Reading: Falling Ball Viscometer Principle
Inst Tools > Blog > Analyzers > Falling Ball Viscometer Principle
Last updated: July 15, 2019 7:21 am
Analyzers
2 Comments
Falling Ball Viscometer uses the simple — but precise — Höppler principle to measure the viscosity of Newtonian liquids by measuring the time required for a ball to fall under gravity through a sample-filled tube.
The principle of the viscometer is to determine the falling time of a ball of known diameter and density through a close to vertical glass tube of known diameter and length, filled with the fluid to be tested.
The viscosity of the sample liquid is related to the time it takes for the ball to pass a distance between two specified lines on the cylindrical tube.
Turning the measurement tube results in returning of the ball and it is possible to re-measure the time over the same distance. The result is dynamic viscosity with the standard dimension.
Velocity of a ball which is falling through a liquid in a tube is dependent on the viscosity of the liquid. When the ball moves through the liquid, it is affected by the gravity, buoyancy and frictional forces: Gravity as downward force, buoyancy and friction as the upward forces.
How It Works
The Falling Ball Viscometer is based on the measuring principle by Höppler for simple but precise dynamic viscosity measurement of transparent Newtonian fluids.
The basic concept is to measure the elapsed time required for the ball to fall under gravity through a sample-filled tube inclined at an angle*.
The tube is mounted on a pivot bearing which quickly allows rotation of the tube 180 degrees, thereby allowing a repeat test to run immediately.
Three measurements are taken and the average time it takes for the ball to fall is the result. A conversion formula turns the time reading into a final viscosity value.
Calibration Procedure
  • Fill the falling tube with studied liquid and put in the ball cautiously. Add more liquid till no air bubbles can be seen. Then close the falling tube by its cap.
  • Before starting the measurement, it is better to turn the falling tube up and down at least once in order to enhance temperature uniformity along the tube.
  • Turn the falling tube 180 degree. Start stop watch when the ball reaches to the first marks on the tube, and measure the time between the two marks. For better and more accurate results it is recommended to repeat the measurement 10 times at each temperature.
  • After changing the bath temperature, it’s highly recommended to wait at least 20 minutes to ensure temperature stability for the sample.
  • At the end of the experiment, empty the tube from the liquid and remove the ball from the tube very carefully. Clean the tube with suitable solvent and/or a brush.
  • Write down the density of liquid and ball respectively. Calculate the average time “t” for each temperature and calculate the viscosity using equation
Calibration
For calculating the viscometer constant, do all the above steps with a liquid which has a known viscosity such as distilled water but use the dynamic viscosity of distilled water in equation and calculate the viscometer constant, K.
Notes:
  • The liquid in the falling tube should be free of bubbles.
  • Generally the measurement for calibration is done at 20°C.
  • Measuring of the time starts when the lower edge of the ball touches the upper mark and ends when crosses the lower mark.
Ozone Analyzer Working Principle
Turbidity Analyzer Working Principle
Non-Dispersive Analyzers
H2S Measurement Using Lead Acetate Principle
Specific Conductance Calibration Procedure
Difference Between Absolute and Relative Humidity
2 Comments
  • Jon Watson says:
    February 5, 2020 at 9:58 pm
    When first inverted the ball will start with zero velocity, its velocity increasing as it falls. At some point, if the ball is correctly sized for the anticipated viscosity, it will reach terminal viscosity before the first of the two marks and thus travel between them at constant velocity.
    However if the ball is too small it may reach terminal velocity only after having passed the first timing mark.
    This is an application of Stokes law. This allows the viscosity to be calculated from the elapsed time.
    https://en.wikipedia.org/wiki/Stokes%27_law
    However, this is not always a convenient way to approach falling ball measurements.
    Typical Hoppler viscometers are from Brookfield https://www.brookfieldengineering.com/products/viscometers/laboratory-viscometers/falling-ball-viscometer
    These methods produce the dynamic viscosity. In the hydrocarbon industry the kinematic viscosity is most commonly required which thus requires also the density.
    I’ve suggested that the Stokes law method allows a direct calculation of the viscosity and I have a query about the Hoeppler method.
    Does the method depend on establishing the terminal velocity or simply the time between two timing marks?
    If the latter then the conversion tables would, I suspect be based on the individual instrument and its original calibration. Can you comment on this?
    The only time I have come across the Stokes approach was in college and the Hoppler in various marine fuel testing applications.
    Such instruments are popular for their simplicity and speed of operation, important when sampling fuels as they are being bunkered.
    Of course, in most hydrocarbon measurements it is the kinematic viscosity that is required and that means also determining the density.
  • Fatma El-Abyad says:
    September 8, 2020 at 6:08 pm
    what is the max range of viscosity this instrument can measure
Moisture and Dew Point Analyzer Problems and Troubleshooting Tips
Basics of Suspended Particulate Matter (SPM) Analyzers
What is Chromatography ?
Mass Spectrometer Working Principle
pH measurement
Thin-Layer Chromatography : Manual Method
Conductivity Transmitter Calibration Procedure
Fluorescence
Analyzer Sample Conditioning
Sodium Analyzer Problems and Troubleshooting Steps
Free chlorine Analyzer Principle
Hair Hydrometer Principle
Electrical Conductivity Meter
What is the Application of Electrical Conductivity Meter?
Measurement of Carbon Dioxide in Flue Gas
Technologies for Oxygen Gas Measurement
Dew Point Method Humidity Measurement
Humidity Measurement Principle
Chemiluminescent Analyzer
Chemiluminescence
What is Optical Coating
What is Optical Coating?
How to Install Thermowell on an Elbow?
PLC Ladder Logic for Motor Control
PLC Program for Motor Starter
V Cone Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
Hydrostatic interface level measurement Formula
Hydrostatic Interface Level Measurement
RTD Calculator : Calculate Temperature from Resistance
Allen-Bradley VFD
Why V/f Ratio is kept Constant in VFD?
