problem.
More Questions:
1. Identify which fundamental principles of science, technology, and/or math apply to each step of your solution to this problem. In other words, be prepared to explain the reason(s) “why” for every step of your solution, rather than merely describing those steps.
2. Identify a practical application for a hydraulic system such as this.
3. Does the pressure/force/area equation hold true for all piston positions, or only with the pistons in mid-stroke as shown in the illustration?
4. Would it matter whether the fluid in this system was a liquid or a gas? Explain in detail how the system’s behavior would differ (or not differ) depending on the type of fluid used.
5. This mechanism seems to multiply the applied force. How can it do so without violating the Law of Energy Conservation (energy out cannot exceed energy in)?
6. Demonstrate how to estimate numerical answers for this problem without using a calculator.
If force is exerted on the piston of this hydraulic cylinder, in what direction(s) will this force be transmitted to the cylinder walls? In other words, how does a fluid under pressure push against its surrounding container?
Force exerted on hydraulic cylinder
Answer:
The fluid pressure will exert an outward force on the cylinder walls, like this:
Hydraulic cylinder walls Fluid pressure
Suppose a small rubber ball is floating inside the fluid of a hydraulic cylinder as shown below. What will happen to the ball when a pushing force is exerted on the cylinder’s rod? What will happen to the ball when a pulling force is exerted on the rod?
Answer:
pushing force on hydraulic rod
A pushing force on the rod will compress the rubber ball to a smaller diameter. A pulling force will expand it to a larger diameter.
A free-floating piston inside a hydraulic cylinder has a 1000 PSI of fluid pressure applied to one side of the piston, and 850 PSI of pressure applied to the other side of the piston. The piston itself is 2.75 inches in diameter. How much force will act on the piston, with these pressures applied to it?
Answer:
Net piston force = 890.936 pounds.
In this scenario, there are two pressures fighting against each other: the 850 PSI pressure is pressing downward on the piston while the 1000 PSI pressure is pressing upward. The resultant (differential) pressure is 150 PSI (1000 PSI – 850 PSI). This is the pressure figure to be used in the final force calculation.
A double-acting hydraulic cylinder has 500 PSI of pressure applied to the side without the rod and 750 PSI of pressure applied to the rod-side. Calculate the resultant force generated at the piston and transmitted through to the rod, and also determine this force’s direction. The piston is 5 inches in diameter, and the rod is 1 inch in diameter.
Answer:
Net force = 4,319.69 pounds, in the downward direction.
If your calculated force turned out to be 4,908.7 pounds, you made a very common error. Once you have figured out what this error is, go back and try to see how the scenario would have to be altered in order to actually generate 4,908.7 pounds of force with the two pressures being 750 PSI and 500 PSI, respectively.
  • Live Zero in 4-20 mA Loop
  • Why we Tune a PID Controller?
  • 4-20 mA Formula
  • Compare Fieldbus & 4-20 mA
  • Control Loop Testing
Credits: Tony R. Kuphaldt
Calculate Process Temperature using a Thermocouple
Transmitter Calibration Range of a Vessel Level
Fisher model 546 I/P transducer
Diagnosing Electric Motor Circuit
Pressure Level Transmitter Problems
Identify the Purpose of Flow Ratio Controller
Why Strain Gauge Resistance Changes as it Stretches and Shrinks?
Determine Level of Liquid in the Vessel and its Specific Gravity
DP Transmitter Error Calculations
Measure the Temperature of the RTD
Simple Pressure Repeater
Calculate the appropriate millivoltage values of a Thermocouple
Draw Wiring of a Pressure Switch to control two lamps
Problem on Tachogenerator
water seal drum lever transmitter
Determine LRV and URV settings for the Level Transmitter
Relay ladder diagram example
How to Draw a Schematic Diagram ?
Which Tube has most Hydrostatic Pressure
Which Tube has most Hydrostatic Pressure?
two chemical streams are mixed together
Practical Process Control System Questions & Answers – 12
water filter level control system
Practical Process Control System Questions & Answers – 6
Questions on Resistive Tape Level Sensor
Purge Type Level Transmitter
Purge Type Level Transmitter Questions
Differential Pressure Measurement across Baghouse
Mechanical Engineering Design and Fabrication Projects
300+ Mechanical Engineering Design and Fabrication Projects
Choppers Quiz
Electrical-Switches-Working-Animation
Difference between Star and Delta Connections
PID Simulator
PID Simulator Download
desuperheater
Desuperheater Design
What is SMPS
What is SMPS? – Types of SMPS
WHILE DO Statement in SCL Language
Transistor as Switch Working Animation
How a Transistor Switch Works
