Reading: Difference Between HV and LV Cables
Inst Tools > Blog > Electrical Basics > Difference Between HV and LV Cables
In this post, we will learn some basic differences between two widely used electrical cables – HV (High Voltage) and LV (Low Voltage).
Last updated: September 28, 2022 4:12 pm
Electrical Basics
3 Min Read
In this article, we will learn the difference between HV and LV cables.
HV CablesLV Cables
Electrical cables come in seven different categories of voltages. They are – rated, nominal, extra-low, low, medium, high and extra-high.
Cables work on voltage levels. They are selected depending upon the voltage that will be passed through wires. In this post, we will see some basic differences between two widely used cables – HV (High Voltage) and LV (Low Voltage).
Both these cables use copper and aluminium as conductor alloys.
HV Cables
HV cables are used for a very high voltage transmission; typically used in power plants and transformers. It will vary between 33kV to 220kV. They mostly work on power grids.
The reason for using such types of cables is that they increase efficiency in a very good way. As they are very high voltages, the insulation too must be very strong in such high tension wires.
They have a very high layer of insulation protection for a reliable transmission mode. Due to a high level of electrical engineering used in the transmission of the voltage of such large levels, a very big scale of industrial automation technologies like DCS, SCADA, and other centralized modes of control are used so that the transmission happens properly through these cables and there is no risk to human life or nearby surrounding.
LV Cables
LV cables are used for domestic and small-scale industrial purposes. It will vary between 70V to 600V. A large scale of automation technologies and factories employing it use these cables as they are enough to satisfy the working of machines.
 It can be said that if high voltage cables are used for power purposes, then low voltage cables are used for control purposes. In any case, no human can touch these live wires, or else it may cause death.
Voltage from power plants is stepped down through transformers and substations; which then give us a normal reliable voltage for our domestic and industrial purposes.
To pass all these voltage levels efficiently, cables play a very important role and each cable has its own electrical properties which must be understood properly before selecting it.
  • What is Megger Test?
  • Torque Boosting in VFD
  • Types of Motor Enclosures
  • Electrical Single Line Diagram
  • Compare NEMA and IEC Motors
What is an ELV System? – Extra Low Voltage
Why CT Secondary Should Never Be Kept Open?
Difference Between Power Cable and Instrument Cable
Dynamic Braking Resistor in VFD
What is an Auto Changeover Switch?
What is a Protective Relay? Principle, Advantages, Applications
Types of Circuit Breakers, Advantages, Disadvantages
Dahlander Motor Control Circuit and Power Circuit
How to Protect Electrical Terminal Blocks From Tampering?
Difference Between MCB and MCCB
What is a Wave Trap? – Power Line Carrier Communication
Electrical Feeder Automation in Smart Grid
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Time Delay Fuse
What is a Time Delay Fuse? – Principles and Advantages
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
Types of Industrial Storage Batteries
What is Electrical Interlocking?
Electrical Contactor Interlocking Circuit Explained
Circuit Breaker Making Capacity
Advantages of Star and Delta Systems
Pneumatic Transmitter
Questions on Pneumatic Transmitter and Repeater
Sprinkler System
Basics of Sprinkler System
Instrumentation of Ion Spectroscopy
Single Bearing Motor Stator Winding
Critical High KiloWatt Motor Winding Burnout Threats
Comparator used in Siemens S7-1200 PLC.
Siemens PLC Comparator Logic
Motor STAR - DELTA Working principle
Motor STAR – DELTA Starter Working Principle
Surface Detector Level Measurement System
Surface Detector Level Gauges (Plumb-bob)
What is FAT and SAT?
