Reading: Diodes Questions & Answers
Inst Tools > Blog > Electronics Q & A > Diodes Questions & Answers
Last updated: September 11, 2016 4:18 am
Electronics Q & A
1. Explain what is a pn junction?
The contact surface between the layers of p-type and n-type semiconductor pieces plated together so as to form a p-n junction is called the p-n junction.
2. Why is silicon preferred over germanium in the manufacture of semiconductor devices?
The silicon semiconductor devices have, in general, higher PIV and current ratings and wider temperature range than germanium semiconductor devices, that’s why silicon is preferred over germanium in the manufacture of semiconductor devices.
3. Explain what does the arrow head represent in the schematic symbol of a p-n junction?
The arrow head in the schematic symbol of a p-n junction indicates the direction of conventional current flow when the diode is forward biased.
4. Explain what are the two mechanisms of breakdown in a p-n junction?
Avalanche and zener breakdown.
5. Name the breakdown mechanism in a lightly doped p-n junction under reverse biased condition.
Avalanche breakdown.
6. Name the breakdown mechanism in a highly doped p-n junction under reverse biased condition.
Zener breakdown.
7. Explain what is an ideal diode?
An ideal diode is a two terminal polarity sensitive device that has zero resistance when it is forward biased and infinite resistance when reverse biased.
8. Explain what is reverse saturation current?
Reverse current of a diode is due to minority carriers and is caused when the diode is reverse biased. Only a very small voltage is required to direct all minority carriers across the junction, and when all minority carriers are flowing across, further increase in bias voltage will not cause increase in current. This current is referred to as reverse saturation current.
9. Is reverse saturation current of a diode is independent of reverse bias voltage?
Yes.
10. Why is germanium more temperature dependant than silicon?
Because the reserve saturation current in case of a germanium diode is approximately 1,000 times larger.
11. Explain what is the effect of temperature on the reverse saturation current of a diode?
Reverse saturation current , theoretically , increases by 8% per oC for silicon and 11% per oC for germanium. But from experimental data it is found that that reverse saturation current increases by 7% per oC for both silicon and germanium. This is because a surface leakage current component of reverse saturation current is independent of temperature. Since (1.07)10 =2.0 (approx.), the reverse saturation current approximately doubles for every 10oC rise in temperature.
12. Explain what is static resistance of a diode?
The static or dc resistance of a diode is the resistance offered by it to the direct current . It is defined as the ratio of the diode voltage and current at the point of interest and is not sensitive to the shape of the V-I characteristic curve. It decreases with the increase in diode current or voltage.
13. Define dynamic resistance of a p-n junction diode in forward biased condition.
The resistance offered by a p-n junction diode to the changing forward current is defined as the dynamic resistance.
AC or dynamic resistance, r = (Small change in forward voltage) /(Small change in forward current)
Operational Amplifiers Questions & Answers
Electronics Questions & Answers
Semiconductors Diodes Questions & Answers
Special Purpose Diodes Interview Questions & Answers
Basics of Amplifiers Interview Questions
Number Systems Questions & Answers
  • Dlightdaily says:
    November 17, 2016 at 7:37 am
    Sir,
    Thanks for sharing ! Very useful Q & A to clear basic electronics concepts.
Transistors Questions & Answers
PN Junction Questions & Answers
Bipolar Junction Transistors Questions & Answers
Logic Gates Questions and Answers
Cathode Ray Oscilloscope Questions & Answers
BJT Amplifiers Interview Questions & Answers
Electronic Meters Questions & Answers
Basic Electronics Questions & Answers
Rectifiers & Filters Interview Questions
Instrument Cable
Difference Between Power Cable and Instrument Cable
Electrical Heating Objective Questions and Answers
Digital Control Systems
Compensation Techniques : Control Systems
What is Photoionization Detector (PID)
What is Photoionization Detector (PID)?
4-20mA to Process Variable conversion
Formula to Calculate Process Variable from 4-20mA
PLC Programming Best Practices and Tips
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
Fieldbus Transmitter Calibration
