Reading: How Does a Touch Sensor Work?
Inst Tools > Blog > Common > How Does a Touch Sensor Work?
touch sensor is the one that senses touch and converts this action into electrical energy to pass on the information to the processor.
Last updated: September 28, 2022 4:07 pm
Common
In this post, we will see the working of a touch sensor.
Touch SensorResistive Touch SensorCapacitive Touch Sensor
Touch sensing is one of the most widely used technologies in today’s world. Almost every electronic thing in today’s time is going touch, be it from a small smart-watch to a big laptop.
As the name implies, a touch sensor is the one that senses touch and converts this action into electrical energy to pass on the information to the processor.
Touch Sensor
Touch makes work easier because you feel the real-time experience of what you want and as touch reaches each and every corner of the screen; you get more access to the navigations and buttons available on the screen.
If you want to understand the working principle of the touch sensor, you need to get through the two most basic ones – resistive and capacitive.
Let us see both of them one by one.
As the name implies, it uses resistance as a means to define where the touch has been done. It consists of two layers – one conductive and one resistive.
The upper layer is the conducting one where the touch is done and the lower layer is the resistive one where the touch sensing information is passed on to the processor.
The conductor mostly used in both the layers is indium tin oxide. Both these layers are separated by a thin gap or air.
Current is always flowing through both layers. When you press the finger or stylus against the upper layer, the pressure of touch changes the resistance value (increase in voltage).
The lower layer detects this change and through its computed algorithms, determines the coordinates of the touch and thus, the position of touch is determined.
This is one of the recently developed technologies in touch sensing. Unlike resistive touch which depends on mechanical input pressure from the finger or stylus, capacitive touch depends on the electric conduction from the human body.
A human body’s natural conductivity is used to detect the touch. It consists of electrons and atoms which allows a small flow of electricity.
The sensor contains two parallel conductors with an insulator between them. These conductors act as a capacitor with a capacitance value. The conductor mostly used in both the layers is indium tin oxide or copper oxide.
Now, when the finger touches the screen, the finger acts as a conductor. This additional conduction increases the capacitance of the second conductor layer.
Basically, the static electricity from the finger is transferred to the second layer of conduction. This disturbs that particular electrostatic field in the conductor layer.
With the help of computations from the processor, the circuit can determine where this disturbance occurred, and thus, you get the touch point of the finger.
For your information, it is to be noted that there are two types of capacitive screens – projective and surface.
Projective type is a tight grid of special sensor chips, and surface type is a combination of itsy bitsy sensors in the corners. But, whatever its type, the basic working is the same.
Common Conveyor Problems and How to Prevent Them
Automation in the Construction Industry
What is a Process Alarm? Types of Alarms
Ultrapure Water in the Semiconductor Industry
Introduction to Fluid Power and Pneumatics
What is an Automotive Radiator?
Level Measurement and Control using Arduino C
Modbus Relative Addressing
Power Tool Maintenance – When And How To Replace Carbon Brushes
Top 10 Podcasts about Electronics
Pressure Regulator with Flapper-Nozzle Principle
Difference between IP Address and MAC Address
What are the Advantages & Disadvantages of CNC Milling?
Top 20 Instrumentation Service Business Opportunities in the Industry
IP transducer
Pilot Valves and Pneumatic Amplifying Relays
Gamp 5 Compliance in Pharmaceutical Industry
HVAC System Heat Transfer Loops
Heat Transfer Loops in HVAC System
Displacement Sensing Accelerometer
Seismic Displacement Sensing Accelerometer
Solar Arrays
Solar Photovoltaic Cells – Parts of the Solar Panel
Artificial intelligence in supply chain management
Strip-Chart-Recorder-Working-Principle
Strip Chart Recorder Working Principle
Hydraulic Load Cell Principle
Orifice Beta
Single Loop Control
Cascade Control Principle
flow Nozzle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Determine Level of Liquid in the Vessel and its Specific Gravity
Bucket Elevator Wrecks
Many Bucket Elevator Wrecks rob crew morale
RTD
Why 4 wire RTD Measurement Accuracy is better than 2 and 3 wire RTD?
Siemens PLC Math Instructions
Siemens PLC Mathematics Instructions
