Here is the online Test questions and answers on digital electronics subject with explanation.
Online Test on Digital Electronics
1. A full adder has
A) 2 inputs, 1 output
B) 3 inputs, 2 outputs
C) 3 inputs, 1 output
D) 2 inputs, 2 outputs
2. The main equation for a D flip flop is
A) Q=0
B) Q=1
C) Q=D’
D) Q=D
3. The state of a flip-flop can be switched by changing its ________ signals.
A) triggering
B) input
C) clearing
D) output
4. Number of 2 input multiplexers need to construct a 210 inputs multiplexer is _________
A) 129
B) 9
C) 1023
D) 32
5. Odd parity of a bit stream can be tested using ________ gate.
A) AND
B) OR
C) XOR
D) NOR
6. For 4 bit parallel addition, we need ________ half adder(s) and ________ full adder(s)
A) 0 and 3
B) 0 and 4
C) 1 and 3
D) 1 and 4
7. A half adder has
A) 2 inputs and 1 outputs
B) 2 inputs and 2 output
C) 1 input and 2 outputs
D) 1 input and 1 output
8. A graphical representation of a products in a truth table is called as
A) Mapping
B) K-Map
C) Graphing
D) T-Map
9. The momentary change in the output/state of the flip-flops is known as
A) trigger
B) tri-state
C) inverter
D) unstable state
10. Simplified form of the function f = (x+y+xy)(x+z)
A) x+xyz
B) x+y
C) y+xz
D) x+yz
All 30 questions and answers are available in the Quiz.
Take All Tests :
- Digital Electronics Quiz – Set 1
- Digital Electronics Quiz – Set 2
- Digital Electronics Quiz – Set 3
- Digital Electronics Quiz – Set 4
- Digital Electronics Quiz – Set 5
- Digital Electronics Quiz – Set 6
- Digital Electronics Quiz – Set 7
- Digital Electronics Quiz – Set 8
- Digital Electronics Quiz – Set 9
- Digital Electronics Quiz – Set 10
- Digital Electronics Quiz – Set 11
Interesting question
