Reading: How does an Electric Motor Operate? – AC Motor Fundamentals
Inst Tools > Blog > Electrical Basics > How does an Electric Motor Operate? – AC Motor Fundamentals
In this article, we will learn the basic concept of an AC motor fundamentals and how an electric motor operates.
Last updated: October 10, 2022 12:33 pm
Electrical Basics
2 Comments
In this article, we will learn the basic concept of an AC motor and how an electric motor operates.
Components of an AC MotorHow does an Electric Motor Operate?
Electric motors are really quite simple. There are only four basic parts to an electric motor:
  • There is the housing or external case that surrounds the other components.
  • Mounted inside the housing is the stator. The stator is the stationary or non-moving part of the motor’s interior. It is made up of wire windings. The moving parts of the motor are the rotor and the shaft.
  • The rotor, like the stator, also has windings.
  • The rotor is connected to the fourth component, the shaft. The shaft is a metal rod held in position within the stator by bearings connected to the case. The bearings allow the shaft to rotate inside the stator. The rotor and shaft are often referred to as the armature of the motor.
The electric motor operates by converting electrical energy into mechanical energy.
Let’s represent the motor’s stator as an iron block “S” and the rotor as an iron block “R”. Both of these iron blocks are wrapped with wire coils.
When an electrical current is passed through the wire coils, an electromagnetic field is created and the iron blocks become magnetized.
All magnets have a North and the South Pole. The North Pole is always trying to get next to the South Pole and vice versa.
Two North or two South poles will push away or repel each other. In other words, opposite poles attract, and like poles repel. It’s this magnetic pull and push principle that makes an electric motor operate.
Suppose that “S” is fastened such that it cannot move. On the other hand, “R” is allowed to move freely. When electricity is passed through the coils and the blocks are magnetized, the opposite poles try to pull together.
Block “R” will move towards block “S.” If the blocks get together the movement will stop. What if block “S” were mounted in such a way that block “R” couldn’t contact it? Block “R” would move until its positive pole was as close as it could get to block “S” and then the motion would stop.
Learn electric motor
Let’s add more “S” blocks (S1, S2, S3, and S4). If S1 were demagnetized just as “R” reached it, and S2 is magnetized, “R” would continue moving toward “S2.” If this same process of demagnetizing and magnetizing S1, then S2, then S3, and finally S4, were continued then block “R” would be moving all the time until it reached S4.
In an electric motor, the “S” magnets are formed in a circle and the “R” magnet is placed inside this circle and is attached to a shaft. The stator and rotor are magnetized as current flows through the coil windings.
fundamentals of an AC motor
The rotor moves so that the opposite poles of the windings can try to move closer to the stator magnets. Just as the magnets are close the magnetic field moves on in the stator, and the rotor chases after it.
Since the rotor and shaft are fastened together, the shaft moves. The rotation of the shaft is the mechanical energy created by the conversion of the electrical energy by the motor.
To summarize, the rotor “chases after” the changing magnetic field of the stator which causes the rotor and shaft to rotate. The magnetic fields of the stator and rotor are changed according to the frequency of the AC voltage applied to the motor.
Changing the frequency of the voltage applied will alter the speed at which the stator’s magnetic fields change. This will, in turn, change the speed of the rotor.
Changing the current will alter the strength of the magnetic fields of the rotor and stator. The stronger the magnetic fields the greater the turning force applied by the rotor to the shaft. This twisting or turning force is called torque.
In this way, we understand the basic fundamentals of an AC motor.
What is an Inductor? – Types of Inductors
Difference between Soft Starter and VFD
Difference between Servo Motor and DC Motor
What is SMPS? – Types of SMPS
2 Comments
  • Ismael Kukubol says:
    October 18, 2022 at 3:52 pm
    Dear sir /Madam
    I am interested to this opportunity l,m interested learn more about instrumentation and so forth.
    Thank you
  • Pradeep says:
    October 23, 2022 at 5:35 pm
    Very beautiful explanation for understanding about torque by motor. Continue your good work.
How to Size a Cable for Industrial AC Motors?
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
What is Vacuum Circuit Breaker?
Types of Industrial Storage Batteries
Difference Between Permittivity and Permeability
Differences between Watts and Volt Amps
VFD Pros and Cons – Variable Frequency Drives
LBB protection relay
What is the LBB Protection Relay? (Local Breaker Backup)
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Intelligent MCC
What is Smart or Intelligent MCC?
Hybrid Solar Power System
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
Difference between Analog Signal and Digital Signal
Clamp Meter
Things to Know When Measuring Current
UL 489 Circuit Breaker
Difference Between UL489 and UL1077
D flip flop in PLC
D Flip Flop PLC Ladder Logic
Hydraulic Actuator
Types of Valve Actuators
Control Valve Selection Guide
Configure Analog Inputs and Outputs in Delta PLC
Determine Calibration Range of Pneumatic Pressure Transmitter
What is a Fuse
What is a Fuse ?
Measurement of Xd and Xq – Synchronous Machine
memory types in siemens plc
Memory Structure of Siemens PLC
