Reading: Demo of a SCADA Software – Level Control System
Inst Tools > Blog > Control Systems > Demo of a SCADA Software – Level Control System
Last updated: March 4, 2021 12:39 pm
Control Systems PLC Tutorials Software
3 Min Read
Clicking on the below download button to download an executable SCADA software file that will run an interactive demo of a realistic simple non-linear level control system. You can adjust the plant conditions and controller settings and observe the responses in graphical form.
Demo of a SCADAFeatures of SCADA SoftwareDownload SCADA Demo
Note: some antivirus softwares may require you to ‘accept’ the download of this executable file.
Demo of a SCADA
Demo of a SCADA Level Control System
  • Users can adjust PID controller settings and Set Point.”
  • User-adjustable Manual Control output.
  • User-adjustable System Load.
  • Model of the tank being filled with liquid from a pump via a control valve.
  • Using the typical characteristics of a fixed speed pump and a typical control valve characteristic.
    Valve has 0.3% leakage when “Shut”.
  • The location of the working points on the pump curve and valve curve is illustrated.
  • Second-order lag introduced into line to control valve to make performance more realistic.
  • The tank outlet flow can be altered by a second valve to demonstrate the application of different loads to the system.
  • The tank outlet flow is a function of pressure drop across the outlet valve.
    The pressure drop across the outlet valve is a function of tank level plus fixed head (350) down the outlet pipe.
  • When the tank is empty the outlet flow is equal to the inlet flow.
  • When the tank is full the tank overflows.
  • A controller is PID where the derivative term only responds to the measured variable, eliminating excessive action from SetPoint step changes.
  • Gain adjustment 0 to 10, Integral adjustment 0.1 to 49.9 secs plus “Off”, derivative adjustment 0 to 10 secs.
  • Bumpless Transfer:
  • when in Manual, the Controller balances its output against valve demand by adjusting integral term initial condition.
  • When in Auto controller output is limited to 0 to 100%.
  • Anti-integral wind-up:
  • when at limit further integral action is inhibited unless tendency is to bring controller out of limit.
  • System performance is displayed on trend graph: Thin lines are controller internal values, thick lines are external (plant) values, pen colors match signal lines on the plant diagram.
  • All trend values are 0 to 100% except some controller internal values which are -50 to +50%.
Download SCADA Demo
Author: JK Controls (UK)
  • What is PID Controller?
  • PID Controller Loop Tuning
  • Compare SCADA and HMI
  • Questions on SCADA
  • Download PLC Software
SCADA Multiple Choice Questions
Problem on PLC, HMI, VFD, and Motor Circuit
Retentive ON Delay Timer using PLC
What is a Line Choke or Reactor in a VFD?
How to Retrieve PLC Project From Memory Card?
Check Block Consistency Tools in Simatic Manager
Pump and Mixer Operations Example: PLC Timer-Based Control
How to Use Diagnostic Buffer for SIEMENS PLC?
Site Commissioning Steps for PLC Programmers
PLC Conveyor Ladder Logic Program
What is a Control Loop ?
Design View of Supplying Process Control and Safety Systems
Most Asked Questions on SCADA with Answers
Different Types of Schneider PLC
Electrical Simulator
Free Electrical Circuits Simulator Download
ICS System Design
CODESYS open source PLC software
What is CODESYS? Why Do You Need to Learn it?
DCS Troubleshooting Control Valve Loop
How to Program Sequential Outputs in PLC
How to choose between PLC and DCS Systems
Safety interlock for motor starters in Siemens PLC
Motor Starter Logic using Siemens PLC Tia Portal
PLC Signal Flow
Basic DCS/PLC Signal Flow – Video
Hydrogen sulfide gas
Hydrogen Sulfide Gas (H2S)
Measuring Instruments
Flow Instruments – Selection, Principle & Application
dispersive gas analyzer
Dispersive Spectroscopy
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Types of Pressure
Basics of Pressure Measurement
Ferrule Example
Ferrules and Cross Ferruling
Siemens CPU Clock Memory
Alarm Acknowledge using PLC
