Reading: How does Electrical Power Outlet Work?
Inst Tools > Blog > Electrical Basics > How does Electrical Power Outlet Work?
An electrical power outlet is used to distribute electricity to various devices and loads connected to it.
Last updated: February 24, 2023 1:17 pm
Electrical Basics
Power outlets are an important part of an electrical circuit. It is so easy that you just plug in a laptop on your power outlet socket and your laptop starts charging.
Power OutletHow does Power Outlets Work?
Basically, a power outlet is thus used to supply electricity to any device connected to it. As electricity is a very important part of our life, it is actually necessary to understand how these outlets work.
In this post, we will learn about the working of power outlets.
Power Outlet
First of all, let us understand what a power outlet is. As you know, AC power has two lines – phase and neutral. From a power distribution grid system, a single-phase system is distributed. This single-phase line (phase and neutral) is then distributed to various circuit breakers in a local panel. From local panels, this electricity is distributed to various sockets which require electricity. These sockets are called power outlets.
Power outlets allow electrical equipment to connect to the electrical supply. You just need to insert the device in the outlet and your device will start working when switched on. Sockets and outlets vary in different countries and they have their own shapes and sizes. But, the working of an outlet is same.
So, simply, a Power outlet is defined as a source for providing power to the final devices for use requiring it. You cannot directly feed power from the substation to your devices. There are various stages in between and due to transformers and various circuit breakers, you get the final safe power supply for your devices.
Power Outlet
Refer to the below image. As discussed earlier, the AC power has two lines. Out of a transformer or circuit breaker, two wires come in the outlet. One is the phase wire and the other is the neutral wire.
In electrical terms, the proper term used for outlets is hot and neutral. Here, hot means phase wire. The phase wire comes and connects to one end.
The neutral wire is connected to the other end and joins the neutral line in the corresponding circuit breaker or transformer.
Now, due to the switch connected to turn on or off the supply, if the switch is off, then no power will flow from the line to neutral even if the device is connected. If the switch turns on, then the power will flow from the line to the device and then back to the neutral; thus completing the circuit.
This method is actually called polarization. The benefit of polarization is that polarized plugs can only be inserted in one orientation, so the switch to turn any device connected to the socket on or off can be built into the hot lead. In a non-polarized plug, the switch may only open the circuit at the neutral lead, which means that most of the internal circuitry of the device is still considered “hot” and can lead to shock hazards.
Now, let us discuss the third pin – ground. As the name suggests, grounding is provided to protect the device and the personnel from any electrical hazards. A grounding wire is connected separately to each outlet and then is connected to the bottom of the breaker box. This can protect the system from overvoltage or sudden surges.
If there is no ground wire, then when you accidentally touch a device and if there is some voltage malfunction, then you may get a shock or in the second scenario, the device itself will get damaged. Grounding nullifies this by passing the leakage current to the ground.
How do Electrical Power Outlet Work
Basically, the working of outlets are the same, be it whichever country, shape, or size.
In this way, we understand the working of a power outlet.
  • Industrial Circuit Breakers
  • Electrical Motor Concepts
  • Relays in Air Circuit Breaker
  • Induction Motor Over Voltage
  • Purpose of Electrical Substation
Why is IGBT used in VFD?
Types of Relays used in an Air Circuit Breaker (ACB)
VFD Engineer Roles – Installation and Commissioning
How to Locate Faults in Cables? – Fault Analysis & Location
Current Transformer Selection, Operation & Maintenance
Basics of Electricity Rates
Testing and Inspection of Bonding and Grounding Systems
What is Switchgear and Electrical Substation?
Pros and Cons of Soft Starter
Why do we need to Control the Motion using VFD drives?
What is a Substation? Purpose of an Electrical Substation
Why Are Neutral and Earth Separated?
Types of Motor Loads – Constant & Variable Torque, Horsepower
Classic Control Circuits
Components of Electrical Motor
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
Why CT Secondary Should Never Be Kept Open?
Types of Industrial Storage Batteries
What is an Electrical Drive
What is an Electrical Drive? Types, Advantages, Disadvantages
What is a Magnetic Field
Difference Between Electric Field and Magnetic Field
Electrical bonding jumpers
Proper Sizing of Conductors
Circuit Breaker Making Capacity
Reproducibility in Measurement
What is Reproducibility?
How to Download Rslogix Free
Download Allen Bradley RSLogix PLC Software
Radio Telemetry Objective Questions
3 Phase Bridge Inverters Quiz
valve plug and seat damage
Control Valve Erosion Problems
Microprocessors Objective Questions – Set 4
How to use Scale and Normalize Instructions in PLC
How to Calculate Heat Load In Electrical Panel
How to Calculate Heat Load in Electrical/Electronic Panel Enclosure
