Reading: Gas Turbine Temperature Alarms using Siemens TIA Portal
Inst Tools > Blog > PLC Tutorials > Gas Turbine Temperature Alarms using Siemens TIA Portal
Last updated: March 4, 2021 12:34 pm
PLC Tutorials Power Plant
This article is about the temperature alarms PLC program for a Gas turbine. Here we will use Siemens TIA PORTAL for programming the logic.
Gas Turbine Temperature AlarmsPLC Logic using Siemens TIA PortalProgram Description
There are many applications in the industry where we need to measure the temperature accurately. If the process temperature goes out of the required range then there must be an alarm generated in the system.
In a Gas turbine, there are various elements need to be monitored like speed, temperature, lube oil pressure, etc.
Here in this article, let’s consider that in the gas turbine we have to measure the temperature in one of the sections.
Here we will take three temperature sensors where RTD PT 100 is used for its constant high accuracy for a smaller range of the temperature measurement. If anyone of the sensors goes out of the range as per the defined temperature setpoint, there should be an alarm generated, which is to notify personnel that things are not working properly.
Also, we want an average of three sensors to maintain a predefined temperature difference. Let’s say, in our case we need to maintain an average temperature of 100°C. We also need one more alarm to indicate, when the average temperature goes out of the range.
If the Temperature difference between Temperature sensor_1 and the average temperature goes above 100°C then the alarm should be generated. Same applicable for sensor_2 and sensor_3.
Whenever there is an active alarm in the system, then I want an additional GENERAL ALARM to be activated.
Here I will use 3 Analog INPUT’s for three RTD temperature sensors and four outputs, out of them one for average temperature indication and three for individual RTD’s.
Inputs:
  • TEMPERATURE SENSOR_1 (MD0)
  • TEMPERATURE SENSOR_2 (MD4)
  • TEMPERATURE SENSOR_3 (MD8)
Outputs:
  • ALARM_1 (Q0.0)
  • ALARM_2 (Q0.1)
  • ALARM_3 (Q0.2)
  • ALARM_4 (Q0.3)
Now first, we need to calculate the average of the temperature readings. For that, we have to add the values of the three temperature sensors and divide it by 3.
Average of 3 Temperature Sensors
Gas Turbine Temperature Control using Siemens Tia Portal
Program Description
Network 1:
Here, I have added the three temperature sensors readings using ADD instruction and divide it by three as per the above-shown equation to get an average temperature.
Network 2:
Here, we want to generate an alarm, when the difference between Temperature sensor_1 and the average temperature goes above 100 °C. To compare it, we have used greater than instruction.
To generate that difference, I have used subtraction instruction.
Here, absolute instruction is used to reverse the sign (+ or -). If the temperature difference goes negative, we want it to positive using absolute instruction. So, it only alarms when the temperature goes above 100 °C.
Absolute instruction only uses real data type. That’s why we have used data type “real” in all the instructions.
Network 3 & 4:
Here, as explained in the above network Alarm_2 and Alarm_3 generated if the temperature goes above 100°C.
Network 5:
As the temperature difference goes above 100°C from any one of the sensors then the main alarm will also generate.
Author: Suhel Patel
  • Troubleshoot PLC Program
  • Lube Oil Pump Logic
  • PLC Maths Instructions
  • What is PID Controller?
  • PID Controller Loop Tuning
Machine Tool and Coolant Control: PLC Ladder Logic Design
PLC Pneumatic Circuit Control
PLC Program for Paint Spraying
PLC Programming for Weight-Based Packaging
  • LAMRI says:
    September 11, 2022 at 1:17 pm
    GOOD, THANK YOU VERY MUCH
How to take Backup from Siemens S7-300 PLC?
How Does Redundant Power Supply Work?
Jump Instruction in Siemens Tia Portal
What is a Wet Contact? – Basics of PLC Wiring
Smart Spray System using Wecon PLC
Basic Pumping System Application Used in Industrial Automation
FC Function in Siemens PLC
Manual sequential logic in Schneider PLC
Programming Schneider PLC Manual Sequential Machine
Siemens PCS 7
What is PCS 7?
Programmable Logic Controller (PLC)
What is Interposing Relay in a PLC System ?
Automatic Car Washing Process using PLC Ladder Diagram
TIA Portal Options
How to Troubleshoot Siemens PLC Programs?
How to Activate the Schneider PLC Software License
How to Download EcoStruxure Machine Expert? Schneider PLC Software
PLC engineering software
How to Download GX Works? Mitsubishi PLC Software
Automated Garage Gate Control - PLC Ladder Logic
Types of Flow Meters
Specific-Conductance-Calibration-Procedure
Types of AC Motors and DC Motors
Troubleshooting Ultrasonic Flow Meter Common Problems
control of level in three cascaded Loops
Multiple Lags (orders)
Digital Electronics Projects
Top 100 Digital Electronics Project Ideas for Engineering Students
Patch Panel
One Shot Rising PLC Example Program
Power Systems MCQ Series 12
